Question about LG Heating & Cooling
My lg air conditioner power and timer light blinks 2 time on each light (power 2 times and timer 2 times) I have no idea what this means. I know its an error code. But is it serious ?
  • 4 more comments
  • Yusuf Issadeen
    Yusuf Issadeen Dec 25, 2013
    It doesn't even turn on !! The lights just blink. I've resetted the remote, Pulled the plug out for 5 mins even.
  • Yusuf Issadeen
  • Yusuf Issadeen
    I do not know much on the whole wiring section. So please simplify. AM I IN TROUBLE? WHAT DO I NEED TO DO.
  • Yusuf Issadeen
  • Yusuf Issadeen
  • Yusuf Issadeen
    we had a couple of power outages in a small span of minutes. I know that definitely has something todo with that
  • 960 Answers
It appears to be an error 22. According to the LG bible, it means an overcurrent protection has activated. In most cases, unplug the machine or switch off from power supply for at least 15 minutes, it should reset the main control board. If this doesn't work , it may have damaged the board. Alternatively, if your machine is on 3 phase, check that all fuses / circuit breakers in your meter box are OK and switched on. You may have a weak or disconnected power supply.
Posted on Dec 26, 2013
dgjtex
  • 405 Answers
SOURCE: C4 error code on LG artcool airconditioner
www.yx2.fi/LG/wall_and_art_cool_error_codes_2007.pdf
Please read this article, I think it will help you solve your problem
Posted on Jan 14, 2009
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
SOURCE: Carrier Air V roof mount with remote. Does not
We have the same problem as of this morning . . . don't have the fix yet, but have located (2) manuals that I will enclose the links for. The 5 flashing green lights is mentioned in the "Service Manual" in Section 2 "Troubleshooting" with 5 possible remedies. Manual http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298.pdf and Parts List http://www.transportaircon.carrier.com/Files/Bus/Local/US-en/T298PL.pdf We're under warranty so will take our RV in ASAP
Posted on Sep 05, 2009
hvac1960
  • 2133 Answers
SOURCE: LG air condotioner with a CH5 error code
CH-05-Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 01, 2011
hvac1960
  • 2133 Answers
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Posted on Jan 03, 2011
Fujitsu asta24 Lcc timer light flashing all the time even when off no cool air coming thru
A continuous blinking timer light is a "model error" meaning the indoor and outdoor unit is mismatched. If the timer light flashes a number of times, pauses, then repeats, count the number of flashes and then you can work out the error code.
Nov 17, 2016 | Fujitsu Heating & Cooling
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
May 29, 2016 | Mitsubishi Heating & Cooling
LG aircon flashes blinking 8 times and the shifts to timer led flashes blinking light 4 times
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem.Air Bulance AC Cleaning Repair Services
Apr 23, 2014 | LG Heating & Cooling
LG aircon operation flashes blinking light 8 times and then shifts to timer light flashes blinking light 4 times
Sounds like a 48 code. (There is no 84 to my knowledge).
Outdoor unit coil outlet (liquid line) thermistor has disconnected or has shorted out.
call a LICENSED hvac repairman
Apr 21, 2014 | LG LS-L1210CL Mini Split Air Conditioner
Power light blinking And no cold air coming out
most units have a diagnostic plate on door or manual that will tell you what blinks mean. steady blink is normal on some units.
Jan 20, 2014 | Heating & Cooling
LG air conditioner blinking red power light
This is not a split system a/c unit guys. Look at the picture. The blinking light means the air filter may need cleaning. Reset power to turn it off.
Jul 25, 2012 | LG 8000 BTU Air Conditioner w/Remote
AIR CONDITIONER LG S18AN
The operating LED will be blinking 5 times, means that there is a
comunication error (serial comunication) between the outdoor and the indoor unit.
Dec 28, 2008 | LG LS-K1830CL Cool Mini Split Air...
Looking for LED flashing light Error codes for FUjitsu AC
communications error
try resetting the breaker
this should clear the eprom
Dec 13, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
360 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
