Question about GE Dishwashers
Dead GE control panel Profile pdwt480P00SS
Control panel has no lights on. I have reset the power and still unable to get any of the lights to turn on. When door is close there is a short beep sound.
SOURCE: GE Max dishwasher no lights on panel
I reset the breaker and still doesn't work. Any suggestions?
Posted on Jun 22, 2008
  • 43 Answers
SOURCE: GE profile PDW9880J00SS dishwasher just beeps
appears control is going bad,or problem with control circut
Posted on Oct 16, 2009
  • 18 Answers
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
Posted on Nov 21, 2009
joe_lishman
  • 192 Answers
SOURCE: GE Dishwasher no water upon start, humming, blinking lights
Seems like the anti flood is activated when water (even a small amount) appears on the bottom of the machiene. This is usualy a leaking pipe but can also be caused by a clogged pipe. Most machiens do have a plastic pipe that (from the flat water tank) feeds water to the bottom of the machiene in case of an internal fault. The anti flood is normaly a polystireen float with micro switch on the base of the washer. This automatically puts the outlet pump on to drain the water. The machiene does not work exept the outlet pump in this mode.
Posted on Jan 18, 2010
SOURCE: Problem with GE Profile Dishwasher
My delay start switch does not work and the dishwasher beeps periodically throughout the day. Also, I have it set for a 109 minute cycle and after about 20 minutes it says that I only have 35 minutes left in the cycle! Any suggestions?
Posted on Jan 27, 2010
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
I have a GE Profile (#PSC23SGRB) side by side refrigerator that is about 7 years old. The light comes on when I open the door of the fridge and freezer but that is all. The whole thing is dead. Not cooling...
The freezer switch/thermostat is almost certainly bad. If you are sure your turning it on, and nothing happens, it is very likely bad.
If you have a multimeter, you can check and be sure that your getting power to this switch...and then with it in the "ON" position, check for power through the switch.
If you do not own a multimeter, you may wind up saving money to go ahead and call a service man. Otherwise, just to replace a part that you cannot check is a roll of the dice.
Mar 23, 2012 | GE Profile PSW26P Stainless Steel Side by...
Ge profile oven lock button won't go off
  • 1.Press the "Clear/Off" button on the control panel to reset the oven. This will clear the lock setting and unlock the door.
    2.Allow the oven to cool to room temperature to avoid turning the lock on again during this heating cycle.
    3.Reset the oven to the temperature you require to finish cooking by pressing the correct temperature control on the control pad.
    or
  • 1.If your GE Profile microwave won't turn on, unplug it, then plug it back in. A power outage may have occurred due to a power surge. Check your home's fuses and circuit breakers.
    2.Set the clock of your GE Profile microwave. Certain models will not operate until you set the clock. Select the "Clock" key and type in the correct time.
  • 3.Hold down your microwave's "Off" button. You may have accidentally hit the control-lock feature on your GE Profile microwave. Hold down the "Off" button for three seconds to turn the lock off.
  • 4.If the sensors of your GE Profile microwave are not working correctly, remove the food from the machine. If the sensors detect food-surface temperatures over 200 degrees Fahrenheit, it will not work properly until the area cools down.
  • 5.Contact GE Support if you are unable to resolve the issue on your own. Call the GE Support hotline or browse the help library on the GE website. You can also schedule a service visit on GE's website.
  • Nov 22, 2011 | GE Profile JK915 Electric Single Oven
    GE profile gas dryer wont turn on. There is power to the unit.
    The service manual is here:
    http://www.affordableappliance.com/Download%20Folder/GE_Harmony_Dryer.pdf
    Things to check
    1. Belt switch and belt on page 26
    2. Door Switch on page 25
    3. The inlet manual; (reset) safety switch on page 30
    4. The outlet thermistor on page 31
    These 4 switches and thermistors control power to the control panel. Find out which one has failed.
    Kelly
    Kelly
    Sep 26, 2011 | GE Profile Harmony DPGT750GC Gas Dryer
    Dispense panel blinking 82-88 on right - left - steady 88 - unable to reset - water only dispensing
    Hold Energy Button & Light Button for 10 seconds!! No repairs needed. Solution is not in manual.
    Sep 19, 2009 | GE Refrigerators
    Control panel dead
    1. Unplug dryer.
    2. Remove 2 screws from rear top of dryer.
    3. Lift panel assembly up, taking care to not pull wires.
    4. Check plugs on circuit board for panel display. Press each one firmly, but carefully.
    5. Put back together, plug in, turn on.
    Jun 14, 2009 | GE Profile Harmony DPGT750EC Electric...
    GE Profile Dishwasher beeping
    Mine was doing the same thing. It was eligible for a recall.
    Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
    Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
    Mar 04, 2008 | GE 24 in. Profile PDW9280JSS Built-in...
    The touch pad panel on stove is blank
    on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
    Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
    Dishwashers Logo
    65 people viewed this question
    Top GE Dishwashers Experts
    Mike
    Garth Jackson
    jdthefixer
    Are you a GE Dishwasher Expert? Answer questions, earn points and help others
