Question about Sharp UX 108 Roll paper Thermal Fax
UX A460 Paper Jam during fax reception how do I prinmt from the memory
Hi
Paper got Jam while we received a fax and the last page has not printed. I know I have something in the memory, but how can I print it
Cheers
    Problem Solver:
  • 9 Answers
Open the machine and clear the paper jam and then closed.The machine will start printing again.
Posted on Dec 31, 2007
How to clear Memory?
If the memory is filled up when a fax is received ... when there's no paper, or it is jammed (so that it can't print) ... you can print the fax (in Memory, after putting in new paper, or fixing the jam) by pressing the START/MEMORY button. After it prints, the memory is cleared.
If the memory is filled up when you're scanning and storing a document into memory (to be fax out), press the START/MEMORY key to transmit the pages that's already in memory. After transmitting the content in memory, the memory will be cleared/emptied. You'll need to scan the remaining pages to transmit (as a separate fax)
Jan 18, 2014 | Office Equipment & Supplies
My fax machine states 'fax RX in memory' and does not receive any faxes?
There is a Fax in memory. Either, the machine has a paper jam, is out of paper, or needs the ink cartridge replaced. Fix the above and the fax will print and the machine should work in Fax mode again.
For a unit with paper and no paper jam, try adjusting the paper stack and check if the unit picks up the paper properly. If you have ink in the cartridge, try cleaning the print nozzles and contacts. If a nozzle cleaning from the unit doesn't work, do it manually. Use a damp cloth (lint-free) and wipe in one direction only. Dampen the cloth with bottled or distilled water for best results. See your manual for pictures.
If you need the manual, try the Sharp site or http://www.retrevo.com/support/Sharp-UX-B700-Fax-Machines-manual/id/310bh149/t/2/ .
I hope this helps.
Jan 14, 2011 | Sharp UX B700 Plain Paper Inkjet Fax
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
Several stored faxes - how do i get them to print
You have one of these problems:
1. You are out of in and need to replace the print cartridge.
2. You have run out of printing paper.
3. You have a paper jam.
Once the problem is identified and corrected, the fax will automatically print the memory pages.
Feb 05, 2010 | Sharp UX-B750 Inkjet Fax
SHARP UX-A1000 - sends all BLACK page (to all
Noisy line? is all that strikes true when you ensure me it makes great photocopys, but then you receive OK, very strange, All the mechanisms for doing a local copy is the same as sending a fax the difference is the conversion to phone noise so it has to be electronic, I;d guess lightning/power surge, cant think of much else....sorry
Nov 04, 2009 | Sharp UX 510 Plain Paper Thermal transfer...
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Sharp fax ux b700
you have to select Auto mode of reception for fax machine with the help of receive mode button of fax machine. this setting will set machine for automatic fax reception and you get fax within 2 or 3 rings as set to your machine.
May 05, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Reprint last fax
JUST OPEN THE TOP COVER PUT IN NEW INK CAARTRIGE THEN FAX WILL RESUME PRINTING FOM MEMORY AS LONG THE POWERS WASNT TURNED OFF
Dec 31, 2007 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp UX 108 Roll paper Thermal Fax Logo
129 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
