Question about Car Audio & Video
PIONEER DH150-MP FLASHING AMP ERROR - Car Audio & Video
Pioneer pdp-ro6g media receiver flashing 8 times, any suggestions what error is or how to clear it? Thanks Jason
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Sep 29, 2015 | Pioneer Televison & Video
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
Amp error pioneer
Hi pat,
For pioneer Amp error:
It means that microprocessor has detected an abnormal DC voltage:
Speaker relay will be Off, then flash "AMP_ERR" on display.
If the AC plug is pulled off within 60 sec,
and then it is plugged in again, the unit will be reset for 60 sec.
Oct 19, 2012 | Pioneer Vsx-d811s Audio Video Multi-...
My MP-90 flashes "E O"
get series MP258 printer. According to my experience of Error P10 can be solved by replacing one or more of the following ...
Aug 16, 2011 | Office Equipment & Supplies
I have a DEH-3087 CD receiver but I cant find the manual book. Can you share the Manual Book in soft-copy ?
Keep in mind that the Pioneer DEH-3087 CD is the Indonesia's Daihatsu OEM version of Pioneer DEH-2950 MP, with screen color to match the dashboard light, no remote control, and no detachable face, and with an interface to Toyota wiring. This user guide link for Pioneer DEH-2950 MP can be used for this model: www.pioneer-latin.com/downloads/crd4138a.
Hope this helps (remember to rate this answer).
Mar 11, 2011 | Pioneer Car Audio & Video
Sir, My copier model RICOH MP 2000Le shows error . ADD TONER & some time it shows SC 302
sc 302 - charge roller current leak. strip the drum unit (dmu) and clean the unit
Sep 04, 2010 | Ricoh Aficio MP 2000 Black and White...
E5 flashing - do not want to use colour ink
use any color cartridge that is no sort & see canon error e5 solution
Jul 21, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
How do i adjust the clock on a deh 1900 mp audio
ive had a search for you and found the manual to download for your pioneer,
hope it helps you set the clock
http://www.retrevo.com/support/Pioneer-DEH-1900mp-Car-Receivers-manual/id/23227bh432/t/2/
Apr 03, 2010 | Pioneer DEH-1900MP CD Player
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
Stand by button flashes but receiver wont turn on
I have vsx-d812 that has an AMP ERR in error menu. the troubleshooting was found to be Q696 and Q697 in the DC prot. area on "C" board, up near front toward diplay in center of c board. You can get access to error codes on VSX pioneer unit by pressing "enter" and "adv. surr." simultaneously for 2 sec. The display should show what error code you are experiencing. I believe there are three diff. error codes. 1) AMP ERR 2) OVERLOAD 3) BOAD ERR (not mistyped) I hope this helps pinpoint error code for ya.
Oct 07, 2007 | Pioneer VSX-816-K/S Receiver
Car Audio & Video Logo
27 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
