Question about Emerson EWL3706 37 in. LCD Television
Is there a way to hook an hdmi connection to a tv without a hdmi port
How to hook a hdmi to a Phillips flat sceen tv that's not a smart tv
Does the TV have an HDMI port on the back of the TV? Example: DVD player HDMI out to TV HDMI in. then on the TV select input and choose the HDMI port number you connected the cable to on the TV
May 11, 2017 | Televison & Video
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
I want to know how to hook up my PC to this TV as a monitor. The manual says to use HDMI 1 port and the DVI port on PC. Do i need to get adapters to make such a connection
an hdmi cable will do then hook up to hdmi port 1 and on tv select that input and it should work. of course the hdmi cable has to be hooked up to hdmi input on computer
Jul 08, 2012 | Magnavox 32MF339B 32 in. TV
Hi, I have a samsung LE40B750. It is connected
Ur tv some how causes HDMI 1 and 2 port hubs link together so changes back and fourth 1 or 2 HDMI hubs will not a difference.Ur tv have 4 HDMI hub ports wright?Tries not to used HDMI hub ports as like HDMI ports like 1,2,3,4 to as in sequences.Tries used like 1 and 4,2 and 4,3 and 1 as skips sequences might work for ur tv.Tries to hook up the PS3 system as the old format hook up same hook as PS2 format like used the PS station old RCA AV cable hook up.Then that should not causes conflict at all because now tv have two difference kind of format hook up.
Sep 05, 2011 | Samsung Televison & Video
Can I hookI hook up to TV without an HDMI cord?My TV has only one HDMI port so can I use TV as a monitor with an AV cord?
Most Acer laptops have a Blue VGA Port for external monitor hookup. Does your TV aslo have such a port (most newer models should)? If so connect these and change display settings on Laptop.
Jul 06, 2011 | Acer Computers & Internet
Hdmi Port wont work on PS3
you need to go into your console video settings and setup for hdtv to use hdmi.
May 21, 2010 | Sony Playstation 3 (PS3) Console
I have my PS3 and TV hooked up to the HDMI ports. I have programmed the unit to show them under TV and DVD respectivly. When I change the source to TV or DVD, nothing shows up on my TV as expected
Sounds like you hooked them both up to HDMI input ports. Make sure that the PS3 is connected to an HDMI input port on the AVR-1508, and that the TV is connected to an HDMI output port (not an input).
Oct 21, 2009 | Denon AVR-1508 Receiver
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Jun 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Emerson EWL3706 37 in. LCD Television Logo
15 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
