Question about Ottavo OT3040 Audio System & Alarm Clock , FM Radio for iPhone/iPod W/
How to set alarm on Ottavo OT3040 - Ottavo OT3040 Audio System & Alarm Clock , FM Radio for iPhone/iPod W/
The alarm is set and I do not want it go off anymore and I cannot find a way to clear it
About 5,060,000 results (0.64 seconds) Search Results
    Set or cancel alarms and snooze - Android One Help
    support.google.com > Android One Help > Apps > Clock
    GoogleSet, delete, and label alarms Set new alarm or repeating alarm Open the. ... Open theClock app Clock . Touch menu More > Settings. Under "Alarms," you can ...
    How to Cancel the Android Alarm ' Chron.com
    smallbusiness.chron.com > ... > Start Up Businesses
    You can cancel your alarm after it goes off to stop that occurrence ... ... going off; turning an alarm off has to be done by managing the app's settings. ... Alternatively, you can tap "Snooze" to set the alarm to go off again after the ... Tap "Clock.".
    Setting and using the alarm - Bose
    worldwide.bose.com/...setting...alarm/page.html
    Bose CorporationLearn how to properly set and use Alarm 1 and Alarm 2 by following these ... There are two alarms indicated on the clock display as ALARM (primary) and ...
    How do I set, cancel, and delete an alarm (including settings ...
    support.lenovo.com/us/en/documents/ht101173
    Lenovo
Jan 30, 2016 | Home
How do I unhide alarms 2 and 3?
Set multiple alarms. If any alarm is active,(picture of alarm hear) appears in time display A. Press MODE repeatedly until ALARM appears, followed by ALM1. Press STOP/RESET to select Alarm to set. B. Press SET/RECALL to set alarm. HOURS digits will flash. Press +/- to change HOURS. C. Press NEXT and +/- to set MINUTES, AM or PM (if primary time display is in 12-hour format), DAILY, WKDAYS, WKENDS, or day of the week (weekly alarm). D. Press DONE to exit. E. Press +/- to set different Alarm. Set as above. F. In Alarm mode, press START/SPLIT to turn Alarm ON or OFF. TIP: Alarms apply to selected Time Zone of watch display. Backup Alarm sounds after 5 minutes if no button is pressed. Turning off any Alarm or backup will not affect other alarms. http://assets.timex.com/user_guides/W191_M131/W191_M131_NA_EN.pdf
Dec 01, 2015 | Timex Sports Ironman Triathlon 100-Lap...
How to set alarm
Install batteries. Press and HOLD down alarm button. While holding down alarm button, press hour button until hour is set, then press minute button until your time is set. release alarm button and set time will be saved. Activate alarm function, by selecting band and station, pressing alarm button, and alarm indicator appears and alarm is on. The station will play when alarm time is reached.
Sep 10, 2014 | Grundig Mini 400 AMFMSW Radio
How to set and remove alarm set
Turning on/off the alarms
To turn alarm 1 on/off, follow these steps:
  1. Turn the system off
  2. On the radio, repeatedly press the Alarm Mode button until the desired alarm mode indicator below "Alarm" is displayed. The music note indicates radio and the sound waves indicate the alarm tone. If no icons appear on the display, that means the alarm is turned off
wr_alarm_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
To turn alarm 2 on/off, follow these steps:
  2. On the radio, press and hold the Alarm Set button. "Alarm" flashes on the display
  3. While holding Alarm Set, press the Alarm Mode button once. "Alarm 2" flashes on the display
  4. Release Alarm Set, and repeatedly press Alarm Mode until the desired alarm mode indicator above "Alarm 2" is displayed. If no icons appear on the display, that means the alarm is turned off. The "Alarm 2" indicator will continue to flash on the display for 10 seconds. When the flashing stops, alarm 2 is set
wr_alarm2_set_icon_both.gif Radio and tone
Radio only
Tone only
Alarm off
Jul 20, 2014 | Bose Wave Radio
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
I do not know how to set the alarm for my Sangean RCR-1 alarm clock.
Alarm settings can be made with clock/radio on or off.
The Alarm Clock/Radio is equipped with two independent alarm
systems each of which can activate the Human Wake System Buzzer
or turn on a preselected radio station.
Using Alarm with a Preselected Radio Station:
Select desired station using + or - Tuning Button [18] or select one
of the 1-7 presets.
