I have a set of Protocol Hi-Def Wireless Headphones. Nothing looks like a battery cover that I can take off without breaking it. Suggestions?
4 Suggested Answers
  • 864 Answers
SOURCE: Battery cover on back is stuck on. no way to get open without breaking it
Press on it with both thumbs in the depressed area and push down and toward the end.  There is a small latch behind the depressed area.  By pushing down as well as toward the end of the unit you should be able to get the latch to release and the cover will slide toward the end.
Posted on May 29, 2009
  • 3074 Answers
SOURCE: hi, I am trying to
look on the sides all four for a slot, with a small flat tip screwdriver insert and then pull the cover off
Posted on May 02, 2011
  • 117 Answers
SOURCE: I have three sets of
This web sight Has nothing to do with selling products. I would suggest contacting the manufacture of your headPhones.
Posted on Jul 14, 2011
How to connect wireless headphones to TV
The TV has to have bluetooth connection or a place to insert a bluetooth dongle, so the headphones can be paired with the tv
Feb 16, 2015 | Ematic Wireless Headphones and Transmitter
My hed set not sapprt
Headphones are a convenient way to experience audio-rich entertainment on your own terms. Headphones allow you to customize your listening level without disturbing other people in your general vicinity. Headphone cables can be a hassle, however, so many new headphone models feature a wireless connection. PCs tend to be wire jungles, so eliminating one wire from a potentially jumbled mess can be an intriguing feature of wireless headphones. Connecting wireless headphones to your PC allows you to take advantage of the benefits of listening to your movies, music or games through headphones without the struggle of the headphone cable.
Charge up or place batteries in your headphones and transmitter. Wireless headphones require power to function. Many wireless headphones come with a charger base. You need to charge your headphones before you attempt to connect them to your PC. Some wireless headphone models require batteries, which you must install before you connect the headphones to the PC. Connect the transmitter to your PC. The transmitter may connect via the PC's headphone jack or USB port. If the transmitter connects to the headphone jack, plug it in and check your headphone's user guide to verify how to synchronize the headphones to the transmitter. If the transmitter connects via USB, you will likely need to install software to use your wireless headphones. If your wireless headphones are Bluetooth-compatible, continue to the next step. Pair your headphones via Bluetooth to your PC. If your PC is not Bluetooth-equipped, you will need to install a Bluetooth USB dongle. Turn on your headphones and open the Bluetooth software on your PC. Scan for Bluetooth devices from your PC. Your headphones should appear. Select the headphones and follow any further instructions to complete the pairing process. Test the headphones. Pick out a song or a video and play it on your PC. Connect your wireless headphones and verify that you can hear the audio. Find the volume controls on your headphones and adjust them to make sure the volume changes correctly. If your headphones are not functioning properly, verify that the headphones are turned on. If the headphones are on and you do not hear anything, verify that your transmitter is functioning properly and that you have your volume turned up on your PC. Recharge your headphones when you are finished using them. To ensure that the headphones are ready anytime you need them, you must always place them on the charging base when you are finished using them. If the headphones are battery-powered, be sure that you always have spare batteries on hand. Hope this helps.
Dec 20, 2012 | Computers & Internet
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
Need earpad replacements for Optimus Pro-100 Wireless headphones
Just flip the headphone pad inside out on the Optimus Pro 100 wireless headphones.
Find the 3 screws on each headphone speaker, you have to push the existing cover back, but you'll find them. Remove the 3 screws. Be careful of the speaker wire that will be attached to the cover plate that has the ear pad on it. Also, look carefully at how the components are assembled inside the headphone, as you might disturb their setting. They are easy to return to their proper place if they move.
Gently remove the ear pad, turn it inside out and you will have a new covered ear pad. GENTLY, re-install ear pad onto speaker plate, be careful not to break the speaker wire that is attached. I found a little flat screwdriver helps to pull the edge of the pad over the plate. The ear pad is actually quite strong and can take some abuse, but don't pull the speaker wires loose.
After you have the cover back on, find the screw holes and put the 3 screws back in. Presto, a little cleanup on any loose pieces of covering from the original side and your done for another couple years or so.
Feb 26, 2010 | Audio Players & Recorders
SONY MDRIF610 Wireless infrared headphones -- I have two sets that won't work -- the Infrared units light up, but I get nothing from the headphones, which haven't been used in a long time and don't seem to...
Hi, to reach the internal battery You have to 1) gently detach the L(left) internal soft ear cover from the headphones, 2) Unscrew the 4 internal screws -- To replace the original NiCd 600mAh battery, You have to unsolder the contacts of the old battery and solder the contacts of the new one. You must buy a battery with soldering tabs, because tabs are very hard to solder well. - Yes, ONLY with this model You may use a NiMh battery, because the original charge-circuit was designed to stop after the battery is fully charged. (NOT many NiCd battery chargers have a cut-off circuit based on battery charge. they use only thermic protection cut-off) -- I've used 2800mAh NiMh to solve the problem, but I'm thinking to use the new hybrid cells battery, because they have a very small discharge rate when are not in use. -- No, You must not use LiIon or LiPo because they need a more precise charging rate and they may explode.Simply don't do that! ;-)
cheers, Rcatech
Nov 21, 2009 | Sony MDR-NC11 Consumer Headphones
Innovage Wireless Headphones and FM scan radio
There was 2 screws at the bottom of the headset just below the name of the headset. Remove those screws and u can include 2 AAA batteries there. Happy Listening!!! Rajesh
Oct 13, 2008 | Audiovox JW-120 Consumer Headphones
117 people viewed this question
 Grubhead
Grubhead
