Question about Hitachi Televison & Video
The tv doesn't respond to remote - Hitachi Televison & Video
  • 597 Answers
TRY BUYING A UNIVERSAL REMOTE...$20
Posted on Feb 02, 2014
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
RCA flatscreen remote doesn't work
\its most likely the ir sensor which has the issue. I will need the model number of your set to help you further on the issue. You can reply to this same post for further assistance if needed.
Jan 01, 2013 | Televison & Video
Remote
does the remote controller is the original remote for your tv ?. if yes and doesn't work the cause is either the IR sensor of the tv is get bad or has a problem in the board.
Oct 16, 2012 | Sony KV-27S20 27" TV
The TV stopped responding to the remote control
tried with reset doesn't work, ok it could be the IR sensor at the front panel of the tv doesn't work. but before you replace it you need to ensure if your remote controller is working. have you tried to check the remote with camera trick just to know if the remote controller is sending light to the IR sensor of the tv.
Sep 23, 2012 | Advent LC-20H15A 20 in. EDTV-Ready LCD TV
Bravia kdl52ex700 volume control doesn't work
Look for any jammed buttons on remote, any obstruction like a sticker or gum on the sensor on the TV. If you have such obstructions, the TV will respond only partially.
Aug 15, 2012 | Sony Televison & Video
Vizio TV. Can't get out of PHOTO mode. I have no remote. Side MENU button doesn't respond when in PHOTO mode. Need to Hard Reset... How can I?
^_^ Those answers are only for new remote but that's not the only way, There trying to ask in another way with out a remote.
Jan 16, 2012 | Vizio VA26L 26 in. LCD HDTV
My Technika LCD32-229 is just over 12 months old and has suddenly decided not to respond to the remote or on/off control on the TV. If I turn of the power at the mains for 30 seconds or so, it will then...
HERE'S THE ANSWER TO YOUR PROBLEM:
The possible reason why your TV doesn't respond to your remote is probably the battery of your remote. Maybe it has been used up to it's fullest capacity, so try checking it up. In case, it has been used up, try to buy a new one.
The possible reason why your TV doesn't stay on is still your remote control. Maybe you have accidentally set it to "sleep mode." When it is set into sleep mode, it turns on just for a shorter time. It cannot stay on longer.
So, here's what you've got to do. Check your remote. When the remote works already, press the sleep button remote again. I hope it works for you.
Thanks.
Jul 23, 2011 | Televison & Video
My tv show is stuck in the pause position it does not respond to any command. How do I exit from pause?
Hi the first thing I would recommend is to change the batteries of the remote control you are using. If that doesn't work make sure the remote is in range of tv or set top box.
Matthew
May 29, 2011 | Televison & Video
Remote doesn't work even with new batteries
make sure the remote batteries are in the correct + and - way. It could also be that the remote is broken. If nothing comes on when you press the power button and the tv doesn't respond, then the remote is broken and you should buy another one.
May 28, 2011 | GPX Televison & Video
Televison & Video Logo
19 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