Set the desired volume level using Alarm Level Adjustment [9]
Select alarm system 1 or 2 by pressing the alarm button [14] or [15].
Display will blink with selected alarm
Press alarm set button [16]
Display will blink showing selected alarm hour and alarm mode
and beep
Press alarm Mode button [20] to select alarm mode
Use + or - button [18] to set alarm time hours.
Press set button [16] to set minutes using + or - button to
set minutes.
Press alarm days selections 1-7 (Sunday-Saturday) to select
alarm days.
Display will show the days on which you wish to be awoken by the
radio alarm.
Pressing alarm button 1 or 2 will confirm settings and a beep and
display indicates radio alarm is set.
Note:
If alarm days or alarm mode are not selected display will blink
all the days for a few seconds indicating the alarm is not set
and the alarm will not be activated.
If you would like to be awoken to the station you are presently
listening to press alarm button 1 or 2 for more then 2 seconds.
This allows the station you are listening to be stored into
memory. Then follow above procedures.
Using Alarm with HWS Alarm Beep:
Display will blink with selected alarm Press alarm set button [16]
and beep
set minutes
alarm days.
buzzer humane alarm
display indicates buzzer humane alarm is set.
Note:
Cancelling Alarm Setting:
Alarm functions can be cancelled:
and beep
Press alarm Mode button [20] one or two times (depending if you
were in the alarm radio or alarm buzzer mode) till display blinks.
Press alarm 1 or 2 button again to confirm alarm cancellation.
The symbol will stay on the display for about 2 seconds
and disappear.
You may also select days you wish to be or not to be woken after
pressing the Set button while display is blinking. Press 1-7
(Sunday-Saturday) of button [19] to make a selection.
This is the figure of your device and you can find which button where is:
Thanks.
gylacz
Jun 10, 2011 | Sangean RCR-1 Clock Radio
How to set an alarm on a Samsung T255G Phone?
Hi there!
You can set an alarm to alert you once, or daily at a specified time. Once set, the alarms are easy to change or turn off completely.
1. In Idle mode, press Menu > Tools > Alarms. The following options appear in the display:
• Wake-up Alarm
• Alarm 1
• Alarm 2
• Alarm 3
• Alarm 4
2. Select an Alarm. The alarm screen appears in the display containing the following options: the alarm name, the on/off setting, the time, AM/PM, alert type, alarm tone options, the alarm volume setting, days if the week to sound, snooze option and auto power on/off setting.
3. Highlight the options you wish to change, then select values for the options using the Left and Right navigation keys.
4. When you're finished entering and selecting values for the alarm, press ok. The alarm is set and the alarm icon appears in the top of the display.
Hope this helps
May 01, 2011 | Cell Phones
How do i set my alarm and when do i know it is on or off....keeps coming on and i dont know how to shut off the alarm...thank you
This clock radio features a dual alarm system, with two separate alarms that can be operated independently. The alarms can be set to wake two people at different times, or to have a main alarm and a backup. One alarm features your choice of radio stations as an alarm wake sound, while the second features a buzzer wake sound. You can set the radio alarm, the buzzer alarm, or both alarms.
Setting Radio Alarm
1. Press the "Alarm Set" Button. The display will flash and the Radio Alarm Indicator will appear. If you do not begin setting the time within ten seconds of pressing the it, the display will stop flashing andd you will need to press the "alarm Set Button again. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time. Hold a button for a few seconds to advance the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator. 3. After setting the radio alarm time, you will need to select the station to wake up to. First, press the "AM/FM" Button to select a radio frequency. Next, select a station using the "Radio Preset Buttons". Rotate the Volume Thumbwheel to set a wake sound volume level. 4. After setting the radio alarm wake time and sound, you will need to select your 7-5-2 setting. The 7-5-2 setting lets you set the alarm for a full week, weekdays only, or the weekend. Before setting the alarm, be sure that the correct date is set. 5. After you have set the radio alarm wake time, wake sound, and 7-5-2 setting, press the "Alarm Set" Button twice so that the display shows the standard, non-flashing display.
Setting Buzzer Alarm
1. Press the "Alarm Set" Button twice. The display will flash and the Buzzer Alarm Indicator will appear. 2. While the display flashes, press the "Tuning/Set" Buttons to set the wake time, as described above. 3. After setting the buzzer wake time, use the "Date/7-5-2" Button to select the buzzer. 4. After you have set the buzzer wake time and 7-5-2 setting, press the "Alarm Set" Button once so that the display shows the standard, non- flashing display.
