Question about IBM ThinkPad T20 2647 Notebook
Screen is very dim..can barely see it..bright adjust doesnt help.
I can barely see the screen
  • ten4truth May 25, 2009
    My backlight went out several months ago, and I had the inverter replaced, but it didn't help. The repair shop then said I needed a new screen - totalling over $500 for repairs - ridiculous, obviously. I put it away and recently decided to use it with an external monitor. When I change the settings for the external monitor, the screen flashes on and stays on for a few mintues. Is this a screen problem or something else?
    Thanks
  • 221 Answers
Hi, your LCD screen's backlight has gone out. This is a hardware failure, and you'll need to have it replaced or repaired. THe LCD screen consists of two parts, the LCD screen which creates images for you to see, and the backlight which forces light through the LCD so you can see it. Your backlight has gone out, so your screen still has images, but no light.
Posted on May 17, 2009
Dim screen acer 5100-3019
Try going into power option settings and taking the brightness to the max there. Start, control panel, power options, then you should see a setting for battery and for plugin. Hope this helps.
Jun 21, 2014 | Acer Aspire 5100-3019 PC Notebook
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Mar 25, 2013 | Computers & Internet
Mytouch 3g slide screen doesnt light up
I have the same model but 4g. I often notice the same problem, but once i step out of the full sun/bright lights, i notice that it is infact dimly lit. This can be adjusted by opening settings > display > brightness > turn off automatic brightness and set the level to at least %50.
now, if your screen is literally too dim to see, try this : Press the power button quickly, now unlock the screen by sliding your finger from the bottom center up to the top center and releasing, all in one fluid motion. This is the default screen-lock gesture and the brightness, if this is indeed the issue, should go up one notch upon unlock. From there, follow the above procedure to turn up the brightness.
hope that helps
Sep 11, 2012 | HTC Black Mytouch Slide 3g Tmobile...
My calculator is very dim and i can barely see the numbers. I changed the batteries and it is still happening
Is it the brightness adjustment being messed up?
You can adjust the brightness by pressing 2nd + Up (or Down) arrow key constantly. (Like, 2nd, Up, 2nd Up, 2nd Up) to make it darker. If you do 2nd + Down, and repeat will make the screen so dim that you can barely see it >_
Oct 26, 2010 | Texas Instruments TI-83 Plus Calculator
I cant get the color right. its to red??? any help? i did notice with the back cover off, there are 6 adjustment screws
yes! those are the screen and focus adjustments. 3 for screen, 3 for focus. try this. go in menu....turn down color, brightness, contrast all they way down. you should then have no picture, but in your case a little red. then go to back of tv and turn those 3 screen adjustments all the way down. slowly turn the screens back up until you get barely a picture. because remember, your brightness and contrast is all the way down. the picture should be dim but seeable and with red, green, blue adjustments, make it a black and white picture. when balanced..... turn up color , brightness, contrast in menu. enjoy!
Nov 14, 2009 | Philips Magnavox 9P6034C 60" Rear...
The screen on my Audiovox FP1510 has gone dark
Yes, there are 4 backlight lamps but it seems you have a problem with the circuit, called inverter, that controls those lamps. m@nt
Mar 15, 2009 | Audiovox FP1520 15 in. LCD Television
GPS screen no longer lights up
If you can't control it with the controls, then most likely the backlight has died. The entire LCD display will need to be replaced as the backlight is integrated into the LCD display.
- Jim
SHARCNET-USA
Dec 09, 2008 | Garmin Nuvi 350 Car GPS Receiver
My acer aspire 9300 screen is so dim i can barely see anything
Hi.
      Have you tried adjusting the Brightness of the Display? May seem like a stupid thing to ask, but some laptops come with what is known as Ambient Light Sensors and by setting a higher brightness level it Disables the Ambient Light Sensor kicking in.
Dec 03, 2008 | Acer Aspire 9300 Notebook
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Bose wave radio/cd
Found this in the manual:
To adjust the display brightness -
The display dims automatically to medium or low brightness, as appropriate for low light room conditions. You can adjust the brightness setting of the display for both strong light and lowest light environments, but not for the medium light setting. Turn the system off before setting brightness levels.
• In a strongly lit room, hold down CD Mode and press Volume up or down to adjust the setting between 5 and 9 (it is preset to 8).
• In a barely lit room, hold down CD Mode and press Volume up or down to adjust the setting between 1 and 5 (it is preset to 2).
• If you do not want the system to dim automatically, set both levels to 5.
Feb 25, 2007 | Bose Wave Radio
IBM ThinkPad T20 2647 Notebook Logo
415 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
