S10 headlights no high beam
The LED might need new batteries.
Posted on Jan 01, 2014
I have a 1997 Chevy s10 I upgraded the headlights to h4 4656 the plug they sent with the headlights have red green and black wires and wires do I splice to the tan wire the light green wire and blue wire...
The black should be the ground, the other two are for low and high beam. Turn on lights and touch the wires to socket wires with low beam on. Then switch to high beam and touch remaining wire. Now if both are wired in and they function properly you all set to connect with crimp connectors. If not reverse the green and blue so high and low beams have the proper connection.
Dec 13, 2014 | 1997 Chevrolet S-10 Pickup
2003 S10 headlights on high beam they very dim
Check for 12V at the light bulb sockets. And make sure any grounds are clean and tight in the circuit.
Sep 02, 2014 | 2003 Chevrolet S-10
Right side headlights not working
You need to first establish that you have current to the headlight in question. With it being so flaky in how it is working I would bet that your connector is bad at the light. Grab a meter and see if you are getting your 12 volts to the connection. Cleaning it out may help you for a while.
Apr 20, 2014 | 2000 Chevrolet Blazer
99 S10 high beams work, but low beams don't.
Do you have power in and out of the dimmer switch in the low beam position ?
Feb 15, 2014 | 1999 Chevrolet S-10 Pickup
S10 1998 high beam problem
If I remember correctly, there is only one bulb on each side for the headlights. Is it possible that you actually have the highbeams set but the highbeam filament in the light is burned out so you're not actually using the highbeam?
Apr 18, 2013 | Cars & Trucks
I have a 95 chevy s10 pickup and the headlights went out, I still have high beams and running lights. What should I look for?
I would check the dimmer switch for power in both high and low beam circuits if you know for a fact the headlight bulbs are good.
Dec 20, 2012 | Cars & Trucks
I have a 1983 Chevy S10 pickup. With headlights off all gauges work normal. When you pull the headlight switch on all the panel lights except the windshield wiper switch locator light never turn on and all...
take a look at the dash ground wire located next to the right of ebrake release handle. if the bole holding the ground wire is loose, which was quite common it will cause all kinds of feed back problems, like described in the comments section to your question.
Dec 11, 2010 | 1983 Chevrolet S-10
My headlights are not working, but shows my high beams are on
Low Beam Fuse may be bad.
Low Beam relay position is bad.
Stalk that controls the high/low beams/cruise/lights is bad.
Low beam filament may be bad in both headlamps.
Mar 06, 2009 | 1999 Chevrolet S-10 Pickup
Head lights in my 84 s10
either both of your low beam headlights are burned out or you might have a bad dimmer switch. I would pull out one of the headlights and check in on your battery to see if it is burned out (you could also check for continuity of the filaments with a multi-meter if you have one). sometimes trucks with tilt columns have broken wires in the column where it flexes as you tilt the wheel (usually high mileage vehicles or ones with loose columns). good luck
Feb 12, 2009 | 1984 Chevrolet S-10
!997 Chevrolet S10 headlight problem
ya know it kinda sounds like the headlight switch that switches from high beam to low beam has a bad contact. You don't have one of those 4-beam modules that turn on all 4 lights on high beam do you? that thing screwed my whole headlight system up, I ended up throwing it in the trash.
I have the chiltons and haynes manual, I'm sure between the two we'll find a good diagram. I gotta get my youngin to open house at school, but I'll pull the books out and send you the wiring diagram.
Aug 07, 2008 | 1997 Chevrolet S-10 Pickup
Computers & Internet Logo
David Payne
David Payne
