Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
How to change over to lp gas on a kenmore model 79074239310
    Sergeant:
  • 259 Answers
There is an item called a regulator, it is not the one that is just out of the tank. This one you can purchase it is only about 2-3 " in size and you install it where your propane line connects to your stove, at the end of your yellow or some times stainless steel line. Once installed all you do is flip the little cap on top of the regulator to the desired position Nat. or L.P. which means for natural gas use or liquid petroleum (propane). It allows you to use your stove with either one with just the flip of the cap on the regulator. They cost anywhere from $40 to $60. It is fast and easy, you can do it yourself. When you are done make sure you check for leaks before you use it. It is always a good idea to consult with a professional. Hope this helps and good luck.
Posted on Jan 04, 2014
How do I convert a kenmore gas range model 790 back to natural gas from lp?
You don't need to change the regulator, just the orifices.
Sep 09, 2015 | Kenmore Kitchen Ranges
Conversion of Kenmore Elite Gas Range 790.7523 from Natural gas to propane.
each burner has a natural gas jet or (orifice) as you pull them out, one atb a time. You should be able to color coordinate them at that point. the jets will be at the end of each gas line right before the burner. and each burner gets one. I haven't seen the model you are referring to. but the ones i have changed out in the past, usually the hole is the same size for all the burners no matter the size of the burners. I hope this helps. good luck with it!
Jun 17, 2015 | Kenmore Kitchen Ranges
How do I change my gas range from lp to natural gas Kenmore model 790.71513405
call sears service to come do it . I will not recommend a person do anything with GAS OR VEHICLE BRAKES .
Feb 25, 2015 | Kenmore Kitchen Ranges
Changed maxitrol regulator to lp to much pressure
If you only changed the gas regulator for use with LP (the regulator located at the connection of the gas service) then you still need to change the orifices for all burners, top and oven. Of course I assume this model can be converted for use with LP. Some models cannot. A new range that can be converted for LP typically includes the needed LP orifices. A card with the LP orifices is typically located at the gas regulator.
May 31, 2014 | Kenmore 72132 / 72134 Gas Kitchen Range
Convert maxitrol regulator#rv47cl natural to propane gas
Some gas ranges cannot be converted. If your model can be converted it normally requires flipping over the regulator diaphragm and also changing orifices for all burners, surface and oven. Most modern new appliances come with the LP orifices located on a card attached to the regulator.
Nov 18, 2013 | Kenmore 72132 / 72134 Gas Kitchen Range
I have a Sears Kenmore Elite 790 hooked up to propane .. is it ok to have it hooked up to propane or is this over for natural gas only?
Kenmore Gas ranges can be used with Natural gas or Lp. They come from the factory set up for Natural gas so if you want to use Lp it needs to be converted by you or your gas company. There are several adjustments that have to be made and some ranges require orifices to be changed. Your installation manual tells how to convert it but if you're not sure about doing it you would be better off the call the gas man.
Aug 28, 2011 | Ovens
How to change orfisis from lp gas to natural gas?
If the conversion was made after in was installed by a pro or amateur, they should have left the Natural gas orifice in the dryer. If not you will have to buy a new on for your model. They come with instructions.
Aug 28, 2010 | Kenmore 74602 Gas Dryer
How do I change the orifice on my kenmore dryer from natural to a LP orifice?
More and more, you have to change the gas valve AND the orifice due to the liability issue of changing only the orifice and not doing a complete conversion. If, and this might be a big if, a conversion kit is available, you will need the model # of your dryer to order it. The kit will come with a spring and a tension nut for the gas valve and the orifice you need. Instructions will come with the kit. Follow them to the letter. An improperly installed conversion kit, or just changing the orifice, can be very dangerous. LP operates at a higher pressure than the natural gas the dryer was built to use, and an improper conversion presents a significant fire hazard.
Mar 02, 2010 | Kenmore Dryers
Change Natural Gas Model of rinnai Heater to LP model
You can change the dip switches, but you may also need to work on the gas valve
Nov 12, 2008 | Hotpoint RGB528 Gas Kitchen Range
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
94 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
