Question about Gatehouse Antique Brass Left Spring Lid Support 890418
How do you install these? I put one on according to the diagram on the package and the lid will not close.
  • Jeff Stevenson
    Jeff Stevenson Jan 13, 2014
    I finally got mine to work by moving the brackets closer to the back of the box 1/2 inch and up about 1/4 inch.
  • Jeff Stevenson
    ....then i had to fill and refinish
    New Friend:
I am experiencing the same problem...I have even looked online for different installation videos....nothing doing. I need to install them asap but keep running into the same problem. I have adjusted my mount placements a number of different ways and along with suggested diagram...nothing is working.
Posted on Jan 12, 2014
Tip
How to change lid switch in a Whirlpool top load washer.
Tools needed: Phillips screwdrive, flathead screwdriver, putty knife, 3/8 inch nut driver.<br /> <br /> Every model is different. So read though. While standing in front of washer there is a phillips screw on each side of console. Some models have a screw on each side but in back of console. Some models dont have screw so you will need a putty knife to slide under console on each side an push the clips inward and lift up on console. Once you have removed the screws or the clips lift the console and allow to flip upside down and the support hindges on the back of washer. Disconnect the quick connect the clips into another quick connect Brcketed on the frame. Remove the two gold curved shaped hinges one one each side with the flathead screwdriver.Tilt cabinet back and move it away from the washer. Unerneather you will see a quick connect with wires running to the lid switch. Remove the two phillips screws that are under the lid holding the lid switch in place. Remove the 3/8 inch nut holding the ground wire next to lid switch. There are also two hindges the hold the wires inside the lip of the frame. Pull hinges towards you enough to allow the wires to come out. Install new lid switch with the two phillips screws from the old one. Reconnect the 3/8 inch grounding wire to frame. Insert the wires back inbetween the hindges to hold wires. Snap the quick connect into the frame from underneathe. It can only go on one way. Once you have the new lid swtch installed than go back in front of washer. Place the cabinet back in place. Push the lower lip of the bottominside of cabinet back under lip of frame of washer. Gently tilt the cabinet back into place. Take your hand and make sure the glide (white plastic strips ) on the back frame line up and than put the gold hinges back in place. Than do the other side. Make sure its stable. Reconnect the lid switch quick connect. Place console back into place and make sure its snug. Put screws back in place. Now standing in front of washer. Tilt washer towards you to reset the self leveling legs. Now lift the lid and start your washer in spin cycle. Close the lid and open it until the basket returns to normal stopping mode. Keep doing this it usually takes 5-10 times increase speed of basket each time ( have lid closed longer for faster speeds). When the basket breaks are reset you will hear the breaks engage and the basket slowly comes to a stop. If you see it jerking or breaking hard The break package is not reset yet keep trying to reset. Once the break package is reset and the lid switch works good than its laundry time. <br /> <br /> Future knowledge: Lid switches go out for a few different reasons. If you drop the lid and it hits the lid switch hard it can start damaging it. Wear and tear using your washer will wear them out over time. Most common is the dropping of the lid which breaks lid switch over time. Thank you for taking your time to reason this How To and I hope this helped you in your task.
on Jul 28, 2011 | Washing Machines
How to install trunk lid torsion bar on 2008 Honda Accord sedan
most torsion bars ure under the least tension when fully open and have one bar facing right and one left
insert the fixed end in the bracket then with a suitable tool twist the end of the bar down as you put it in the hinge bracket repeat for the opposite bar
It is not easy until you get the idea as to how to twist the bar as you put it in place
Mar 23, 2016 | 2008 Honda Accord
The trunk of my car doesn,t shut properly...you have to slam it really hard for it to close properly. I,ve tried W-D40 but that only helped a little. Any sugestions, 98 hona accord
Two possibilities:1) The latch part (the one installed in the chassis, not on the lid) has adjusting screws, these might have become loose, pushed down, and the lid part cant reach it when you close it. 2) The remote cable lid opener might be stuck on the open position, not allowing the lid to lock. Check the remote tab by the driver´s side for freedom of movement, and proper return to rest position.
Sep 27, 2010 | 1998 Honda Accord
The lid was lifted during the wash cycle. The washer stopped but when the lid was put down it will not restart. There is power at the plug.
This is usually caused by the lid switch. These are inexpensive and easy to replace. There are videos at www.appliancehelponline.com/servicemanual.html that will walk you thru testing and replacing this part. It may be a different model but the testing will be the same. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Apr 13, 2010 | Maytag Washing Machines
2001 Honda accord trunk latch spring fell out
It probably goes on the outside of the casing One end arond the cable to hold the latch against the cable
Jul 09, 2009 | 2001 Honda Accord
Dust compartment lid won't close
Hi Depending on the filter you have, you need to check that the filter grid has been securely locked in at the back. Check that it "snaps" down and locks into place. Then check the position of the bag. If the bag is sitting on the rising bag lock slider then the hinged slider needs to be pushed down into the bin. Usually the lid will close and lock down if you remove the hose. Try this to see if it works. Then check to see that the bag is opened out where the hose usually goes - if the mouth of the bag (and this also includes the new HyClean range with the seals already built in) looks out of angle then it has slipped upwards. This usually happens if the bag hasn't been folded out properly and can take milliseconds to put right.
Then put the hose back in and lock into place.
Has this solution been Fixya? Please rate accordingly or msg again if you need more help.
Mar 28, 2009 | Miele S4580 Luna Bagged Canister Vacuum
Lid/Top Loose
I have a Tecra M2 S630 and was able to fix my left hinge by removing it and drilling out the rivet and replacing it with a 6-32x1/4 inch machine screw and a nut. Total cost was $4 for a package of nuts and screws from Radio Shack.
Nov 30, 2007 | Toshiba Tecra M1 Notebook
Gatehouse Antique Brass Left Spring Lid Support 890418 Logo
401 people viewed this question
Top Gatehouse Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Gatehouse Hardware and Accessory Expert? Answer questions, earn points and help others
