Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave heats up inside, particularly the right wall(gets really hot), but the food does not get warm
Had it running with nothing in it for 10-12 minutes, no burning smell at all and everything else works, just no heat getting to food
    Scholar:
  • 114 Answers
Someone else had the same problem as you. The solution was posted here:
http://www.fixya.com/support/t16342323-ge_profile_spacemaker_1800_xl_microwave
Posted on Dec 25, 2013
4 Suggested Answers
  • 43 Answers
SOURCE: burning odor, no heat
A burning smell along with a different sound (growl) USUALLY indicates a breakdown in the High Voltage Side. This is not a direct short (short circuit) or the line fuse would have blown shutting everything down. The High Voltage Side is made up of-- The Secondary ,or High Voltage Side of The High Voltage Transformer, A High Voltage Diode, A High Voltage Capacitor, and The Magnetron. If The High Voltage Transformer is the problem it will smell like a florescent light ballast burning, and will smell each time you turn on the MW. A HV Diode burns and opens, thus no more smell. A HV Capacitor usually does not burn nor does the Magnetron. There is no Cheap-Fix unless you can see that the HV Diode is burned into and you can get to it to replace. CAUTION: Always unplug from power before attempting to repair. NOTE: If you replace a Diode make sure it goes back in the same direction it came out. Yes there is a front and back.
Posted on Jan 26, 2008
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
fridgetech
  • 473 Answers
SOURCE: GE PRofile Spacemaker XL Microwave Oven Model# JVM1460 950 watts
Sounds like the problem is in the high voltage. Most common would be magnatron, capacitor and diode. For safety reasons this should be checked by a professional. Look in your owners manual because some high voltage parts have a longer warranty than 1 yr.
Posted on Oct 10, 2007
Wall of microwave oven is burned any way to clean it?
If it doesn't clean with dish soap, particularly where the microwaves come through the place on the right side that is plastic,then it is pooched. The microwaves will not get through to the heating area and reflect back to the magnatron. The thermal switch will open and the unit will not heat. or get hot and the food will be under cooked.
Feb 08, 2018 | Microwave Ovens
Tip
Microwaves and how they work. ­T­he microwave oven is one of the...
Caption
--> ­T­he microwave oven is one of the great inventions of the 20th century -- millions of homes in America have one. Just think about how many times you use a microwave every day:
Caption
­You're running late for work, so there's no time to fix breakfast at home. On your way to the office, you stop to gas up your car. Inside the quickie-mart, you grab a frozen breakfast burrito and pop it in the microwave on the counter. Later that day, you have to work through lunch. By 3:00 p.m., you're starving, so you grab a snack-pa­ck of microwaveable popcorn from the vending machine and pop that in the break-room microwave. That night, after a really long day at work, you're simply too tired to grill out, so you dish up last night's lasagna and heat it up in the microwave...
As you can see, microwave ovens are popular because they cook food in an amazingly short amount of time. They are also extremely efficient in their use of electricity because a microwave oven heats only the food -- and nothing else. In this article, we'll discuss the mystery behind the magic of "meals in a minute" with microwave cooking.
­A m­icrowave oven uses microwaves to heat food. Microwaves are radio waves. In the case of microwave ovens, the commonly used radio wave frequency is roughly 2,500 megahertz (2.5 gigahertz). Radio waves in this frequency range have an interesting property: they are absorbed by water, fats and sugars. When they are absorbed they are converted directly into atomic motion -- heat. Microwaves in this frequency range have another interesting property: they are not absorbed by most plastics, glass or ceramics. Metal reflects microwaves, which is why metal pans do not work well in a microwave oven.
Microwave cooking ­You often hear that microwave ovens cook food "From the inside out." What does that mean? Here's an explanation to help make sense of microwave cooking.
Let's say you want to bake a cake in a conventional oven. Normally you would bake a cake at 350 degrees F or so, but let's say you accidentally set the oven at 600 degrees instead of 350. What is going to happen is that the outside of the cake will burn before the inside even gets warm. In a conventional oven, the heat has to migrate (by conduction) from the outside of the food toward the middle. You also have dry, hot air on the outside of the food evaporating moisture. So the outside can be crispy and brown (for example, bread forms a crust) while the inside is moist.
