Question about Achiever CCS5000 Shredder
Ccs/5 shredder wont power on
Our old faithful CCS/5 Achiever shredder stopped working recently. When plugged in a fain hum can be heard. I opened up the unit and motor is free but doesn't seem to be getting power thru the switch from the mainboard. I hate to trash the unit its VERY heavy duty and has been a work horse for us. Can anyone advise?
  • 3 Answers
Do a very thorough inspection of the cutting blades. I have found that just a shred of paper, that one would think would not be a problem, can in fact make your shredder act as you describe. How old is it? Depending on age & the heavy usage you say it has had.... it could very well be good old made in USA obsolescence. Wish I could tell you more. Without a multi-meter;(Ohm Meter). & manual to know what power is getting from point A to point B I cannot advise beyond this. Sorry.
Posted on Dec 25, 2013
Testimonial: "Thanks for responding Steve. I took the top off and the unit will motor thru by hand with no problem. Also, since I posted this I determined that some voltage is getting to the motor when the switch is on. It appears the mainboard that supplys power to the motor thru the switch is and is outputting lower voltage than it should. The mainboard looks fairly simple with a transformer and a relay and some other components. A tag on the motor indicates it's rated for 120v so I assume the motor should be receiving 120v when switch is on. I have a pic of the mainboard but am unsure if or how I can pot it here."
5 Suggested Answers
SOURCE: Achiever CCS 5000 Basket
Manufacturer of Achiever CCS-500 new name Homeland Security Cameras (p)800-678-5891 Basket = 15.00 + shipping 7.00
Posted on Aug 22, 2007
SOURCE: CCS 5000 Achiever Shredder
You need to purchase a real heavy duty shredder that will handle your work applications. Call 800-342-7362 EG Brennan & Co LLC can help you in this regard!
Posted on Jun 12, 2008
SOURCE: Broken wheel on ccs 5000 achiever
Have you found a source for parts yet. I am looking for one too.
Posted on May 21, 2009
matandacosma
  • 66 Answers
SOURCE: I need a brown fuse
If you are looking for a fuse you must specify the type, get the specks from the brown fuse such as:
1. current rating e.g. 13A (very important)
2. Potential Difference(PD) e.d 110V (very important)
3. Wattage e.g. 300W (very important)
4. Temperature rating (if indicated) e.g 120 degrees Celsius.
With these ratings you are able to find your fuse in an electronic shop
Posted on Jul 15, 2011
Fix this shredder
The unit is probably clogged up with a bunch of shredded paper. Unplug it ! Clean out the paper using fingers and a knife to get most of the paper clips and paper out then plug it in and run forward and reverse. That's what i do and it works every time.
Nov 16, 2013 | Achiever CCS-1500 Cross-Cut Shredder
The shredder does not work at all. No power. I changed the fuse. I have a ccs 5000.
there is sensors inside that might cause this problem
try to look inside its like a small switch
Hope it will help
Oct 12, 2010 | Achiever CCS5000 Shredder
Apr 07, 2009 | Achiever CCS5000 Shredder
HELP ME
try this number 225-923-1317 this is for a service dealer that works on Fellowes shredders but they may work on yours to
Mar 06, 2008 | Achiever CCS5000 Shredder
Broken Wheel
You should be able to contact manufacturer unless your model has been phased out
Jan 05, 2008 | Achiever CCS5000 Shredder
Ccs-1500
The solution is to remove the paper bin, and dig out the jam.
1. Unplug shredder
2. Remove paper bin
3. Lay it on it's side or back
4. Dig out all the paper around the teeth
5. Put paper bin back in and plug in
6. Should be good to go
Nov 15, 2007 | Achiever CCS-1500 Cross-Cut Shredder
Did you contact Royal Corporation. Look up the model on EBAY and you can find a replacement. I have a used basket from a customer that did not want to repair their shredder. You can have it if toy want to come to Clearwater Florida
Jul 11, 2007 | Achiever CCS5000 Shredder
Apr 12, 2007 | Achiever CCS5000 Shredder
Achiever ccs 5000 no power at all
hi check these before enything: 1) check with another device that the socket has power 2) check cable is good all the way (NOT torn, twiched, squashed) 3) the device is hooked up good (in place,NO trash) 4) there is a micro switch on the door which wont let the device work without no good connection 5) check good fuse should work good luck
Apr 05, 2006 | Achiever CCS5000 Shredder
Achiever CCS5000 Shredder Logo
127 people viewed this question
Top Achiever Office Equipment & Supplies Experts
Gilbert Ruiz
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
