Question about Uniden Bearcat BC345CRS Base Scanner
How to program a Uniden BC345CRS base scanner
Unable to program my Uniden BC345CRS Base scanner. I can't get the frequencies correctly into the correct bank;aircraft,fire,ham radio or FM / AM.
  • Anonymous Mar 28, 2014
    How to program
I recently purchased a Uniden bc345crs scanner. I programed 5 codes, but it will only scan one of the codes continuously. What do I need to do to have it scan the other programs? Thanks
Make sure you do have frequencys stored. Turn it on, push button to clock, then press bitton to scanner, then press hold, then the channel # you want it in, press hold again, now press e, enter frequency, press e again, if you want more channels press up, press e. Do this until channels are full or what you want. Then press scan if radio is ok it should scan.
Jan 24, 2015 | Uniden Radio Communications
How do you program a Uniden Bearcat bc244CLT?
To program a known frequency into your scanner:
- With power ON, press MANUAL to stop scanning.
- Enter the number of the channel that you wish to program (01 - 30).
- Press MANUAL.
- Enter the frequency, including decimal point (for example, 156.065).
- Press E to enter/store the frequency into memory.
- Press MANUAL to advance to the next channel for programming.
For more information, you can download/print the manual for your scanner here:
http://www.uniden.com/pdf/BC244CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B
Apr 24, 2010 | Uniden BC244CLT Base Scanner
How do you progam a uniden bc350a scanner
If you know the frequency, push the program button,use channel up-down till you see the frequency you want, you may have to flip the switch in the back. You can get frequency,s at RadioFreq.com .....hope this helps...
Mar 14, 2010 | Uniden BC350C Base Scanner
How do you manually program a Uniden BC355C?
Turn on the radio
Press the "band" button
Keep pressing the "band" button until you come within the parameters of the frequency that you want
Let the radio scan until it gets close to the actual frequency that you're looking for
Press the "hold" button and use the arrow "up" or "down" button till you lock in the correct frequency
Once you have the frequency locked in, press the "program" button
Press the "private" button
The unused channel will be flashing
Press the "program" button, this locks the frequency into that channel
Continue this process until all of the frequencies are loaded into the radio
Feb 22, 2010 | Uniden BC350C Base Scanner
Unable to program trunking after uniden download was completed
I would try redownloading and reflashing the firmware on the scanner. If this doesn't work, you may want to try downgrading to the previous version of the firmware. If you are unable to redownload the firmware from Uniden, there is a Yahoogroup dedicated to this radio.
http://groups.yahoo.com/group/BCD996T/join
Also in the files section, there are older versions of the firmware.
Hope this helps!
Feb 10, 2010 | Uniden BCD996T Base Scanner
How do i clear all channels and start over putting in new ones
There is no global clear/erase function on the BC350C, but programming a new frequency on a channel automatically deletes/erases the old frequency. To delete an inactive or troublesome frequency, program "000.0" in that channel. Doing so will deleted the previously programmed frequency and set the LOCKOUT to ON for that channel. For more information on deleting frequencies, see page 27 of your operating manual.
Need the manual? You can download it here:
http://www.uniden.com/pdf/BC350Com.pdf
Sep 13, 2009 | Uniden BC350C Base Scanner
How to program and delete uniden bearcat scanner 210 XWneed to c
I can't locate information specific to the 210XW, but hopefully this generic Bearcat programming info will help:
1. Press the MANUAL key to advance to the channel that you wish to reprogram.
2. Enter the new frequency, including decimal point.
3. Press the ENTER or E key.
4. Start over with step one to continue programming channels.
Jul 31, 2009 | Uniden BCT8 Base Scanner
Programing
Here is a pdf format copy of the BC278CLT manual
http://www.uniden.com/pdf/BC278CLTom.pdf
Page 12 to program scanner frequencies.
Rollin CBs
Dean
Sep 30, 2007 | Uniden BC278CLT Base Scanner
Uniden Bearcat BC345CRS Base Scanner Logo
441 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
