Question about Acer Computers & Internet
CANNOT READ DATA FROM OLD INTERNAL SATA HDD I have recently been forced to buy a new laptop due to a hardward malfunction (not a software issue) and now want to retrieve the information from my old laptop?s HDD; It is a ST9808210A Seagate Momentus 4200A which I have never had any problems with previously. I purchased a SATA to USB connector and have plugged the HDD into the USB drive of my new laptop. The HDD is detected by the new laptop but does not come up on ?My Computer?; on closer inspection in Administrator Tools, Disk Management, I see that the Disk is visible as ?Disk 1? but has a black bar above it and is ?Unallocated?, on the left hand bar it is ?Unknown? and ?Not Initialized?. When right clicking on the bar the only options available to me are ?New Simple Volume? and ?Properties? ? neither of which enables the disk to work. There is also the option to ?initialise? the disk when clicking on the left hand bar, when this is tried I get the error message: ?The request could not be performed because of an I/O device error.? Any ideas please ? I really could do with getting several weeks of work off this disk!! THANKS.
  • robinson_jez May 17, 2009
    Great, I will have a go with PhotoRescue and see what results I get. I'll get back to you once I've had a go - thanks so far in the interim.
  • robinson_jez May 20, 2009
    Right I’ve continued hard to grab the data off this disk and repair it; I have used ‘TestDisk’ and while recognising the disk drive it tells us that there is No partition and it has ‘Error reading sector’; It terms of what TestDisk can see the following comes up:
    Disk/dev/sdc – 80GB/74GiB (RO) – ST980821 0A
    No partition 0 0 1 9729 80 63 156301488 [Whole Disk]
  • 221 Answers
Well, you've done most of everything that would normally be recommended. It sounds like at some point, the partition table and/or file system information on the disk has been lost or damaged. The information at the begining of the disk tells the OS where the rest of everything is, like a legend or a map. Without this information, everything is still on the disk, but getting to it could be very difficult. At this point in the game, I would recommend using a disk/data recovery tool. It's a software program that reads the drive at a bit level, then attempts to recover files, folders, and structures on the disk without the "map".
I have used and recommended PhotoRescue Expert in the past and had good luck. This is NOT guarenteed to bring your data back, but it will passively attempt to recover data from the disk without making changes to the file system, just in case we need to try a different method. There are other data recovery softwares out there, many of which work fine. PhotoRescue is inexpensive and has saved files for me and my clients many times.
http://www.datarescue.com/
Posted on May 17, 2009
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
My toshiba HDD (Model-MK3265GSX) Serial Nunmbet 40LDF2NIS KK 8 EC . A has failed. It is not readable from outside. In order to recover the data, I need another good Toshiba HDD with a serial number close...
If the drive has failed then the only option to recover data is to send it to a data recovery service but these are not cheap.
Installing another drive with a close batch/serail number will not allow you to copy from a dead drive.
I would be connecting to a regular desktop computer and trying some of the free data recovery software available such as hirens boot cd.
ANY drive within the max and type supported could be used in your laptop.
Thses are common problems with laptops and in most cases I recover data (when the drive is not too damaged) as i described above.
I then install a new and often larger drive and build the system from the recovery CD's available from the laptop manufacturer.
Then old transfer any old data I recovered back to a folder on the new drive so that customers have access to anything that was saved.
The only sure way of getting everything back from a damaged drive is to send it off but that is only of use to you if your data is mission critical.
I use the cheap USB to IDE/SATA adaptors often available from good computer shops.
Feb 15, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
I have a HP xb3000 notebook expansion base for my HP Pavilion dv9500 laptop. The problem is the laptop is having display issues (flickering screen, black screen, horizontal lines, etc). The expansion base...
as the posters said, you can move any working HDD or SSD
be it old PATA or new SATA cables, using and adaptor.
google that see 1million examples.
to any PC, and backup data.
i reading your manual online, remove the hdd, carrier.
as it tell you on page 5.7
it shows the OLD OLD PATA cable.
now most PC made have no such port now
so we buy a HDD enclosure, and it convertes, PATA to USB
and now you can plug it in to any PC mADe and use it.
#1 is old PATA, (parallel interface from dark ages of PC)#2 is power
Jun 12, 2017 | HP Xb3000 Notebook Expansion Base And...
Want to replace 80Gb HDD with a bigger one. How? Do I have to copy everything from the original one to the new one before actually replacing it? how?
Before you change the 80 GB Hard Drive you can take the backup of your hard drive to the External Hard Drive or if you have any sata case so you put your new hard Drive in the sata case and make 2-3 partitions in the new drive and copy your data in the new hard drive except in first partition which will be primary C Drive for your laptop and will replace data when you install windows in it. after the windows is installed and your data is verified in your new hard drive you can clear your old hard Drive or use it as an External Hard Drive (as you like )
2nd thing which is more safer and reliable is that you make backup CD/DVDs for your data before proceed to formatting or even changing hard drives, it will be very useful and helpful for any unforeseen data loss
if you require more assistance regarding this feel free to reply to this post
Regards, BA
Jan 14, 2011 | Acer Aspire 9300 Notebook
XP not detecting MY HDD but 7 trail and linux freeware
Method 1 : Go to BIOS and set anything with SATA disable (usually find uns=der advance setting in IDE configuration setting).Save the setting.
