Question about Kodak EasyShare C743 Digital Camera
Jammed lerns dropped camera lens wont close any suggestions
  • Kodak Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 17, 2009
My camera says..lens error will shut down automatically restart camera..! so my lens wont close even when i turn my s100 on or off. please help???
Make sure there is no dust or foreign material that could be jamming the lens and lens shutter. Have you tried removing battery or battery pack or try to reset camera? Just a suggestion.
Oct 02, 2013 | Canon PowerShot S100 Digital Camera
Zoom lens wont closed, malfunction
You could have a stripped, jammed, or broken gear inside the lens assembly. Here is a blog about things you can try to fix the problem, if the gear is just jammed:
If none of the suggestions fix it, the camera will have to be serviced. You can take it into a local repair shop, or contact Sony Support on the web for an estimate.
Good luck and hope this helps.
Apr 18, 2011 | Sony Cameras
Dropped camera now lens wont close. It says lens
Remove the batteries and insert new batteries . Sometimes this may work but in your case the lens is stuck inside, or it will have been damaged . Nothing can be done other than taking to service center to get it repaired .
Hope this helps .
Dec 16, 2009 | Canon Cameras
My camera been dropped and now it has a zoom error and wont close the lens back it stuck in one place - how much it will cost me to repair it? is it expensive?
To repair this model of camera requires a complete strip down to get at the lens unit. Lots of carefull desoldering etc.
The lens unit is just a larger version of a compact camera lens unit. Lots of gear gogs to release before you can un jam the lens its self.
Price will depend on where you take it and what damage has been sustained
Nov 18, 2009 | Fuji FinePix S1000FD Digital Camera
Lines on screen and photos, too bright photos outside
Lines across your pictures or pictures too bright are due to the shutter not closing correctly or at all.
to check this- turn camera on, turn off flash, turn camera around and look into the lens. Adjust the zoom so that the shutter and internal lens comes up to the end of the lens and whatch as you take a picture. You should see the shutter close completely over the lens. If it doesn't move or does not close over completely then there is your problem.
If camera was dropped it could have jammed the shutter open or obstructed it in some way from closing completely.
camera will require repair/ service.
You may have some luck if you power up and down your camera numerous times before taking a picture. The action of the lens opening and closing may free the shutter.
Aug 07, 2009 | Fuji FinePix V10 Digital Camera
Lens wont close.
did you try and take the battery out and outting them back in
might be worth a try
Feb 08, 2009 | Canon PowerShot SD850 IS Digital Camera
Sounds like you broke a lens gear, or it is jammed with sand.
Nov 17, 2008 | Cameras
Zoom error
worked on allot of fuji's. first detease, a gear is slipping in the lens retract assembly due to a crack or wear or jam
2nd guest .. zoom errors means its really stuck tight
the gears can be ordered and replaced and one more possibility is that the motor that drives the gear is bad
Also if dropped or zoom lens jammed hard... lens assembly needs total realignment or replacing..
May 23, 2008 | Fuji FinePix F460 Digital Camera
Cannon Power shot SD630 Lens Problem
Sorry to here that you can send it to a repair company like me for repair. cost about $120.00 plus shipping to fix.
Feb 26, 2008 | Kodak Easyshare M753 Digital Camera
Sanyo VPC-E760 Lens not closing
THis is really easy to fix. just pull the lense out so it is alligned. it might seem like your breaking the lens but its just jammed.
Feb 17, 2008 | Cameras
Kodak EasyShare C743 Digital Camera Logo
171 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
