Question about Serfas DWC-1 Level 3.3
My serfas si-4.4 doesn't show accurate distance messure
My wireless computer doesn't show accurate distance measure even though i calibrated it according to my wheel size
Does not measure distance
Put in new batteries, clean lens, and calibrate. If this does not work, type " Leica Disto A6 Laser Distance Meter user manual " into computer search engine. It will bring up sites for manual.
Oct 18, 2014 | Leica Disto A6 Laser Distance Meter
Why doesn,t my computer connect with my modem & doesnt even connect though a wired conection ???wifi says no nework in range??? when the modemis right beside it???
If you have a laptop check all sides to see if there is a switch to turn it on, if not look at the keyboard and see if there is a wireless icon on any of the keys .If found Press the FN key and the wireless key to turn on.
Oct 03, 2014 | IBM ThinkPad Computers & Internet
Why is it showing on the Screen info 206
Put in new batteries and clean lens and calibrate.
Mar 18, 2014 | Leica Disto A6 Laser Distance Meter
How do I change from kilometers to miles, in both distance and speed?
Any search engine would greet "Serfas WC-4 manual" with the link to it.
http://www.serfas.com/product_details.asp?ID=594
It is always a good idea to try a few web searches before resorting to Experts. That's where we frequently start. Eliminate the middleman.
Aug 09, 2011 | Serfas WC-4 Level 4.4
My BMW X1 shut off in the middle of the road eventhough it had a 1/4 tank of petrol left. BMW suggested I fill it up with petrol and it started again. I am left confused as to why that happened...
The fuel sender unit could be faulty. It says 1/4 tank even though it is almost empty. Carry a jerry can of gas in the back , and run it down to 1/4 or less to see if the problem repeats itself.
The gas guage and trip computer are only as accurate as the float in the tank.
Feb 08, 2011 | 2011 BMW X1
How do I calibrate my stanley laser level
to calibrate you need to have an area 75 to 100 feet in distance. place laser on tripod 20 feet from one end, take measurements on short and long end, then move laser to center of range and take measurements on both ends . the distance between both sets of marks should be within + or - 1/4 inch if not move level screw to move beam to center then center bubble
Jun 17, 2010 | Stanley 77 156 RL100 Manual Leveling Dual...
Hello, I want to calibrate a Marksman Distance Measure, but I dont know how I have to. Please, help me. thanks in advance
If you take a tape measure and step from the wall at exactly 10 feet, you will be able to turn the calibration knob to the same exact distance. All other distances from that point on will be precise. Thank you, Dana
Mar 05, 2010 | Black & Decker Distance Measurer with...
How do you fix a broken tape and what size "rivits" to repair a 100' 1/4" tape
pick up and throw out. purchase new one. If the tape head or foot. (End grabby bit) has broken or moved to far the tape will not read accurate. So if youre using a tape that has to be calibrated or has to be accurate its useless.
hope it helps.
Oct 03, 2009 | Lufkin Measuring Tools & Sensors
The tool is not staying calibrated
I would say from the sound of it, that it is loose and sloppy or dirty. You can clean and tighten it up but I do not know how much exposer you have had in calibrating. I would be glad to take a look at it and more than likley fix it for no charge. I was a Tool & Diemaker for 25 years and am now retired. I would ask that you supply return postage on a return box.
Good luck, Jack
Aug 02, 2009 | Arsenal Gaming Frankford Arsenal Dial...
Serfas DWC-1 Level 3.3 Logo
Top Serfas Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Serfas Cycling Expert? Answer questions, earn points and help others