In microwave cooking, the radio waves penetrate the food and excite water and fat molecules pretty much evenly throughout the food. No heat has to migrate toward the interior by conduction. There is heat everywhere all at once because the molecules are all excited together. There are limits, of course. Radio waves penetrate unevenly in thick pieces of food (they don't make it all the way to the middle), and there are also "hot spots" caused by wave interference, but you get the idea. The whole heating process is different because you are "exciting atoms" rather than "conducting heat."
In a microwave oven, the air in the oven is at room temperature, so there is no way to form a crust. That is why microwavable pastries sometimes come with a little sleeve made out of foil and cardboard. You put the food in the sleeve and then microwave it. The sleeve reacts to microwave energy by becoming very hot. This exterior heat lets the crust become crispy as it would in a conventional oven.
on May 07, 2010 | Microwave Ovens
Oven heats, but light, fan and turntable do not come on.
Hi Ted
many microwaves have safety mechanisms to reverse, or stop the turntable if it senses resistance to the turning. This is done both because
  1. the turntable is usually driven by a small motor with a gear reduction transmission to get more torque on the glass platter and your food, and if something resists the turning, it can damage the gear train or belt if it keeps running.
  2. if you have something with liquid in it and it hits a wall, it could tip over, possibly spilling scalding liquid all over and maybe surprising the person who opens the door.
In some cases, it'll just stop and then try again the next time you run the microwave. The banging on the case sometimes turning things back on suggests that either something in the turntable mechanism is awry, or that there is a common hot wire, ground loop, or possibly fuse for the light/fan/turntable.
the manual for the oven doesn't really say anything about this.
You can see generic intructions on looking for an internal fuse here
Panasonic Microwave NN CT552W has no power plug fuse ok Has it got thermal... . Please, in particular, make sure you unplug the oven before opening anything. This is one of those devices where defeating the interlocks and having it turn on can seriously hurt you.
With regard to the turntable, in particular, it's really easy over time for exploded spaghetti sauce, spilled cocoa, and overmelted butter to have run down into the indentation in the middle of the bottom of the oven cavity. Remove the platter. Is it clean in there? Does it look like the 'this person never flosses' picture for mechanical rotors? If so, start with some kitchen cleaner and a washcloth damp (not soaked) with hot water. Let the cloth steam /warm the area a bit, wipe it down. repeat if necessary. If there's a lot of cruft built up there, that could be keeping you on the edge of safety shut-down.
Good Luck!
D
Nov 24, 2015 | GE JE1140 Microwave Oven
Microwave gets really hot on inside, especially the right wall, but the food will not get hot at all
it seems that the right wall inside of the microwave is absorbing most of the microwave energy. If the panels are replaceable then you might want to consider having them replaced but it probably wouldn't be worth it. Maybe buying a new microwave will save you a lot of expense and grief.
Good luck
Dec 25, 2013 | GE XL1800 1100 Watts Microwave Oven
Use ifb microwave
You need to power down to 70% this will allow the inside
to heat as well.
Oct 11, 2013 | Microwave Ovens
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
Our emerson microwave will not make anything hot.put in time for something to cook it runs fine but it will not make the food hot HELP!!!!! the sides and top and bottom of microwave are warm but food is...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 14, 2010 | Emerson Microwave Ovens
Microwave Won't Heat
Check the door safety interlock switches. Be careful of the capacitor, potentially dangerous.
If the switches dont make a connection, the magnetron will not energize ... no heat
Apr 19, 2010 | Microwave Ovens
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Kenmore Microwave Won't Heat Food
The service manual is here.
Unless there's a bad connection at a magnetron terminal, I would say you have a failing magnetron.
It is part number 2B71165R and you can get it from the Pros here for $68.59 (subject to change).
For more free DIY and other help & advice, feel free to contact me via my site.
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | Microwave Ovens
GE Spacemaker JVM1640SJ Microwave Oven Logo
54 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
