Question about BroilKing Crown 20 Grill
Doesn't get hot enough (about 200degrees)
We've had it for about 2 yrs, keep it covered and use it all yr. Now, it doesn't get hot takes about 2 hrs to cook a steak. Any suggestions?
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 06, 2010
What is the best time of day to run the Salt Water System...Morning, Afternoon or Evening?.....and how long? Manual says run for about three hours but that doesn't seem enough...we have been having...
I have an 18 X 33 oval and temparatures here range from 80 to 102 in the summer. I run my cycles at 10 to 12 hrs pump with 8 to 10 hrs chlorinator. Water stays crystal clear, no cloudy.. Now...if you don't keep the electrolytic cell clean and maintain the proper salt levels, you will struggle with making free chlorine...
Hope I helped??? AND... I HAVE NOT ADDED ANY CHEMICALS TO MY POOL IN THE 2 YEARS I'VE HAD MY INTEX SYSTEM...
Jul 18, 2011 | Intex Automatic Salt Water System for ...
MY 97 SAFARI KEEPS RUNNING HOT I,VE PUT A NEW WATER PUMP IN 3 NEW THERMSTATS I,VE FLUSHED IT EVEN RAN IT 2 DAYS WITHOUT THERMSTAT I DONT KNOW WHAT TO DO PLEASE HELP
Has any engine light came on your dashboard at all ? IF so please take it to a Advance Auto Parts store so they can check any codes for free or at no cost to you. Have you checked to see if there is enough oil in the engine plus check to see if your transmission has enough fluids as well. Every engine runs hot because when your injectors lets gasoline into each piston chambers and compresses the fuel so when the spark plugs sparks the fuel will cause a very strong hot flame. So every car engines runs hot so does your temperature gage in your dash board shows what ? Let us know because we are not there to check it ourselves.
Jun 16, 2011 | 1997 GMC Safari
Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
Sony rear projection standby light stays on color red, has no pic or sound ? help please.
Hi,it sounds like its time to replace the lamp,especially if tv is between 2-3 yrs .Any clicking noises? if you do it could be an issue with the board that powers the lamp it's called the ballast.Your lamp is made by Philips and it last 6000-8000 hrs ,make sure you get the original, generics dont provide same quality and life time is way shorter 4000 hrs 6 mths - 1 yr.Have a blessed life!
Nov 17, 2009 | Televison & Video
How install wiring system for trailer hook up
You have to purchace a wiring kit i got mine at northern tool
a hot line has to be run from the battery the rest you follow instructions with kit took about 20 min
do not just splice into wires not enough current from relay
did  about 7 yrs ago workes fine i tow 3-4 times yr 2-3k trailer no problem
JR23
Apr 09, 2009 | 1999 Ford Explorer
Works fine in forward but will not go in reverse
Assuming that it's within 2 yrs old, you can phone Hilti re getting it fixed under warrenty. Hilti has a warranty that covers wear and tear on the tool body for 2 yrs (batteries for 1 yr) - hope you didn't already know this...
Mar 28, 2009 | Drills
Looking for an inexpensive replacement skimmer for my hot tub. Skimmer is a Waterway 510-1500. Thank you, Jim
I fully inspected the skimmer for any cracks, filled it with water and found no leaks. Since it's 10 yrs old, I chaulked it up to wear and tear. I bought some 100% Silicon, applied it around the opening on the hot tub and the back of the skimmer and reinstalled. Letting the Silicon cure for 24 hrs which will be in about 2 hours and will retest. I'm pretty sure this should take care of my problem.
Feb 20, 2009 | Waterway Complete Skimmer, Front Access,...
BroilKing Crown 20 Grill Logo
136 people viewed this question
Top BroilKing Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a BroilKing Grilling Expert? Answer questions, earn points and help others
