Question about Nostalgia Electrics Helman Group CCP-509 Popcorn Maker
Kettle adjustment on a ccp810
The stirring rod and the motor in the top do not stay engaged? Any ideas?
My popcorn maker won't spin the kernels. I think it's the stir rod?
There are many possible problems that will cause your agitator to not spin, But you said the gear in the cabinet comes off easily, it should not.
There is a flat part of the motor shaft that extends thru the top of the cabinet that the gear should be tightened onto with an allen wrench via a set screw. This is the first place to check. When the motor is on, you should not be able to stop that cabinet gear from turning. (not easily anyway).
Oct 25, 2014 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Nostalgia Electrics Junk or What CCP810 59" VintageCollection 8oz Popcorn Machine
Your motor is stalling. Nostalgia does not support the equipment, there is no solution, or parts anywhere.
Apr 25, 2014 | Kitchen Appliances - Others
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
2000 polaris 4 wheel drive goes in and out alot doesnt stay engaged
If this is a Mechanical Actuator, then you need to find the Actuator Rod and adjust the throw to ensure it stays engaged.
Electrical Motor, you are getting a loose connection that is lacking a signal and then engages when the loose wire is causing the problem.
Feb 15, 2014 | Vehicle Parts & Accessories
How do I get the agitator rotate
The motor in the top of the machine should rotate the gear sticking out of the top of the cabinet when you turn the switch on. This gear should connect with a gear on the top of the shaft that sticks out of the kettle when the kettle is in the correct upright position and turning the stir rod.
Make sure the kettle is installed correctly, and the switch is in the on position. If the motor is not turning with the switch on, it is broken and should be returned to store if possible.
There are no repair parts for this brand popper, and they cannot be repaired.
Sep 03, 2013 | Nostalgia Electrics Helman Group CCP-510...
Do you do popcorn machine 8oz stirring rod please?
Your question has more questions than answers. You choose a Gold Medal 2408 Popcorn popper as your model, but it does not have a 60ktyz motor, the stir rod and shaft are separate from the motor, and you can't get parts for it on ebay.
What model machine do you have?
Feb 19, 2013 | Gold Medal 2408 Popcorn Maker
Popcorn maker jams up - burns kernels
Please call Nostalgia electrics at 1-920-347-9122 so we can help you get the piece you need.
Nov 25, 2008 | Bond Helman Old-Fashioned Movie Time...
Stirring rod stopped
Hey,
The stirring rod is operated by a motor on the bottom of the popcorn maker, if the rod is not moving, it means the motor is not moviing either. Most likely faulty motor, and it should be replaceable by opening the bottom of the maker. If the motor rotates but the rod doesn't move, something is cut in between the motor and the rod.
Thanks,
Ekse
Aug 07, 2008 | West Bend 82306 Stir Crazy® Popcorn...
Kettle
make sure there is no build up around contact points, sometimes you can add alittle soder to give it more better connection but you have to have some idea what your doing, good luck
Jan 21, 2008 | Hamilton Beach 40898 Cordless Electric...
Nostalgia Electrics Helman Group CCP-509 Popcorn Maker Logo
73 people viewed this question
Top Nostalgia Electrics Kitchen Appliances - Others Experts
Robert
Wayne Fellows
Wayne Fellows
Christopher Smith
Are you a Nostalgia Electrics Kitchen Appliances - Other Expert? Answer questions, earn points and help others
