Question about Oster 6058 Toaster Oven with Convection Cooking
Plug in unit and display flashes de-f then clock then back. Nothing on key pad works
My toaster oven quit working--the led display lights up just fine but no heat. I unplugged/replugged and it worked! for awhile. Then, the same thing and the plug had no effect.
take it in to an appliance repair shop as it may be the elements or thermostat control that is faulty
get a quote as the repair may be more expensive than a replacement unit
Jun 16, 2017 | Toaster Ovens
Digital display breaking up
it happens commonly with LCD we can do nothing replace the display unit
Jun 10, 2015 | Breville The Smart Oven Convection Toaster...
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
What ever setting I use Toaster, Pizza etc the oven runs for 3 minutes and stops and in the read out window E 1 comes on the screen
Unplug the unit for at least 30 seconds. Plug in, set clock. When making pizza punch in the time you wish it to run, such as "7:30" then "start". Watch carefully the first time to see how much time it takes to cook to your liking.
Sep 03, 2014 | Oster Digital Countertop Oven With...
Black & Decker toaster oven won't work
We've had many of these over the years...they seem to run along just fine, and then, one day, they quit. There is no fuse, but if it's the only thing plugged into that wall outlet, the one thing you might check is the circuit breaker on that line. To be sure, plug a lamp into the socket just to make sure you're getting electricity out of the wall.
Sorry to say, it may be time to purchase a new unit.
Sep 14, 2017 | Applica CTO6301 Toaster Oven
Unit will not turn on. No power to anything on the display. The outlet is verified working. This happened once before and a few hours later just miracled itself back to life. any idea Is there some...
An loose, intermittent power switch is the cause of that and it associated with lose wiring inside. Check it and replace lousy parts once you done that your unit will back to normal again.
I hope my idea help you.
Apr 04, 2011 | Cuisinart TOB-155 1500 Watts Toaster Oven
How do you set the clock on the delonghi DO400 toaster oven
  1. Press for 5 seconds the TEMP./SELECT/CLOCK but- ton (7) (the hours flash on the display).
  2. Press the TIME/TOAST COLOR buttons (8) to the desired time (hours). The time set will begin blinking on the display.
  3. Press the TEMP./SELECT/CLOCK but- ton (7) (the minutes flash on the display).
  4. Press the TIME/TOAST COLOR buttons (8) to the desired time (minutes). The time set will begin blinking on the display.
  5. Press the TEMP./SELECT/CLOCK but- ton (7) to confirm. It is pos- sible to press the button at any time during cooking to display the current time (the display shows the time set).
  • If you wish to change the hour on the display once it has been set, press the TEMP./SELECT/CLOCK but- ton (7) before proceeding to set the new time as described above.
  • It is possible to display the current time even after starting a function, by pressing the TEMP./SELECT/CLOCK button (7) (the time is displayed for 2 seconds).
Oct 14, 2010 | DeLonghi DO400 Toaster Oven with...
ELECTRONICS SEEM TO WORK (ON/OFF; TIMER; CLOCK; OPERATION SELECTIONS [TOAST, BAKE, ETC]) BUT ELEMENTS DO NOT LIGHT UP
check the resistance of the plug by turning the timer and temperature switch, if there's no resistance, open your unit and check the resistance of thermal fuse which is connected to line wire. it is look like resistor..if the thermal fuse is ok then check the resistance of heating element..
Sep 30, 2010 | Krups FBC2 1600 Watts Toaster Oven with...
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
May 28, 2010 | Krups FBC5 1600 Watts Toaster Oven with...
Does not heat up.
Mine worked for awhile, then started overheating. I (former appliance repairman) found that the fan needed oiled. While I was checking it with the outside covers removed, I saw that two of the connections on the top heating element were arcing and burning! This accounted for a strange smell.
Jul 06, 2009 | Toastmaster TUV48 UltraVection 1400 Watts...
Oster 6058 Toaster Oven with Convection Cooking Logo
54 people viewed this question
Top Oster Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Craig Butler
Craig Butler
Are you an Oster Toaster Oven Expert? Answer questions, earn points and help others
