Question about Zmodo 8 Ch Cctv Ir H264 Surveillance Dvr Outdoor Monitor System 500gb Hard Drive
No signal on camera 8 switched camera and still no sig.
I have a 2002 Park Avenue my turn signals do not work my flashers work
gmlogoflat.gifService Information
2002 Buick Park Avenue ' Park Avenue (VIN C) Service Manual ' Body and Accessories ' Lighting Systems ' Description and Operation ' Document ID: 643323
Turn Signal/Cornering Lamps
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.
+snpvvsvwho06+5aqhepgaaaabjru5erkjggg==
May 10, 2016 | Cars & Trucks
The fuse for a right turn signal on a 2001 Buick Park Avenue
The left an right turn signals get there power from same fuse ,HZDT/SG fuse 15amp in the left under hood fuse box. through the turn signal hazard flasher module. Here is how they work .
The HZDT/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal/hazard flasher module and have ground at G202. The turn signal lamps may only be activated with the ignition switch in the ON or ACCY position. The T/SIG fuse in the fuse block - underhood - left supplies battery positive voltage to the turn signal switch. When the turn signal switch is placed in either the left or right position, current flow is from the turn signal switch assembly to the turn signal/hazard flasher module. The turn signal/hazard flasher module then sends an on-off voltage signal to either the left or right turn signals and their instrument cluster (IPC) indicator. When the hazard switch is pressed, all the turn signal lamps will flash including both IPC turn signal indicators. The left turn signals have ground at G106, G400 and at G402. The right turn signals have ground at G105 and G400. The turn signal switch supplies battery positive voltage to the cornering lamps, the left cornering lamp has ground at G105 and the right cornering lamp has ground at G106.The turn signal switch or the turn / hazard flasher module is bad or there is a wiring problem. Go to you tube an check out a few videos on basic electrical testing ,then get a DVOM - digital volt ohm meter , an wiring diagram an trouble shoot the circuit . There may even be a video on test turn signal circuit .
Dec 04, 2015 | Buick Cars & Trucks
No turn signals. hazard lights work only when button is held in. Hazzards will not stay on. Is problem in turn sig switch or hazard light switch
If hazard switch wont stay engaged and the turn signals run through it I would replace hazard switch then retest
Apr 11, 2015 | Cars & Trucks
Turn sig. Switch does not shut off when you make a turn?
you don`t say what kind of car you have. there are turn signal cancelling lobes on the turn signal switch and sometimes they are cancelling springs that are pushed back when turning to cancel the signals. sometimes they break and require replacing, sometimes you have to replace the signal switch itself.
Sep 23, 2014 | Cars & Trucks
F-150 replacing a turning signal?
There should be a flasher unit located under the dash near the brake pedal
Jun 04, 2014 | Ford F-350 1996 Door Mirror Fits SUPER CAB...
Engine shakes after a time on chevrolet trailblaser 2007
Manifold gasket or broken hose can cause rough idle ,spark plugs leads etc.
Mar 10, 2014 | Chevrolet Trailblazer 2007 Door Mirror...
2000 tacoma flashers don't work but turn sig do work!
The hazard switch gets power from the horn fuse which is hot all the time, and from the turn signal fuse which is hot when the key switch is on. The turn signal switch gets power from the hazard switch and both use the same flasher.
So if the turn signals work but the hazard switch does not power the lights, and both fuses have power, I would say the problem is inside the hazard switch.
Feb 19, 2013 | Cars & Trucks
Turn signals come and go
if you meen come and go by nothing happens when you use turn sig lever up or down you dont get green arrow light on dash or hear sound sounds like gms multifunction switch its behind steering wheel and works wipers,turn sigs,brights and headlights on some models hazzards too thier pricey too
Aug 23, 2012 | 2002 Pontiac Grand Am
2009 Impala rear lights not working
Turn Signal Lamps
The LT T/SIG and RT T/SIG fuses located in the underhood fuse block supplies battery positive voltage to the body control module (BCM) for turn signal and hazard lamp operation. When the turn signal switch is place in either the LEFT or RIGHT position, ground from G202 is applied through the turn signal switch signal circuit to the BCM indicating the turn signal request. In response to this signal, the BCM applies a pulsating voltage to the front and rear turn signal lamps supply voltage circuits cycling the lamps ON and OFF. The BCM also sends a message via GMLAN to the instrument panel cluster (IPC) to cycle the turn signal indicator ON and OFF depending on the position of the turn signal switch.
Ground for the turn signal lamps is supplied as follows:
• G101 provides ground for the left front turn signal lamp
• G100 provides ground for the right front turn signal lamp
• G302 provides ground for the left and right rear turn signal lamps
The LT T/SIG and RT T/SIG fuses located in the underhood fuse block are also used by the body control module (BCM) for stop lamp operation.
The brake pedal position sensor is used to sense the action of the driver application of the brake pedal. The body control module (BCM) provides both, a 5-volt reference voltage and low reference to the brake pedal position sensor. The position sensor provides an analog voltage signal back to the BCM that will increase as the brake pedal is applied. When the brake pedal is applied, the BCM will then apply battery voltage to the left and right stop lamp supply voltage circuits and the center high mounted stop lamp (CHMSL) supply voltage circuit illuminating the stop lamps. At the same time the BCM signals the transmission control module (TCM) and the engine control module (ECM) that the brakes are applied. Ground for all stop lamps is provided at G302.
The stop lamps on this vehicle will not illuminate unless the ignition is in the accessory, run, or crank positions. When the ignition is in the OFF position the stop lamps will not illuminate when the brake pedal is applied.
Did you check the fuse's. ? Wouldn't think it's a ground because right an left tail lamp Assembly's use same ground ! Did you check for B+ voltage at the bulb. with a volt meter ? Power is supplied by the BCM . Could be the tail lamp assembly
Jul 19, 2017 | Cars & Trucks
I have a 1997 chev pickup...the two rear signal lights stay on with the ignition off...if i turn the signal lights on the front ones flash fast but the rear ones do not come on HELP!!!!!
pull the fuse for t.sig if the light go's out put fuse back
and locate T sig harness at base of collum and use
a test light to check for power coming out of the
switch with everything off there should be no pwr.
you will have 1 wire with a constant 12v for the
emegency flasher if you have pwr out in any others
the switch is bad. also pull the horn fuse to avoid
any false reads. hope this helps good luck
Jan 15, 2010 | 1997 Chevrolet C1500
Zmodo 8 Ch Cctv Ir H264 Surveillance Dvr Outdoor Monitor System 500gb Hard Drive Logo
35 people viewed this question
Top Zmodo Video Cameras Experts
Are you a Zmodo Video Camera Expert? Answer questions, earn points and help others
