Question about Kodak EasyShare C533 Digital Camera
Will not turn on even wit new batteries - Kodak EasyShare C533 Digital Camera
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 131 Answers
Kodak, and particularly the easyshare range have so many faults...... just look on this site for starters.
bin it, (or sell it on Ebay for parts, lcd, lens, housing Ect.) and never buy another Kodak.
Posted on May 25, 2014
I'm trying to sell my 1990 Bronco, and the battery died last month. I switched the selector under the dash to off, as recommended by installing mechanic. But now I replaced the Truck battery, turned the...
It sounds like the disconnect of the battery has caused the anti-theft system to kick in. Anti-theft overrides the key. There is a chip in the key fob and a chip in the ignition lock, if they are paired and both present, the Engine Control Module releases power to the starter and the ignition circuits. When you connected your battery, I am guessing the key and fob was in your pocket.
Disconnect the battery for at least 2 hours. Hold the negative and positive battery leads together for 5 minutes to fully dissipate any residual power. Very important bit, PUT THE KEY IN THE IGNITION, but not turned on. Reconnect the battery. Wait 15 minutes for the system to self check and reset. Start the vehicle.
Apr 30, 2017 | 1990 Ford Bronco
2000 Silverado 2500 6.0. New starter, new battery. Turns over but no start. I'm at wits end !
Check the alternator. It is likely not working to charge your battery as your car operates. Your battery can sustain a momentary rush of current even when it is low, so this explains why you get a turn-over of the engine shaft. But as it drains quickly and needs a boost. It can also be cabling as well, but check that your battery is getting more voltage as the car operates (that is, after someone gives you a boost to start your car).
Feb 02, 2015 | 2000 Chevrolet Silverado 2500
I have an 93 gmc yukon brand new starter and battery wont start or even click
id make sure the fuses and relays didn't pop for the starter while installing as if it was intstalled wit the battery still connected it could have arched it causing them to blow. then id make sure the battery was good and so was the alternator first thing. second, make sure all ur connections are good ie battery ground as well as wires on the starters solinoid.
Apr 26, 2012 | 1993 GMC Suburban
My bb curve wont charge ive tryed a new battery and charger the red light doesnt even turn on idk wat to do i just woke up and it was off plzzz help
Hi
Try cleaning your phone charger port wit brush.do it gently.
check for the charger port is loose with the board or not.
if its loose .you have to take it to the technician to fix it.
If this problem occured while your phone is being connected with charger then this might be a problem with the mother board.some times it happen becz of voltage fluctuation.
Thank you.
Sep 15, 2011 | Cell Phones
I went out a few days ago and my Ford escort would not even turn over. I tried jumping it and had no luck. I tried switching over to a new battery and still no luck starting. When I turn the ignition key...
high im haveing simalar problems with mine except i turn the key and get nothing no lights no radio nothing batter is new and altenartor is good so seys pepboys.im going to check all the wireing to make sure i have a good ground to the block or frame and im also going to see if there is any exsposed wireing that could be grounding out the car ??? im probaly going to replace the alternator despite what pepboy says ill let you know what happens if i solve it or not hopefully that it will help you also check your fuses to
Mar 21, 2009 | 2001 Ford Escort ZX2
Wii remote
you have to sync the "wii-mote" open the door on the front push the red button after you turn on the remote that should sync it.
Aug 16, 2008 | Nintendo Wii Console
Compac presario v2000
try reseating the RAM,if that doesn't work replace the RAM
2 Beeps = bad RAM
Mar 24, 2008 | HP Compaq Presario V2000 Notebook
Problems when trying to charge my phone..
try soft-resetting it by taking the battery out and then putting it back in and turning on the phone. if the problem persists, you could try a different battery and/or different charger. if that still doesn't work, it's warranty time! call your carrier's cust. service or go into a corporate store and they can give you the number for the warranty dept.
Jan 28, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Kodak EasyShare C533 Digital Camera Logo
102 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
