Question about Vacuums
I have power cord ku28-220-0200d is this the right one for shark vacum sv75 14
I have a Shark navigator upright vacum NV22L 31. When I vacum the roller stops and starts spinning on and off. What could be the problem?
Well apart from it not being a Dyson? :>)
Usually two things.
The beater brush is not spinning freely due to hair and fluff at the bearing ends. Remove the brush and clean them.
Due to age, the belt has stretched or worn thin, or both. Change the belt every year.
Oct 10, 2017 | Shark Vacuums
Is there a guide to repacking Shark Rotator Powered Lift Away Vacum cleaner, Model NV750 for return shipping?
There is most likely no guide available. If you have any questions contact Shark before sending it to them. Insure it will be replaced or repaired and if it will be covered by warranty before you pay to ship it.
Jan 08, 2017 | Shark Vacuums
Shark rocket ultra light
Hello, this is Ava with Think Crucial.
Your Shark vacuum is equipped with a motor protective thermostat. If for some reason your vacuum overheats, the thermostat will automatically turn the unit off. Should this occur, you would need to restart the motor thermostat. Turn off your unit and unplug the vacuum from the power. Clean the filters and dust cup filters. Check for blockages in hose, accessories and inlet openings. Then allow the unit to cool for a minimum of 45 minutes before plugging it back and turning it on.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Oct 17, 2016 | Shark Rocket Ultra-Light Upright Vacuum...
How to change the power cord on Shark NV502
Shark is not made to repair and there are no parts available. It's disposable. Most vac shops won't touch them.
Oct 10, 2014 | Euro-Pro Shark SC-505 Handheld Steam...
Shark Navigator blowing front filter out of the vacum cleaner.
Dear sir, This is the most likely cause of this problem: Be sure that the top tabs and the bottom lock clip are not damaged. (red arrows on photos of my own unit) These hold the filter in place. If damaged you may try several layers of super glue, or oder replacement part from shark.com parts for this model. good luck.
May 19, 2014 | Shark Navigator Bagless Upright Vacuum
Vacuums Logo
27 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
