Question about Clarion VX401 Car Video Player
My VX-401 changes from tuner to digital tuner as it was searching for a signal
Please advise how to change from analog to digital when using an antenna. CCVG 3276 Broksonic tv. We are using buttons on TV, as we don't have the remote or instruction manual.
Firstly the antenna must be good quality, as there is no weak signal with digital. The TV must have a digital tuner or it will need a converter box. Once the antenna is connected and assuming it has a digital tuner. You simply do a full tuning operation and let the set search for channels. If there are regional options it should allow you to select the one you would like.
Apr 03, 2017 | Broksonic Televison & Video
I do not get any channel when i search even though all the connections are ok
Is this an analogue or digital tv tuner card.
If it is not a digital tv tuner card you wont get any channels.
UK has gone fully digital now and you need a digital receiver(freeview)
If it is a digital receiver you may just have a poor signal from your ariel
Jul 11, 2010 | Philips SAA7130 TV Tuner/FM Radio/Video...
Can the tuner be upgraded to get digital signals?
There is no way to directly change the internal tuner to receive digital/HD signals. I would simply purchase an external tuner unit, but be sure to get one that has at least component signal outputs and is HD. You want to be able view HD & not just digital. One of the small tuner boxes would get digital, but not HD. I personally have a Digital Stream tuner with a set I own and have been very pleased with it. The tuner has many extra features and also has an NTSC output I use for recording with a regular vcr. Shop for an HD tuner unit. You will be impressed by the kind of performance you will get from this set.
Nov 09, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Vhf is not picking up signal, no image
Well since all TV is now broadcast in High Definition that might be why you are no longer able to tune in a station. You will need the converter box.
Aug 19, 2009 | Casio Televison & Video
No digital signal search
Check your manual to see if it has 2 tuners, digital and analog. If it doesn't have a digital tuner, you will need a converter box.
Jun 02, 2009 | Vizio SV470XVT 47 in. LCD TV
I have a Hitachi 32CX38B, does it have a digital tuner?
To answer your direct question, yes it has a digital tuner. To answer your real question, NO it WILL NOT receive the new ATSC (digital) broadcast stations. The tuner itself is a digital one but works only for analog signals. The changeover in February will change the broadcast signals to a new digital format that will require a converter for your set to continue to function. Please note that the converter is only required if you receive your signal from rabbit ears or a rooftop antenna. If connected to cable or satelite, no change will be seen and no converter is needed.
Dan
Jan 28, 2009 | Hitachi Televison & Video
Digital Conversion for DFTV270A
A VERY short search on Google (first hit when using "DFTV270A digital") shows this:
Amazon.com: SANSUI DFTV270 27" Flat Digital TV with ATSC/QAM Tuner ...The DFTV270 receives digital terrestrial and cable signals without the need for an additional tuner.
People should at least make a minimal effort in looking up answers for themselves. An equivalent questions is asking if a FlexFuel can use E85 gas.
Jan 18, 2009 | Sansui Televison & Video
Does the GE 35GT740 model have a digital tuner?
As far as I know, this set DOES NOT have the required tuner capability. Please note that the changeover only effects those using rabbit ears or a rooftop antenna. If you have cable or satelite, no change will be seen. The change over is from an analog broadcast signal to a digital one. Your set has a digital tuner that expects an analog input signal.
Hope this helps,
Dan
Dec 31, 2008 | GE 35GT740 35" TV
Does my tv have a digital tuner (RCA Model E13320, 2/2001)?
The digital tuner has nothing to do with the new signal you will be receiving in February of next year. The new video signal is a digital signal. The old video signal is analog. Your television receives the analog signal and converts it to what you see on television. You need a converter box to convert the new digital signal back to an analog signal your television can convert.
Jerry
Nov 07, 2008 | Televison & Video
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
Clarion VX401 Car Video Player Logo
75 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
