Question about Mach Speed Trio Stealth Pro Trio Stealth Pro
How do i get my sd card to work on trio stealth 10.1 tablet
Tried to put the SD card in and go to settings but it kicks me out every time
2 Suggested Answers
  • 54 Answers
SOURCE: trio stealth will not recognize I have an SD card inserted, therefore will not save documents and I'm unable to change the settings of storage to do so, says there's no SD card to store to I have trie
From what I gather you should have something like 2Gs of memory on your phone, remove the SD card and then connect the device back into whatever and then try saving again...if it all fails get to settings/ file management and change file saving location to phone memory...now for your pics try a different phone to see whether it will pull them if it does so, copy the pics to the that specific phone and then send then from there to your device, if needed. If all said above fails, try to get hold of your service provider they should have some technitians on stand by to help with device queries/ or check your owners manual.
Hope I helped.
Posted on Apr 24, 2014
How do I transfer apps and stuff to SD card on my trio stealth g5
If the tablet is running Android, in app manager click on the app you want to move and there should be a button 'move to sd card'. If it's 'greyed out', you can't move it.
May 28, 2016 | Tablets & eReaders
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
I forgot the password to my android 9.7 how do I rest it?
Factory Data Reset- Factory Data Reset can be accessed through your settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset tablet and Erase everything.
    1.Settings
    2.Backup and reset on the left hand column
    3.Factory data reset on right hand side
    4.Erase SD card (optional)
    5.Reset tablet and erase everything
What do do if forgot my password to unlock to my tablet
Dec 20, 2015 | Mach Speed Trio Stealth Pro Trio Stealth...
How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Jan 11, 2015 | Tablets & eReaders
Settings stopped
Maybe the capacity of your SD card is greater than the maximum capacity the tablet can handle. For example, you inserted a 64 GB card and the maximum capacity allowed is 32 GB. Check the tablet specs.
Nov 26, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
My trio stealth G2 refuses to recognize my SD card
Plug it up to your computer or laptop using your usb cord. DO NOT remove the SD card. Double-click My Computer and access your Trio Stealth G2 SD card that way. You should be able to see your pics if the kids did NOT do extreme damage.
Nov 18, 2014 | Mach Speed Trio Stealth G2 Tablet -...
My trio stealth 10 MST10-21 won't stay turned on
This may not be the problem, but worth checking. I ran into this the other day with my Trio Stealth pro tablet. I had left it on while unplugged and it drained the battery completely in sleep mode. It would only show the startup icon and shut right off. After a complete charge it is back to normal operation. You might try making sure the charge is full, maybe the battery has gone bad and that would also affect operation. Also try starting it up without the SD card in. If it doesn't mount properly or a file is corrupt, it may act strangely. I believe it scans the SD card first and may be trying to startup on it. Other than the above mentioned, it could still be hardware related with Ram or CPU problems. Good luck in finding the problem, tablets can be fun but frustrating sometimes.
Jul 06, 2014 | Mach Speed Trio Stealth Pro Trio Stealth...
Trio stealth will not recognize I have an SD card inserted, therefore will not save documents and I'm unable to change the settings of storage to do so, says there's no SD card to store to I have tried...
Hope I helped.
Apr 24, 2014 | Mach Speed Trio 7" Trio Stealth Pro Tablet...
Trio stealth pro 4.0 will not connect to the internet
You can try to go online on a different computer download compatible driver save to sd card then reboot your tablet . Id try a hard reboot first too see if that works
Dec 25, 2013 | Mach Speed Trio 4GB 7" Trio Stealth Pro
Mach Speed Trio Stealth Pro Trio Stealth Pro Logo
262 people viewed this question
Top Mach Speed Trio Audio Players & Recorders Experts
Paul &...
Paul &...
Will Halftowaite
Are you a Mach Speed Trio Audio Player and Recorder Expert? Answer questions, earn points and help others
