Question about HP iPAQ hw6515 Pocket PC
Not able to turn on my hp ipaq hw6965
Previously i was not having a usb cable ,so i connected my ipaq with bluetooth to syncronise it with pc .But when i installed an update for windows it has gone into serial mode and diplayong on screen "SERIAL" on top of screen,then in middle  "h/p" logo yhen at bottom "G v 3.9" and not able to get out of this mode and not able to make soft or hard reset to turn it on.
plz help me its urgent
contact me at boombozu@yahoo.com
  • 490 Answers
Sir u have to contact vendors or service center coz they r having softwares to upgrade os  for pda's might be a virus has entre ur phone while upgrading windows good luck
Posted on Oct 20, 2007
Hp ipaq wont charge from usb cable. turns on for a few seconds nd loads but then turns off. it wont fully charge.
On the the IPAQ 6515 and others, there is a USB Power option that you must enable to 'slow' or 'fast' charge from USB connection.
Jan 13, 2010 | HP iPAQ HX4700 Pocket PC
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Charging indicator stays red
Hmmm...is the USB cable plugged in to a powered PC? Could be cable or battery issue. Red light means that the battery is very low on juice. Return it to where you got it from if you can't solve it on your own.
you want a repair service
Oct 16, 2008 | HP iPAQ hw6965 Smartphone
Syncronising with pc
i have a 5450 , it will recognise and find my wifi but will not connect to it . any ideas , thanks in advance
Apr 12, 2008 | HP iPAQ H5450 Pocket PC
HP IPAQ HW6965
its a relice, legacy device , that nobody used now.
well buy the spares on EBAY, there is no other way to fix the old.
for sure non standardized things like this.
it throway device, now?
why not buy a used smart phone and invest on something supported and with a futures.? why not?
Sep 24, 2017 | HP iPAQ hw6965 Smartphone
Red Light!
Hi xx
It sure does sound like a battery. If it is more than 12 months old, and regularly charged(daily) , then it will need replacement.
regards
Graeme
Mar 11, 2008 | HP iPAQ hw6965 Smartphone
Syncronisation problem
I have managed to sort it by doing a soft reset.
Sep 12, 2005 | HP iPAQ H1930 Pocket PC
Connection with my iPAQ 3660
...USB and Serial cradles and cables from... http://www.pdasmart.com/ipaqparts3600.htm http://www.amazon.com/exec/obidos/A...1&link_code=as1 http://www.bizrate.com/buy/noncat_p...--37673232.html There are probably other sites, but these are a few from a quick search... Otherwise, yes via IR if the PC your synching with has IR functionality... BT and WiFi also, but you need to establish a partnership via USB/Serial/IR first... Go to this site and download the Reference Manual, etc... http://h18000.www1.hp.com/support/f...te/48_1334.html You can get the latest version of ActiveSync from... http://www.microsoft.com/windowsmob...tivesync37.mspx __________________ "When all else fails, read the instructions..."
Sep 12, 2005 | Compaq iPAQ H3660
Sync via bluetooth
Does your USB adapter provide serial port connections ? I had the same issue with an USB adapter with a dedicated-to-phone software. I changed to MSI bluetooth adapter and then made a serial port available to COM5, then connect activesync to COM5. (make sure on the ipaq you create a shortcut "activesync connection" and pair with the bluetooth adapter.
Sep 11, 2005 | HP iPAQ hx2410 Pocket PC
Activesync via bluetooth
I have bluetooth Activesync working on my hw6515 connected to a Dell x300. Followed the instructions in the User Guide Chapter 9. Need to take note of the com port assigned to bluetooth serial port on the PC. Connection must be initiated each time from the IPAQ ie go to buetooth manager and connect the activesync shortcut.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
HP iPAQ hw6515 Pocket PC Logo
110 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
