Im having trouble opening the optical drive on the Dell Inspiron 15RV
It does not have a button on it so I do not know how to open it.
    Champion:
  • 411 Answers
Right click on D: in my computer and select [eject]
Posted on Dec 29, 2013
Trouble with Dvd player in Dell Inspiron 530
Find the small pin hole on DVD player and use a straightened paper clip to manually eject in case there is a stuck disc.
Use system restore to roll back your system. Look for a restore point longer than the three days.
I don't see a correlation between the two because the system should work even you don't have an optical drive (CD\DVD).
Aug 30, 2012 | Dell Inspiron 530s Desktop Computer
How can I remove the barrier to install a second optical drive
Two things have to be done in order to add a second optical drive.
1. Open case, remove front cover of case.
2. Remove blank from lower optical drive from front of case - remove blank (chassis part) from optical drive space.
The black insert that can be seen, removes from back on this model.
The 'steel' part on the chassis should pop out fairly easily.
Jan 19, 2012 | Dell Inspiron 620 MT Desktop Computer...
We have a disk stuch in a dell inspiron 1318, there is no OS on it right now. how can we get disk out? there is no place to stick the paper clip
Remove the optical drive, and then open the drive. Remove the disk.
With most laptops this is a simple job.
Turn the laptop over on it's top, remove one Philips head screw, pull the optical drive out.
Remove 2 to 4 screws from a cover on the optical drive, and ease the tray open.
With the Inspiron 1318 Notebook PC it is more difficult.
A) Remove the Display Assembly.
(Removal covers removing the Display Assembly as a whole unit, off of the laptop)
B) Remove the Keyboard.
C) Remove the Palm Rest. (Top cover under the Keyboard. Your palms rest on it when you use the touchpad)
D) Remove the Optical Drive
Dell Support > Dell Inspiron 1318 Service Manual,
http://support.dell.com/support/edocs/systems/ins1318/en/sm/index.htm
In the list click on Optical Drive.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 16, 2011 | Dell Inspiron 1318 Notebook
Got Dell Inspiron 2650 2002 from a friend, free. Want to restore to factory settings. How? Installed Windows XP and Norton Anti Virus
Hi and welcome to fixya!
There are two ways to restore this machine to factory settings;
First is thru the Recovdery partition in the hard disk itself:
  • 1 Close any windows currently open and click the Inspiron's "Start" button. Select "Shut Down" and choose the "Restart" option.
  • 2 Tap "F8" when the Dell image appears on the screen. Continue tapping the key until the advanced boot menu loads.
  • 3 Scroll down to "Repair Your Computer" and press "Enter" to access the DataSafe local backup screen. Click "Next." Select "Dell Factory Image Recovery and DataSafe options."
  • 4 Click the "Restore without preserving new or changed files" radio button and click "Next." Click "Next" three more times and click "Restart" to restore the disk drive to its original condition. Follow the on-screen prompts to set your operating system settings.
If the hdd was already repartitioned or corrupted, the second option should work:
  • 1 Insert the Dell recovery disk in your Inspiron's optical drive and close the "AutoPlay" window when it appears. Shut down any other open programs. Click "Start" and select "Restart."
  • 2 Tap "F2" as soon as the Dell image appears on the laptop's screen. Scroll to the "CD-ROM" option and press "Enter." Tap any key when you see the "Press any key to boot" option.
  • 3 Press "Enter" when the setup screen appears. Press "F8" and highlight the Dell's hard drive partition. Press "Enter."
  • 4 Follow the instructions on the screen to choose the Inspiron's operating system options. Click "Finish" and remove the recovery disk from the optical drive. Click "Start" and select "Restart."
Hope this helps!
Takasashi
Jul 19, 2011 | Dell Inspiron 2650 Notebook
Eject stuck disk in Dell inspiron 1318 notebook
Take a Norwegian paper-clip, and straighten one end.
Gently push that end into the small hole in the face-plate of the optical drive.
When you feel resistance, firmly push another 5 mm (1/5 inch).
This should "unlock" the tray.
Press the open/close button, and the tray should fully open.
Feb 19, 2011 | Dell Inspiron 1318 Notebook
Hi i have laptop dell"inspiron 2200 when i swithed it on the laptop so it will get open and get stop than start making noise like tooooooooooooooo
Back up your data on an external drive now! It could be the optical drive or the fan but it is most likely the hard drive. If it is the hard drive making that noise, it is about to die. Saving a hard drive is unlikely. You can replace it but you cannot replace your data. Save your data now!
May 01, 2010 | Dell Inspiron 2200 Notebook
How do I put my new dvd rewritable driver in my dell laptop 1501
All of the below is from your Inspiron 1501 Manual, which if you do not have a copy, you can obtain
a PDF document Here
You will find all below under Adding and Replacing Parts--Optical Drive
Optical Drive
CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the
ProductInformation Guide.
Turn the computer off.
Turn the computer over and remove the optical-drive locking screw.
Insert a scribe into the notch and push it to the side to release the drive from the bay.
Slide the drive out of the bay.
Apr 10, 2009 | Dell Inspiron 1501 Laptop
Optical Drive
no known bug maybe a programming problem perhaps they can fix it for free no problem asking dell.com
Apr 05, 2008 | Dell Inspiron 6400 Notebook
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