Activating the Alarms
1. To activate the radio alarm, press the "Radio Alarm" Button so that the Radio Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 2. To activate the buzzer alarm, press the "Buzzer Alarm" Button so that the Buzzer Alarm Indicator appears on the display. As long as this indicator appears, the alarm will sound at the set time and days. 3. When the alarm sounds, press the " Off/Reset" Button to turn off the alarm while still maintaining the programmed 7-5-2 alarm settings. To turn off an alarm and cancel its 7-5-2 settings, press its "Alarm Button" so that its Alarm Indicator no longer appears on the display. 4. To activate the snooze feature, press the "Snooze/Night-Light" Bar when the alarm sounds. The alarm will shut off for approximately nine minutes before sounding again. The feature can be repeated several times during the one-hour snooze cycle. 5. If it is not turned off, the alarm will sound for an hour before stopping. As long as an Alarm Indicator appears on the display, the alarm will sound at the set time, according to the 7-5-2 settings.
Mar 23, 2011 | Timex Auto-Set Dual Alarm Digital Clock...
I cant get my second alarm to be set on the alarm sound how do i get my second alarm off of radio of cd mode
products.bose.com/pdf/customer_service/owners/og_wrcd.pdf
copy and paste the above link in your internet address bar under a new tab. It is your entire manual.
Hold down ALARM SET and press ALARM MODE. The Alarm 2 indicator flashes. You now have 10 seconds to begin setting Alarm 2. Note: The Alarm 2 indicator must be flashing while setting Alarm 2 wake up time or sound. To set Alarm 2 wake up time, hold down ALARM SET and press either TUNING button
For manual copy and paste this link in your internet address bar under a new tab:
Oct 14, 2009 | Bose Wave Radio
Lost manual for a timex t307s
Setting the Alarm 1 for AM/FM Radio
1. Press and hold the 2 Radio Alarm 1 Button. The display will flash and the Radio Alarm Indicator will appear. If
you do not begin setting the time within ten seconds of pressing the button, the display will stop flashing and you will
need to press the 2 Radio Alarm 1 Button again.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the wake time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, as shown by the PM Indicator.
3. After setting the radio alarm time, while the display is still flashing you will need to select the station. First, press the
L Mode/DST Button to select a radio frequency. Next, select a station using the M Memory Set 1-6 Buttons. For
more information on programming radio stations into memory, see the Programming Radio Station Settings section of
this manual. Rotate the O Volume Thumbwheel to set the wake sound volume.
4. After setting the radio alarm wake time and sound, you will need to select the 7-5-2 setting. The 7-5-2 setting lets you
is set, as shown in the “Auto-Set” and Manual Time and Date Settings section of the manual. While the display is still
flashing, press the 9 Date/7-5-2 Button until the desired setting is shown.
5. After you have set the radio alarm wake time, sound, and 7-5-2 setting, press the 4 Enter Button. The Radio Alarm
Indicator
will appear on the display, showing that the radio alarm has been set.
Setting Alarm 2 for Nature Sounds/Buzzer
1. Press and hold the 7 Nature Sounds/Buzzer Alarm 2 Button until the Alarm 2 settings and Sounds Alarm
Indicator appear on the display.
2. Press the 1 Reverse or 6 Forward Button to set the Alarm 2 time.
3. Use the L Mode/DST Button to select a nature sound or the buzzer to wake to. There is a choice of five sounds:
Sound #1: Ocean Surf
Sound #2: Birds
Sound #3: Brook
Sound #4: Wind Chimes
buz: Buzzer
4. See Note #4 in the Setting Alarm 1 section for instructions on setting the 7-5-2 alarm setting for Alarm 2.
5. After you have programmed the Alarm 2 settings, press the 4 Enter Button or wait ten seconds to return to the clock
display. The Sounds Alarm Indicator will appear on the display, showing that the alarm is set.
Nov 18, 2008 | Timex (T307S) Clock Radio
Ottavo OT3040 Audio System & Alarm Clock , FM Radio for iPhone/iPod W/ Logo
56 people viewed this question
Top Ottavo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Ottavo Audio Player and Recorder Expert? Answer questions, earn points and help others
