Question about Clothing Accessories
Skechers wr100m How do I set the time? I see a plastic tab under the wind up knob...do I need to remove that? Help!!!
    Sergeant:
  • 302 Answers
The plastic tab is there for transportation. Pull it out and you should be able to use it normaly
Posted on Dec 26, 2013
233XLTMB GENTS TITANIUM BLACK MESH WITH DATE. Won't start, help!!
new watch , battery operation--remove the small plastic tab from under the crown wheel (knob) and push the knob in
it is used as an isolator preventing the battery from going flat before sale
Apr 15, 2017 | Black Watches
The timing knob on my dryer wouldn't turn, it would just spin without selecting a setting so I pulled the knob off and tried using pliers to turn the plastic shaft to select a setting. It worked a couple...
Both the timer and the knob is replaceable.
Locate the model number of the unit. Here's info on how to find it:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=+86673100&pathTaken=partSearch
You can get the timer and the knob from www.searspartsdirect.com or call 1-800-252-1698.
Once you have the part, remove the screws from the back of the control panel, removing the back cover. From there you should see the timer. It will either have one wiring harness or many wires attached to the timer. INSURE UNIT IS UNPLUGGED WITH NO POWER TO IT. If there is a harness, unplug the harness. The timer will be held in place either by a couple screws on the front of the control panel that is normally hidden by the knob AND/OR a screw INSIDE the control panel at the timer. There could also be a plastic tab holding the timer in place. Raise this tab and turn timer until it is free. Remove timer and put new timer in place. Fit harness onto timer.
If there are many wires attached to the old timer, I would hold the new timer in my hand and transfer the wires one-by-one to insure you get the right wires on the right terminal tab. Once wires are transferred, remove old timer and put new timer in place.
At this point. put new knob on the timer on the front of the control panel. Plug unit in, stay clear of exposed wiring, and test dryer. If it works, replace back cover and you are done.
If it doesn't work, further troubleshooting will be needed and Ill need the make and model number.
Hope this helps. Please take a minute to give a testimonial if I've help you.
Thanks, G
Aug 04, 2010 | Dryers
Removing Nikon FM2N top plate
Unscrew the rewind knob and remove a circlip under it (You may need to grind the tips of a pair of round-nose pliers for this). Remove the disk and pull the rewind shaft stop off the hub (a spring and flat plate). Remove the two screws. You'll need a special tool to remove the little stud the shaft stop was pivoting on. Take a 1/8 inch screwdriver and grind a slot in the blade. Use this tool to remove the stud, then remove the three screws from the plastic cover ring.
Do not remove the center screw from the shutter speed dial. Remove three screws from the side of the dial and pull off the grip ring.
Jul 08, 2010 | Nikon Photography
Trying to get the film removed and new film put in
to rewind the film back into the tin look underneath the camera you will see a button, press this, it will disengage the winding mechanism, looking on top of the camera to the left you see a knob. flip out the handle and start to turn this clockwise until you hear a click and the turning become a little easier. if it is hard to turn, ensure the button undeneath is still pushed in. once the film is wound back, lift this knob this should open the back door and of the camera and release the spent film can.
take your new film and take it out if its platic container. place the old film in the same container for safe keeping til it goes to processing.
place the new film into the camera on the left side with the brown tab of the film laying over the shutter window in the middle.
press in the winder knob to help hold the film container in place.
pull out the end of the film and guide it over the two wheels with teeth ensureing that the teeth fit into the perferation holes in the film.
slide the film across the camera to the roller on the oposite side. slightly wind the camera on help guide the film tab into the slot
once in the slot slowly wind the camera on ensuring that the film is running smoothly over the shutter gate.
now close the back of the camera which should click to lock.
now wind on the film until the winder leaver stops
check the ASA or IOS rating of your film from the box it came in.
and ensure this setting is correct on the setting wheel on the right.
if your camera has automatic film recognition then this is not necessary.
you are now ready to start taking pictures again.
Nov 15, 2009 | Minolta X-700 35mm SLR Camera
Trying to remove the user interface cover for a kenmore washer
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2009 | Kenmore Washing Machines
Clutch Release Problem
You will need to remove the clutch release knob and the 3 eared positioner (the clutch) under that knob. Reposition the clutch on the shaft, put the knob back on and see if you can put the screw back in the hole. If it hits something, remove the knob, remove the clutch and turn it 180 degrees. This will reposition the ears. Put the clutch back on the shaft, put the knob back on the shaft and screw the screw into the hole. Test to be sure the knob releases the hand wheel to wind the bobbin.Be sure the thread is under the thread guide when you wind the bobbin and that there is a slight tension on it.
sewman7
Jan 16, 2009 | Brother Sewing Machines
The knob on wheel stuck.
Remove the needle, and place a screwdriver or something like it under the needle bar to keep the wheel from turning.
Wrap the knob in some type of fabric to keep it from being marred.
Using channel locks or water pump pliers, grasp the knob and turn it to the left. It should come loose. Once it is loosened, try it 2 or 3 times to make sure it works as it should.
Wind the bobbin, insert a new needle and have fun again.
sewman7
Dec 29, 2008 | Necchi 3537 Mechanical Sewing Machine
'99 Hansgrohe Aktiva Family Set. All heads & controls are leaking
the temp control knobs have little plastic tabs over the hot and cold handles. To remove them take a flat blade screw driver( small with sharp head) or a small pen knife( cover drain with a wash cloth
and pop the tabs off
Take a medium size phillips screw driver and tighten the screw
Put tab back o and you are done
If they work loos again remov e tabs, screws put loctite ( You can get a small tube for m ace or hd) screw threads and tighten
Temp control knob either has same tab or has a hex type of set screw or has a large lock nut
use a channel lock pliars over nut ( protect chrome finish by putting washcloth over then put wrench over cloth
You mentioned heads I am assuming shower head you need to use an adjuatible wrench to turn the nut (at head) and a vice rip or chanel locks over washcloth around the eustaceon ( chrome pipe coming out of wall
If you have teflon tape put that on the threads of showr head and tighten
Best of luck to you!
Nov 18, 2008 | Hansgrohe Plumbing
Whirlpool ultimate care ll washer
on the back of the timer is a black plastic tab, you have to pull out on this tab in order to remove the knob. in other words you have to take apart the control panel to get to the timer just to take off the knob. :I
Jun 23, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothing Accessories Logo
131 people viewed this question
Top Clothing Accessories Experts
Da Doc
Tom Chichester
Are you a Clothing Accessory Expert? Answer questions, earn points and help others
