Question about Concept s +1 +2 +4 +10 Close-Up Macro Filter Set with Pouch for The Sony DCR-PC109, PC350, HC...
Tray will not open
Cassette tray at down position, no moving up, display indicate cassette eject problem.
How do I get a jvc camcorder out of safeguard mode. Error 06
Step 1 Look at the camcorder's display to identify if it is in Safeguard Mode. If its display indicates an error number of E01 to E06, your camcorder is in Safeguard Mode.
Step 2 Disconnect your camcorder from its power source and remove its battery by sliding the latch forward and sliding the battery down while pulling it away from the camera's body. Wait at least two minutes before continuing.
Step 3 Remove the camera's cassette by pressing the "Eject" button, waiting for the cassette door to open, and lifting it out of the tape bay. This step is only necessary if the camera indicates the E03 or E04 error code or it tells you to eject and reinsert the tape.
Step 4 Replace the camera's battery, power connection and cassette, and turn the camera on.
Sep 04, 2015 | JVC Video Cameras
Nakamichi DR 10 does not eject. I loaded a cassette, pressed 'Play' the cassette played 10 seconds and stopped. The display showed 'ERR'. I removed the cover, nothing immediately obvious. The cassette...
The DR1o might have a Sankyo transport and they have sense fingers that become tarnished. This needs to be serviced to make the deck work. It is possible that the deck is still in play mode which blocks the eject from taking place. Unplug the unit and open it up and rotate the worm gear with a finger and the door will eventually open up but do not force things as understand the size of motor in the unit that normally turns the worm gear.
Sep 19, 2013 | Nakamichi Audio Players & Recorders
My Sony TC WR 535 wont open doors, one cassette in deck B,lights blinked in display panel then unit shut down, not been able to turn it on since
Remove the cover after unplugging AC. Look for a plastic stop that keeps the eject button from going in farther. Move the plastic stop peice downward and the buttom will then move in all the way and tape will eject. On mine the plastic piece is white and rotates down.
Feb 18, 2012 | Sony TC-WR565RM Single Cassette Deck
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and...
I have put a new cassette in my VL-Z5 camcorder and the display says "eject the cassette". My problem is that the cassette will not eject when the cover is opened. Battery is fully charged and I've also tried it with power supply connected?
Oct 04, 2011 | Sharp VL-Z5 Mini DV Digital Camcorder
I have an Elura 90. The cassette door opens but
When ejecting the tape you must hold the eject switch down for a full second. There are two stages to the eject process just as there are with the insertion of a videocassette. Hold the button in position long enough to hear the motor mechanism start.
Oct 30, 2009 | Canon Elura 90 Mini DV Digital Camcorder
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Mar 26, 2009 | Emerson EWV401 S-VHS VCR
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Mini DV Cassette won't come out. Cassette case moves up and down but doesn't open.The display keep on saying Cassette is ejecting.I don't use it as often.
I AM HAVING THE SAME PROBLEM. HAVE NOT USED THE CAMCORDER FOR A YEAR AND A HALF. IT MECHANISM MOVES IN AND OUT BUT WILL NOT OPEN UP TO PUT A TAPE IN. VERY FRUSTRATING.
Feb 21, 2008 | Canon ZR65MC Mini DV Digital Camcorder
Cassate tape will not eject from my Canon ZR85 Mini DV Digital Camcorder
I found a temporary solution for this problem. When the tray with the cassette tape comes out remove the battery so that the tray will not go inside again. Now on top of the tray it will be written as "PRESS" just adjucent to it you can see a spring connected to the tray just press the string down wards and the tray opens and you can replace the battery. Hope this can help.
Feb 01, 2008 | Canon ZR85 Mini DV Digital Camcorder
Concept s +1 +2 +4 +10 Close-Up Macro Filter Set with Pouch for The Sony DCR-PC109, PC350, HC... Logo
102 people viewed this question
Top Concept Cameras Experts
Steve
Are you a Concept Camera Expert? Answer questions, earn points and help others
