Question about Garden
Valve rocker are loose - Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
On what the engine ??? what kind of engine ??? do you know how to adjust them ??? then forget asking and have someone repair it for you before you need a new valve, cylinder head or worse, an engine
Posted on Dec 28, 2013
D4eb 2.2crd sounds like noisy lifter, have replaced all eight noise still there, wonder if any problems with valve seats
possible
check cam lobes are all shiny and no missing sections
if it is a valve it could be a loose valve seat insert -- normally associated with a miss in engine noise
noise could be from worn rocker bushes or the rocker face on the valve stem end
Nov 22, 2016 | Cars & Trucks
How do I check my engine for a valve tap? It's a 1995 Buick century special four cylinder
one way is to remove the rocker cover and start the engine
let idle and using a screw driver gently place pressure on the rockers to keep the rocker on the valve end
you will hear the tap go when you press on the loose rocker
Sep 17, 2015 | Buick Cars & Trucks
Exhaust cam problem #3 cylinder
as the exhaust cams are fixed on the camshaft, unless there is a failure of the cam lobe for no 3 cylinder , there will be problems for all the cylinders on that cam
have a compression test done to check for burnt /bent valve or a loose valve seat insert for that cylinder
of the valves are operated by a rocker off the cam, it may be a rocker bush or worn rocker shaft that is the problem and not the cam shaft.
Sep 05, 2015 | 2004 GMC Envoy
Why wont the rocker arm go up or down on left side of my generator and how do i fix it.i replaced the rocker arm on that side it was broke .the bolt was broke
Several reasons why an OHV rocker won't work.
  • Push rod not installed in the lifter.
  • Stuck valve
  • Valve guide work loose jamming valve movement
  • Bad cam lobe.
Are just a few possibilities.
May 29, 2015 | Electrical Supplies
I pulled my valve covers on my 04 jeep liberty 3.7 and both sides have a rocker arm that has slipped off. there doesn't seem to be any damage done, but i have yet to pull the heads off. what should i look...
Hi, without a rocker arm, the valve would stay closed. As the lash adjusters may have been loose for a while, check the camshaft lobes for wear as well as the rockers themselves. Look around for other stuff the rocker may have damaged while bouncing around in the valve cover. Replace all of the lash adjusters, making sure to put the rockers back on their original valves. Not sure you need to pull the heads. Why don't you put it back together and run a compression test. If compression is good, valves are probably fine. Let me know if you have more questions, and thanks for using FixYa.
Dec 31, 2010 | Jeep Liberty Cars & Trucks
Mitsubishi Montero 2001 - 3.5 litre Rattle in the valve train rocker arms? Cary burchglass@hotmail.com
It could be one of the rockers are loose or you're not getting oil up there. Have it checked out quickly before the engine locks down if it's due to oil not being pumped correctly. A loose rocker is just as bad. Dumb question, But have you checked the oil level?
Dec 27, 2010 | 2001 Mitsubishi Montero
Loose rocker arm on ford in line 6 cylinder
Remove valve cover,Remove nut holding rocker. Check for damaged parts.Clean rocker nut and stud and put locktight on stud and re-tighten replace valve cover gasket if need be.
Nov 03, 2010 | Ford Fairmont Cars & Trucks
Rocker arm come out on jeep chrysler 3.7 eng
A rocker arm is the arm that sits on top of the valve stem and connects to the push rods 'the push rods sit on the cam so when engine is running, the push rods go up and down in a timed sequence and with the rocker arms, open and close the inlet and exhaust valves. the rocker arm is located inside the valve(rocker)cover .If the rocker arm gets loose or comes out.
Check the nuts on the shaft which holds the rocker arms.either the shaft or nuts are got loose.They need to be tightened.Don't make it too tight or too loose.  Too tight,and they don't flutter right. Too loose,and they allow the rocker arms to wiggle out of whack. Other possibility can be  something is broken, bent, collapsed, or out of adjustment.
Thanks. you can rate this solution and show your appreciation.
May 20, 2010 | 2002 Jeep Liberty
89 cherokee. 4.2 stroker. good oil pressure but some rattling noise in top end at idle then clears up with throttle. possibly a loose rocker?
Loose rocker, bent rocker, bent push rod, loose or bent rocker stud are a few things that come to mind. Take off the valve covers and with each cylinder at top dead center, check the play on each rocker assembly and inspect for any bent parts. Visually look down, and to the side for any mis-alignment.
Feb 03, 2010 | 1989 Jeep Cherokee
Knocking or ticking in the engine, under the valve cover ticking under valve cover in 94 cavalier i think it is the rocker arms
you are right its either a rocker arm broken or loose or it also could be a broken valve spring so look for all three While you have the valve cover off to save you coming back and looking again ... thanks Jerry
Apr 22, 2009 | 1994 Chevrolet Cavalier
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