Windows Xp will detect your hard drive now.
Method 2 : This days BIOS comes with only few thing to configure.if that's is the case.
Download SATA driver,here is the link
http://download.cnet.com/SATA-Driver-Intel-Ver-7-0-0-1020-zip/3000-2122_4-162224.html
you need one more software called "nlite" in order to integrate the SATA driver in Windows XP CD so that it recognize SATA drives.
Here is the link for nlite download
http://home.midmaine.com/~nlite/nlite/nLite-1.4.9.1.installer.exe
On how to intergrate SATA driver with windows XP
Go to this page :
http://www.nliteos.com/guide/part1.html
Jan 12, 2010 | Toshiba Satellite A100-S8111TD Notebook
Trying to install a Samsung PATA 160GB HD in my recently bought ued Solo 5300.I see no cables etc, just some pins at the back of the HD slot. Do I need to take the whole unit apart to get at any cables?...
larry, is your motherboard PATA capable? meaning, are there 4-8 red female connectors on your motherboard?
If there is no compatibility with your PATA/IDE Motherboard, you can purchase at any local computer shops PATA-IDE converters... ranging $15USD.
This converts the PATA DATA+Power to your motherboard.
The HD you have requires Jumpers. Hence why they look like card slots on the back.
Before purchasing any cables, be sure to notice if your motherboard is PATA capable and relieve less stress on you :)
Aug 27, 2009 | Gateway Solo 5300 Notebook
Disk error accorured will not let you boot up laptop
Disk errors can occur for many reasons but typically due to age of the drive. The average life span of a hard drive is only a few years, despite the fact that we can usually get a decade or so out of them if the conditions are right.
Another possibility is that your drive had been exposed to something online that has caused data corruption. Another; moisture can significantly damage a HDD. Another yet is that excessive G forces, such as dropping the system, can also cause damage to the HDD (and other internal goodies).
The good news is that there are pro computer shops that can, in most cases, recover the data that exists on an inaccessible drive. The cost is usually between $50.00 and $100.00 USD and is well worth the cost if facing the loss of extremely important data. This can usually be accomplished within an hour.
The bad news is that you're looking at the cost of replacing the drive, reloading an operating system and setting up drivers again.
If there are errors on the disk that translate into bad sectors (areas of the drive that are physically damaged), it's still possible to reuse the drive, though I wouldn't suggest doing so. Bad sectors are a tell-tail sign that the drive is nearing the end of its life and continued use will most likely result in frustration when even more data is lost as even more sectors die.
You can attempt to recover the data yourself if you've another computer. You'll need either another laptop with an external drive port or a desktop with an external laptop drive port plugged in in order to access the drive. Just because the OS won't boot doesn't necessarily mean that the data can't be accessed.
... and someone once said that computers were going to make our lives simpler and more efficient. LOL. ;)
Note: before replacing the drive, have it removed from your laptop and installed into another to confirm that it is, indeed, lifeless. If it is, carry on with either having the data professional extracted or personall accessed via another computer. If not and it boots up on another laptop, you may have to investigate a possible IDE or SATA port malfunction (depending on how old your laptop is) or... gasp... an even more serious motherboard issue.
Jul 07, 2009 | Computers & Internet
Replacing HDD in ACER 2920Z
never use internal HDD without knowing. Use same old HDD and use external hard dsc now u brouught 320 sata use casing now
Jun 18, 2009 | Acer Aspire 3690-2900 Notebook
SATA hard disc compatibility
Actually, there are two good reasons not to swap that drive into the new laptop,
First, you never want to boot from or install software to a drive you're trying to recover as everything you do to/with the drive runs the risk of causing further damage.
Second even if it weren't for the damage, you simply aren't likely to have the right drivers unless both laptops are the exact same model.
My suggestion is just get the new laptop you want, then attach the damaged drive with the enclosure to the new laptop then run your recovery software. If that doesn't work, you will likely need the help of a Pro.
Try Armor-IT Data Recovery, they are listed in the FixYa database and service clients from all over North and South America.
Hope this helps FixYa,
Chris
May 19, 2009 | Computers & Internet
Motherboard died on my Toshiba Satellite A105 S4334
That is a tricky one. Guessing that you already have the new laptop, there is a usb adaptor that accepts SATA, IDE 3.5" and IDE 2.5" drives. You plug your drive into this adaptor, and plug the usb into your new computer. Now you can access all of the files on the old hard drive.
Mar 18, 2009 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
404 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
