Question about Canon iP2702 InkJet Photo Printer
Ink cartridge i have a flashing orange light on my printer and it says the ink cartridge is not being recognized and now it wont print???
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 544 Answers
I will remove both ink cartridges from the printer.
Unplug the printer from the electrical outlet and wait awhile.
Plug printer back into the outlet and reinstall the ink cartridges.
Posted on Dec 26, 2013
silly girl
  • 513 Answers
SOURCE: Canon BJC 6000 Beeps and Power Light Flashes Orange
The 6 beeps along with the orange light stands for "Re-install BJ cartridge or replace it". You might have already fixed the problem by replacing the cartridge, and you're still stuck with the error indication. Waste Error Reset 1: Power off printer 2: Hold Resume button then press and hold POWER, the beeper will sound once. 3: Hold POWER and release RESUME 4: Press RESUME twice 5: When the indicator lights steady, press RESUME three(3) times. The indicator should be orange. 6: Press Power to set data If it still doesn't go away, try cleaning the contacts the cartridge makes with the printhead. Dip the carts contacts(dipping only the contact area) in shallow hot water for a minute, then wipe dry with a cloth that doesn't shed fiber. Also clean the contacts on the printhead using a damp cloth, maybe also some alcohol. If it still doesn't go away you have to think of replacing the printhead, or chucking it. Good luck
Posted on Jun 22, 2006
SOURCE: CANON IP 1880
i need install canon ip1880.. how?
Posted on Oct 05, 2008
don_farr
  • 1018 Answers
SOURCE: cartridge problem
Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Posted on Nov 19, 2009
SOURCE: Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
Posted on Dec 03, 2009
pineworks
  • 4041 Answers
SOURCE: printer is flashing orange in equal increments.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Canon ip100 portable printer ink cradle stuck on right hand side
I had this same problem. Count the number of blinks in sequence of the error light. it will flash green and yellow, and then just straight yellow for a number of flashes, then it will flash green again and the same number of yellow flashes again. Here is the diagnostic guide.
Two flashes: Printer is out of paper. Paper does not feed
Three flashes: Paper jam
Four Flashes: The Print Head Lock Lever is not locked properly / Ink tank is not installed properly. / Ink may have run out
Five flashes: Print Head is not installed./ Print Head is defective
Eight flashes: Ink absorber is almost full
Nine flashes:No response from connected digital camera or video camcorder/Connected digital camera or video camcorder is not compatible with this printer./PictBridge compliant devices are attached to both Direct Print Port and Bluetooth Unit Connector
Eleven flashes: Automatic Print Head Alignment failed
Twelve Flashes: Low battery level
Fifteen Flashes: Ink tank cannot be recognized
Seventeen Flashes: Ink has run out
Eighteen Flashes: Printer detected ink out condition
Nineteen Flashes: A USB hub is connected
Mine had 10 Flashes and the Print Carriage, was bad. Cost almost as much as another printer so thats what I did. I did take it apart and got it unstuck, but still didn't work.
Mar 10, 2014 | Canon iP100 Portable Printer
Flashing light opposite ink symbol
Indicating cartridge faulty/exhausted, replace the cartridge..
Oct 11, 2011 | HP DeskJet F380 All-In-One Printer
My printer wont print. The ink cart went out and then was replaced but the orange light continues to flash and wont print
replace the cartridge with a new one probably the cartridge is not good or malfunctioning!If problem persists disconnect the printer from power outlet wait for 10 seconds and connect again
Jan 20, 2010 | HP DeskJet 940c InkJet Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Canon iP1800 printer,flashing orange light under the green 'on'
First off, How many times does it flash organge before it goes to green?
two: out of paper
three: paper jam
four: Ink has run out
Five: FINE cartridge cannot be found
Seven: FINE Cart. not installed in correct position
Eight: Ink absorber almost full
Count how many times it flashes. Then get back to me
Feb 05, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Canon iP2702 InkJet Photo Printer Logo
42 people viewed this question
old marine
old marine
