Question about AOpen Power Supply: ATX-300GU (PS4300GU) Power Supply
ATX-300GU PSU: 32V around Q4/Q5 circuit
I have an A Open ATX-300GU power supply. I have had it for about 7/8 years. Recently my computer did not switch on and I found the problematic source to be this PSU. The two 1k resistors around Q4 & Q5 got burned. I used a multimeter and saw that there is 32V on one side of the resistors, when on a working PSU it reads about 11V. What could be the fault? Where can I look to see which component/s need replacement?
Thank you
  • 42 Answers
Could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
Posted on May 17, 2009
Compaq Presario SR2010NX power supply
if it is your power suply that is bad its very easy. all you have to do is get a replacment oem powersuply i would go with this one http://www.atxpowersupplies.com/300-watt-power-supply-fsp-atx-300-gu.php?psu=ATX-300GU-SR2010NX,. you then will want to make sure the computer is powered down. once you get it powered down i would strongly suggest wearing a anti static strap can buy at any computer repair store. you then want to look at end of connectors and will be labeled. u then want to label the ends as you unplug them. all you have to do is label the new ones. once you get old power supplies cables labeled. you can unhook the four mounting screws on the back that hold power suply to case. then all you have to do is hook up new power surly as you labeled old one and can just match up the plugs. then all you have to do is mount to computer. once you mount it go ahead and power up.
Jan 06, 2011 | HP Compaq Presario SR2010NX PC Desktop
ATX-300-12Z was hit with a power surge (thought we had a surge protector). Green light on power supply blinking at 2X/second. No power at USB devices (or anywhere else.) PC was on when surge hit.
There were 2 Switching power supply circuit inside the ATX PSU. There's a Standy PWM circuit whichSupply +5V to the PWM IC of the Main PWM. Stand by pwm still working or insufficient voltage, lower than +5V. This is the reason you still have Green light. Check or replaced small filter capacitor around 100 MFD 16V, open resistor or shorted diode that was nearest of the PWM IC..
Watch out for charge voltage on big capacitors.
Rleo
Dec 30, 2010 | HP ATX-300-12Z (ATX30012ZBD) 300-Watt...
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Hp pavilion a430n power supply is blinking
Look at this photo
(http://www.atxpowersupplies.com/images/300-watt-atx-power-supply-FSP-ATX-300GU-350w.gif)
Did you connect the p4 atx 12vx1 plug?
You may also need to connect the aux x1 plug on some models.
Mar 08, 2010 | HP Pavilion a430n PC Desktop
The PSU bestec atx-250-12e is dead, there is an easy fix for it
You can find the same psu at ebay with free shipping.
http://itemlistings.ebay.com/sdcsrp?fl=360131455504&product=bestec+atx-250-12e&sconstraints=PriceMin.Value%3D23.00%26PriceMax.Value%3D45.59
Aug 20, 2009 | Gateway Emachine Bestec ATX-250-12E PS...
Broken Power Supply
hello!
I guess that the computer have a one year warranty, You can claim a warranty anytime you want. But if has no warranty at all then you can repair the PSU by your own, Open the PSU and find any busted parts or maybe the fuse blownout that is very cheap you can replace that by your own. If afraid to do so, then let the repairman do it for you.
If no hastle it is recommended to by new PSU for your system.
Hope this help, best regards, melnavz
Feb 21, 2008 | Computers & Internet
PSU
You can try to rearrange from ATX form to dell form.
Here is ATX arangement
http://en.wikipedia.org/wiki/Computer_power_supply#Wiring_diagrams
and here is dells arangement
http://www.jdresearch.com/icon/shark20pin.jpg
Jan 31, 2008 | Computers & Internet
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Jan 06, 2008 | Gateway Media Center 610XL PC Desktop
AOpen Power Supply: ATX-300GU (PS4300GU) Power Supply Logo
185 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
Matthew Spark
Matthew Spark
David
David
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
