Question about Boating
Repair diagrams john deere 1032 snow thower auger&worm gear
The worm gear shaft has about 1/2 inch play is this a normal movement or or not
    Top Expert:
  • 43,095 Answers
I would guess not normal.
Posted on Jul 07, 2014
Model 1130 se. Why does it have less power?
If 1130 is A Lawn tractor, your belt is slipping
Jan 12, 2016 | John Deere Garden
Auger replacement
Here is a manual for your snowblower. Yes, It's the same. http://download.sears.com/own/spin_prod_674132601.pdf . Go to page 30, it a parts diagram of the blower and housing.
You will need to remove the pulley #66 from the back of the unit, the bearing retainer #1, and the auger bearing bolts #18. The whole unit will then slide out of the housing. You can then remove the augers and then take the worm gear apart. That will get you to the auger shaft.
Mar 24, 2014 | Agri-Fab Agri - Fab Snow Blower - 42"
TRS21 cloggs in the chute
I have the exact same problem. Also it won't clog so easily if the snow is deeper because the auger moves more snow through (or if I run with it.) It seems to me that the auger should be as close as possible to the scraper bar without causing any friction. Do you think that distance adjustable, or would new paddles on the auger close the gap sufficiently?
Dec 26, 2012 | John Deere Trs21 Rubber Auger Paddle Set...
John Deere G049K Snow Thrower Service Repair
An older snowthrower will make some noise, but it depends on what kind of noise you are hearing. A "growl" is not common and can indicate the gearbox is low of oil or the oil needs to be changed. The gearbox is mounted on the back of the snowthrower and there will be a dipstick on top. There should be oil on the dipstick, and it should be kind of thick. Proper gear lube is 80-90, and should be a gold color. Also check to make sure the auger bearings are not going bad. You can grab ahold of the auger while the machine is off and try to wiggle it. If it moves at all the bearings will have to be replaced. Start there and let me know if you need anything else, Daniel.
Oct 25, 2011 | John Deere 420,1020,2010,2020,2510,2520...
I have trs22 john deere snowblower the the impeller turns but the auger does not turn . i think the key is sheard off in the augers transfer case . any one have a detailed diagram or a pdf file for the...
Go to weingartz web page and you will find the diagram and parts you need. I have a TRS22 with the same problem. You will need a worm gear, gasket/gear case, and a shaft key. I need to order the same parts. take appart the auger first you might need more parts
Jan 22, 2011 | John Deere Garden
I have an Ariens 926LE snowblower. The blower spins but the auger spins slowly. It barely throws snow. Some times the auger stops spinning. Shear pins are fine.
Hi, The blower spins at full speed? If it does the belt, pulley, and shaft are good. Look at the shaft from the fan to the gear box while it's running and that shaft should be turning at the speed of the fan.
If the blower spins at full speed and the auger doesn't the most likely problem is the worm gear transmission from the blower shaft to the auger shaft.
A good way to visually inspect this is: With the machine turned off and the spark plug wire unhooked go to the front and try to rotate the auger by hand. If the gear box is good you will only be able to move the auger less than an inch. If the box is bad you will be able to move the auger a lot farther. While you are there recheck your shear pins.
You can also remove the blower drive belt and have someone turn the pulley by hand while you watch the auger. Put resistance on the auger with your gloved hand. If the box is good the auger will move smoothly in you hand. If it is bad, it will ****, move roughly, or stop.
While the other person is turning the pulley and you have some resistance on the auger look closely at the shaft running from the gearbox back to the blower. On some models there is a connecting sleeve and the roll pin that connects the sleeve to the shaft and gearbox will break.
If the gearbox is bad, it will have to be replaced as a complete unit.
Was this helpful? If you have any other questions, please ask.
Jan 10, 2011 | Garden
What would cause my John Deere Sabre 25hp 54"cut to be hard to steer ?
Your tractor has a simple worm gear turning another worm gear system.Either the one of the spindles in the front wheels is sticking or the worm gear is not meshing or you need to replace the worm gear on the steering shaft it's self.Also,if the tie rods are not set right then the wheels may turn hard,set the tie rods so that they have 1 to 1 and 3/4 inches of tow in in the front wheels.
Sep 12, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ever hear of a PTO running in reverse? I have my 42 inch snow thrower attched at this time and for whatever reason, it is turning the auger for an under-throw. This is on a JD 285 lawn tractor.
Is your blower running off of a belt or a pto shaft?If it is running off of a belt then you likely have a twist in the belt that shouldn't be there ,have a look at it to see if it crosses it's self somewhere.If it has a shaft then the drop box needs to come off and the gear arrangement checked out.
Jan 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Ariens snowblower auger wont turn
Just finished repairing my ariens, 6 years old with aluminum gear box. Same problem encountered. The problem turns out to be the BRONZE gear driven by the worm shaft. Shear bolts did not shear and bronze gear broke about 5-6 teeth. This is why you can move the auger a half turn or so, there are no gears in one area of the gear and as the gear turns to engage the worm drive it will stop. The fix: the cast iron replacement from ariens! About $200 including shipping, got mine from Jack's Small Engine (MD). Fairly easy repair if you are mechanically inclined. Buy yourself a set of roll pin extractors ($20 from Sears), new roll pins, new woodruff key for shaft. You will also probably have to press 2nd stage impeller from shaft with hydraulic press & heat (took mine to my local auto garage). What stinks is ariens seemed to have admitted the design problem with the aluminum gearbox, yet won't help with repair cost! Anyways, I learned a lot about my snowblower for future repair (belt replacement)!
Dec 21, 2008 | Garden
Boating Logo
53 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
