Question about Hot Wheels Toys
Hot Wheels Car Maker error message
Heating Cycle ends with error message. Unplugging to reset triggers the cooling cycle, then when the unit is plugged in again it starts the heating cycle which once again ends in the error message.
  • 76 Answers
SOURCE: After first Ignition cycle igniter stays on too briefly to open gas valve gas.
Valid Most likely the problem with your dryer is the coils for the gas valve. Remove the access door (on the bottom right side on the front panel) and you can see the gas valve with three coils on top of it. They are coming as a kit with complete instruction. The part number for this kit is AP2669614.You can buy it here http://click.linksynergy.com/fs-bin/click?id=SrmyP8LkIos&offerid=92089.542517043&type=10&subid=
Posted on Jan 16, 2007
KOakaKO
  • 135 Answers
SOURCE: "Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Posted on Aug 04, 2007
  • 10 Answers
SOURCE: I have a ARB2205CS that is 6.5 yrs old. It stopped
Yes your compressor is coming to a stop. There was a 5yr warranty I am sure but if it's 6.5yrs now it's still beyond coverage. I would call some authorized companies familiar with these models who replace the compressors. Not all companies do. Shop around for the best price. I am sure you can do better than $700. I can usually compete that job in 1.5hrs. And the replacement is a great compressor.
Posted on Jul 01, 2009
SOURCE: Error 2-Unit will not heat or brew. Stopped in
Error message 2 is a result of the water heating element burning out. The element is replaceable, if you can find a vendor who sells the element assembly. Price of a new element may be more that a new pot though, if you're lucky enough to find a parts vendor that sells one.
Posted on Dec 31, 2009
tbirdfan1
  • 3051 Answers
SOURCE: oven door won t open after self clean cycle
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Now if this has not worked then you will have to remove the top part of the oven to get to the latch asy which means you may have to remove part of the back of the oven or the entire back piece depending on your model to be able to remove the screws that hold in the top of the oven on the back then you should be able to see the latch mechanism
Now remove it and have it tested or simply replace it ok
Hope this helps please keep me informed on how this is going i can send you a link to a site that has a video on how this is done if needed ok to help you repair this
Best regards Mike
Posted on Nov 19, 2011
My frigidaire dryer GLEQ2152ES0 runs but no heat ?
Good Morning Friend,
I understand that you are receiving an "AD" error code on your Frigidaire dryer, model# GLEQ2152ES0. I also see that your dryer is not heating. The "AD" code states that your appliance is in an auto dry cycle. I suggest resetting your dryer, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 09, 2014 | Dryers
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
Failure to start cycle
WHAT IS THE EXACT BRAND/MODEL AND NUMBER OF YOUR APPLIANCE...?
DID YOU TRY TO RESET THE UNIT, BY UNPLUGGING IT FOR A WHILE INTO THE POWER OUTLET...?
Sep 24, 2008 | Zanussi 24 in. DE6544 Built-in Dishwasher
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
No heat
Hello Patty Hanna - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Oct 08, 2012 | Frigidaire GLEQ2152ES Electric Dryer
I have a lg gromm dryer and it dosn't get hot when drying why?:
I suspect that either the heating element is malfunctioning or the control board is. Sorry but either will mean an engineer's visit ;-0(
Sorry again,
Good luck,
John C
Mar 25, 2011 | LG Washing Machines
Miller home heater -runs but clicks off and on,off and on, during heating cycle .so far it keeps coming back on to get up to selected temp but this hickup during heating cycle, what problem does this...
If the burner comes on and then after a while the burner turns off for a short time, minute or less then starts again, you might have a problem with your fan motor or a very dirty air filter. I could be going off on high limit and then resetting and working that squence of operation. Also if your unit has been worked on recently, a larger then needed nozzel could have been installed and the unit fan can not cool the heat exchanger quick enough.
Dec 14, 2009 | Heating & Cooling
Washing machine keeps stopping mid wash and coming up error (32 motor surrisc) zanussi keeps stopping and reporting E32 as a fault, how do i fix this?
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Feb 26, 2009 | Zanussi ZWF1430W Front Load Washer
Toys Logo
251 people viewed this question
Top Hot Wheels Toys Experts
ray gallant
Are you a Hot Wheels Toy Expert? Answer questions, earn points and help others
