Question about Sharp XL-MP130 CD Shelf System
4 short flashes 1 long
Won't power up
Jazzy 1107 power chair won't move
3 flashes indicate that there is a short circuit to the left motor and battery connection. Check wiring and connections
Jun 14, 2013 | Pride Jazzy 1113 ATS Indoor Power...
BIOS Update was interrupted. Now laptop won't boot up.
basically your screwed , if the laptop is still under warranty I would return it without telling them u tried to flash the bios....ergo if they find out you will not be covered for warranty
the only other thing you may be able to try is inside of the laptop casing should be a small round battery usually wrapped in heatshrink or alike if you unplug that then unplug power source (main battery) and hold power button down for about 30 sec then replce both batteries and turn on it may reset bios to factory but is highly unlikely!!! you may need to contact the creator of the nios system!!!
Jan 25, 2013 | Intel Lenovo ThinkPad T410 2518F4U 141in...
My nokia 3110c wont switch on.
PHONE IS DEAD WON'T COME ON
If the mobile phone does not switch on, it is called a dead mobile.
It can be due to many reasons
1. Water damage
2. Fall down
3. Not used for a long time ( Mostly battery is down)
(1) Check the Battery. It should show 3.7 volts or as written on the battery.
(2) Check the Battery Connector
Check two things (a) Voltage coming or not (b) shorting
Note : If there is shorting then clean the circuit in ultrasonic cleaner (Remove display, camera, etc before putting it in ultrasonic cleaner )
Clean the circuit with a soft brush and make it dry with a hair dryer or ****er.
If the shorting doesn't go it may be due to shorting in an ic,capacitor or circuit. if shorting is in ic u can check it by attaching a battery then press the on-off switch keep the battery for 10-15 seconds. after that remove the battery and check which ic becomes hot. Reball or replace that ic. If shorting is in circuit it must be removed by ultrasonic cleaner
Note - The circuit is made of three layers. if there is shorting in the middle layer it cannot be removed
(3) Check the On/Off switch & voltage at on-off switch
Note - Connect a charger. If charging is shown on display then the problem is with the on/off switch or software problem
(4) Try flashing the mobile.
(5) If flashing cannot be done then there is hardware fault we first dry solder the Flash IC & RAM IC and check in the Software. if flashing cannot be done then we dry solder/reball/replace flash ic & RAM ic.After that dry solder/reball/replace Power IC, Network IC, Crystal, CPU :D:D
Sep 21, 2011 | Nokia 3110 Cellular Phone
No power my phone
1. Water damage
2. Fall down
Jul 18, 2011 | Cell Phones
Samsung c140 dead
1. Water damage
2. Fall down
Jul 18, 2011 | Samsung C140 Cell Phone
My Nokia E63 is not turning on, I've changed the battery, charged it with a desktop charger, on other phones it will on but on my e63, I won't just turn on. what am I to do.
1. Water damage
2. Fall down
Jul 05, 2011 | Nokia E63 Cell Phone
The cell phone LG1500 will not turn on.
1. Water damage
2. Fall down
Jun 18, 2011 | LG Cell Phones
My samsung jet will not turn on
1. Water damage
2. Fall down
Jun 15, 2011 | Samsung Jet S8000 Cell Phone
Whirlpool Dishwasher Model GU2500XTPS1 Light on soak/scour button flashes on and off. Dishwasher will not run.
there s atechsheet / troubleshooter behind you lower kickplate assy-- this was taken from there
PROBLEM: WON’T RUN AND LED ABOVE KEY(S) IS FLASHING
RAPIDLY
Stuck key(s) or shorted
circuit(s) in keypad.
See Checking Keypad Operation, page 1. Shorted circuits or
connections on the control
that read the keys .check/replace keypad
1. Unplug dishwasher or disconnect power.
2. Check/replace control
Nov 03, 2008 | Whirlpool Dishwashers
Sharp XL-MP130 CD Shelf System Logo
47 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
