Question about D-LINK SYSTEMS DAP-1360 Wireless N Range Extender DAP-1360
Cannot open dlinkap page for set up of DHP-W311AVF
I bought D-Link HHP-W310AV but cannot access to the setup page when type in dlinkap on my browser. Pls help
Enter http://192.168.0.50 in the address field.
By default, Admin will be the User Name . Leave the password blank.
If you still can not access the web-based configuration utility see the troubleshooting guide on page 48 of the manual located at the below web link.Good luck!
http://www.dlink.com/-/media/Consumer_Products/DHP/DHP%20W310AV/Manual/DHPW310AVA1Manualv100WW.pdf
Dec 21, 2014 | D-Link Computers & Internet
Dap 1320 can't set it up using web browser link
These answers on all these sites are very confusing. Here's what I did to solve the issue of not connecting with a browser. 192.168.0.50 does not work nor does http://dlinkap.local. or whatever else is printed on the device. On my PC that is hard wired to my router, I logged into my router, checked which wireless devices were connected and found that dlinkap (note this is not the SSID that is printed on the device) was assigned 192.168.0.4. Set my browser to 192.168.0.4 and off we go to configure the extender.
Mar 09, 2013 | D-Link DAP-1522 Xtreme N Duo Wireless...
I have a Dlink 1150, it dosnt open the page in order to configure the device, when i write the dlinkap text in the box of url. Could any body help me?
Connect a LAN cable from the D-Link to your laptop/computer'sLAN port, open the browser on your laptop/computer and enter the D-Link'sconfiguration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 15, 2011 | Computers & Internet
DHP-306AV and the DHP-W306AV To extend the range of signal, for the above 2 items I bought: 1. is DHP-306AV to be plugged on the wall electrical socket and connected to the router (in this case my study...
This can occur when the wireless adapter in the computer has trouble connecting to the wireless router. It may not get an IP address from the router or the wireless adapter encryption setting didn't get an the encryption authentication from the router.
In this case right click on the wireless adapter on the Task bar and click Repair. This will make the router re-issue an IP address and authenticate the adapter's encryption setting.
Feb 20, 2011 | D-Link DHP-W306AV PowerLine AV Wireless N...
When i write hhtp://dlinkap on the explorer internet i have nothing
Hi i believe that you do have dlink access point device...
if the http://dlinkap doesn't work, try to asign STATIC IP to your computer
assign the following:
IP address:192.168.0.55
Subnet mask: 255.255.255.0
Default gateway: 192.168.0.50
the try to access again the http://dlinkap or simply typein 192.168.0.50
and thats it you're now in the login page of the access point device.
hope this will help
Aug 04, 2010 | Computers & Internet
Can not access to de adress dlinkap
If you are trying to configure a D-Link router, then take note of your Gateway IP address and default. The default could be 192.168.0.1.you may need to configure your computer using Static Ip address, If you are trying to configure an access point or print server. Enter the webmaster. Open your web browser and enter the IP address of your device D-Link in the address bar. This should open the page to log the webmaster. Use the instructions provided with your product, complete the configuration.
Jul 29, 2010 | Computers & Internet
Dlinkap web page is not opening
you will have to reset the router
disconnect the power supply and press te reset button for more then 3 second
now you will be able to enter the router with factory setting 192.168.0.1
Feb 13, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
Configuration dap 1150
You cannot configure the DLink by the URL address http://dlinkap?
You connect a LAN cable from your computer to the DLink.
Then open Internet Explorer and enter the URL http://192.168.0.1
the default login = admin
the PW is blank (just press Enter)
You can now configure the DLink.
Sep 28, 2009 | D-Link AirPlus G DWL-G710 Wireless Range...
D-LINK SYSTEMS DAP-1360 Wireless N Range Extender DAP-1360 Logo
Top D-LINK SYSTEMS Computers & Internet Experts
David Payne
David Payne
Are you a D-LINK SYSTEMS Computer and Internet Expert? Answer questions, earn points and help others
