Question about NA Essential Collection
Funai lf320fx4f resolution mismatch
In games i keep getting resolution mismatch
My Funai Tv model LF320FX4F changes channels by itself, the volume goes up by itself and the panel buttons doesn't work
wash with baby wipe the switches,they are stuck in,if you smoke near it,that will be why
Apr 23, 2017 | Funai Televison & Video
Is there update firmware for LF320FX4F Made In Oct. 2013
According to the product support page, Funai has not released any new firmware for the LF320FX4F. Go to http://funaiamerica.com/product/product.php?id=880 and click on the Downloads tab. You can also check for updates from the Support Downloads page, http://funaiamerica.com/support/download.php , by entering the TV model number.
I hope this helps.
Aug 23, 2016 | Funai 32" LED 720p 60Hz TV | LF320FX4F
Funai 32" model LF320FX4F SN DS2A1337252939. Shut off and won't come back on . Has power to the red light in front. Try turning on it blink's then I hear sound and see flash on screen and it goes off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 27, 2016 | Funai Televison & Video
How to troubleshoot Funai LF320FX4F DS1 that will not power on
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 10, 2015 | Funai Televison & Video
How do I do a firmware update after replacing the main board?
Jul 28, 2015 | Funai 32" LED 720p 60Hz TV | LF320FX4F
My Funai TV Model Number LF320FX4F Comes On Then Goes Back Off Again
suggest a tv repair shop. if they can't fix worst is they charge you 20.00 not 200.
Mar 03, 2015 | Funai Televison & Video
WHAT TO DO IF MY FUNAI LF320FX4F FLAT SCREEN ...WILL NO LONGER COME ON, AND WHERE TO FIND THE FUSES, OR ORDER A REPLACEMENT POWER SUPPLY?
Try to powercycle the tv by unplugging then pressing the power button and hold for about 1 minute. Once you have done that replug and see if it works. If not, most likely is a mainboard issue. There is a kit available for repair here that you can use that includes all of the parts so you don't have to waste time trying each one at a time. http://digipartsdirect.com/listKits.php?brand=Funai&SId=3
Nov 27, 2014 | Funai 32" LED 720p 60Hz TV | LF320FX4F
Funai lf320fx4f
it should look like
3a8058d6-5d05-4fc8-aa1e-b624777960e9.jpg on computer
Not sure on the cable depends on tv connection for hdmi and hdmi connector on P.C take a photo of each and take with you to store to avoid mistakes
this could be most likely cable
http://www.officeworks.com.au/shop/officeworks/comsol-male-male-hdmi-ultra-thin-av-cable-1-5-metres-cohdmi15st.
However mini connectors are used sometimes so matching the cable could mean looking up computer specifications on type of hdmi used and television specifications on type of hdmi interface used.
Aug 03, 2014 | Televison & Video
NA Essential Collection Logo
42 people viewed this question
Top NA Televison & Video Experts
Electro Med Services...
Are you a NA Televison and Video Expert? Answer questions, earn points and help others
