Question about Refrigerators
Where is the water filter?
Kitchen aid model ktrc22emss02
  • Refrigerators Master
  • 842 Answers
Located in the grill under the doors. Replacement part number should be 4396701 from any part house you select to use.
Good Luck
Posted on Dec 26, 2013
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
  • 1314 Answers
SOURCE: kitchen aid refrigerator model KSRS22Q
it should be on the bottom where the kick plate is and will be a round piece that you turn and remove
Posted on Mar 03, 2008
  • 115 Answers
SOURCE: change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
Posted on Jan 05, 2009
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
What is model # or description of filter for Kitchen Aid Model ksrs25ilss
Hello, click this link to view your filter http://www.repairclinic.com/PartDetail/Water-Filter/4396508/1017291 if you have any further questions message me back and please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks again
Rick
Sep 09, 2011 | Refrigerators
Where is the water filter located on a kitchen aid superba? It is not located on the bottom or in the back.
If the model number you provided is correct, the filter is located on the bottom through the lower grill.
Aug 15, 2011 | KitchenAid Superba Architect KSCS25INSS...
Water not flowing from Kitchen Aid Refrigerator. I've switched the filter and it has not resolved the problem. the unit is one year old, was working properly. 2 days ago, water leaked from spout and that...
water maybe frozen somewhere in the system. may need to disconnect water connections at various points and retry to narrow down where freeze up is at.
Jan 06, 2010 | KitchenAid Refrigerators
Kitchen Aid dishwasher model KDC-18 is not filling with water
Under the machine is the water inlet valve. if you take off the front end of that you find a filter which fills up with rust, and you can clean it out. If that doesnt work, repairclinic.com will sell you a new valve for 32
Jun 13, 2009 | KitchenAid Dishwashers
Ice maker dosen,t work kitchen aid side by side
Please provide brand and model number of refridgerator,... The red indicator probably means you need to change the water filter.. but I am only speculating since I do not know what brand you have..
Sep 01, 2008 | Refrigerators
Kitchen aid refrigerator model KSRS22Q
Mar 03, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Refrigerators Logo
63 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
