Question about Uniden Radio Communications
Uniden BC345CRS Scanner
Unable to program Uniden BC345CRS. I can't seem to get freq. in correct banks. How to I clear freq. that I put in wrong.
Scanner stuck on one channel and won't allow me to enter new freq
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
May 07, 2014 | Uniden Bearcat BC 220XLT Radio Scanner
I can't get local police on my uniden bc345crs
That's because many police departments use a baud rate (similar to old fax modems) to decrypt the voice and then put it back together again with the right encryption key
Nov 28, 2013 | Uniden Bearcat BC345CRS Police Scanner
I want to dump the old programs and reprogram new freqs. for the uniden bc72xlt
Your can RESET your scanner to erase all data that you've programmed into it and return it to its original factory settings.To do this:
1. Power the scanner OFF.
2. While holding in the 2, 9, and HOLD keys, power the scanner ON. The process takes about 3 seconds, and the word CLEAr will display.
For single channels, you can program "000.0000" into any one of them to clear its programmed data, or just program a new frequency into the channel. The new data will override the old information.
Need the factory operating manual for your scanner? You can download and print it, free of charge, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Listening in since the 60's
Nov 10, 2010 | Uniden BC72XLT Handheld Scanner
How do you manually program known frequencies in a Uniden BC350C scanner? There are no numerals to key in.
Sorry, but your BC350C is an oddball that does not allow manual programming. You have to lock on to a freq in the SCAN or SEARCH mode, and then move it to the PRIVATE bank. Details are in the operating manual which you can download and print, at no cost, here:
http://www.uniden.com/pdf/BC350Com.pdf
Bill B
Aug 24, 2010 | Uniden BC350C Base Scanner
Deleting frequcies
Clear out everything do the following
While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAr appears.
To take out individual Freq. Manually tune to that freq. Ch/Bank on the scanner. Enter 0.00 like a new freq for that ch. and it will be gone.
Jun 22, 2009 | Uniden BC72XLT Handheld Scanner
Help me put new Frequencys in my scanner
Here is the link to all Uniden scanner manuals:
http://www.uniden.com/index/manuals_results.cfm?cat=3
Also, you can find the frequencies for your area at www.radioreference.com.
May 20, 2009 | Uniden BC60XLT-1 (30 Channels) 2-Way Radio
Uniden BC350C Scanner
Start by pressing 'band' & select the band that the freq you want to program is within by using the 'up' or 'down' button, then press 'search' , when you see the display getting close to the desired freq, press 'hold' & then use the 'up' & 'down' buttons to zero in on it. Then press 'program', then press 'private' & select the channel you wish to put it on (1-50). Repeat this process as needed. I find it's easier & faster to program all the freqs within a band as you can assign them to whatever channel you wish within the 50 in the private bank, then do the other bands. Hope this clarifies it, good luck. Regards from Community Communications in Wanaque, NJ.
Jul 17, 2008 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Programming a Scanner
Hey Emkat, here is a link to your owners manual, all you have to do is download it and print it. The programming starts on pg 24.
If you need freq's to put in it, go here;
http://www.radioreference.com/apps/db/
Just click on your country, state, county and it'll list all the freq's for you. I hope this helps you out in your search, let us know; Mechanic
Feb 12, 2008 | Uniden BC350C Base Scanner
New to Radio Scanners
If it just seems to be "stuck" on static, you probably need to adjust the Squelch. Try turning the squelch down until the static stops.
If you haven't programmed any frequencies into the banks, scanning won't do anything. Press "Func" and "Scan" to perform a Search. This way, if you find a frequency with a lot of chatter, you can program it into a bank for scanning later.
The easiest thing to do is to find frequencies for your local police, fire, etc. on the internet & program them into the various banks on the scanner.
BC72XLT user manual (page with PDF link)
Google for local frequencies
Dec 06, 2007 | Uniden BC92XLT Handheld Scanner
Radio Communications Logo
87 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
