Question about Kodak EasyShare C533 Digital Camera
Will not turn on with new batteries - Kodak EasyShare C533 Digital Camera
John Deere LA140 won't turn. New battery. No sound when I turn the key. No headlights, what should I do?
Check your connections at the battery. May have a bad ground or bad battery connection. Also check to make sure new battery is good by supplementing with a jump start. If new battery is good and connections are solid, you most likely have a broken wire somewhere. The lights may only work with the mower running though. I believe on my LA105 the lights only come on with the engine running and dim/brighten with the RPM of the engine.
Apr 07, 2013 | Garden
Bought new battery for cell phone, wont charge or turn on
did you try a new charger not the best solutinon
Jun 11, 2012 | LG Rumor 2 Cell Phone
Camera has new batteries but will turn on a few seconds & then go off & now the lense is stuck & will not go back in or turn on HELP????
You should charge your new Nikon Coolpix L10 battery before using it for the first time. And if you continue to turn on it and discharge the battery again and again until can't turn on, the new battery maybe damaged. come to Nikon EN-EL10 Battery and see the battery maintaion.
Dec 27, 2010 | Nikon COOLPIX L10 Digital Camera
Battery charger says charged. camera will not turn on
Hi there i can 't get your these word." camera charger is blue, used battery and new,". Please let me know the battery is new or or its old? If its old then the battery life is finished. Thats why he can't store the power.
Thanks.
Feb 15, 2010 | Olympus Mju Tough 8000 Compact Digital...
Will not turn on even with new batteries
Here are the steps for the no power problem: 1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher). 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera 3. Turn on your camera without the memory card. (If it works then it?s your memory card that is faulty)
Jan 18, 2010 | Kodak EASYSHARE Z1285 Digital Camera
Wont turn on
Dec 31, 2009 | Kodak Easyshare C813 Digital Camera
I bought a new camara c433 in it won't turn on
Dec 08, 2009 | Kodak EasyShare C433 Digital Camera
New battery, new starter just installed wont turn over.
turn on your headlights ,then turn key like your going to try and start the engine and see if the headlights dim dramatically, then you'll know if you have a good connection to starter from battery, then check chg on new battery
Sep 26, 2009 | 1989 Ford Escort
Kodak EasyShare C533 Digital Camera Logo
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
