Question about Protocol Manta 4-Channel Radio-Controlled Quad-Copter
Copter is charged. it wont respond to the rc though
Rc has batteries.. it turns on properly
    New Friend:
  • 3 Answers
Turn on the remote control first then the heli the instructions are wrong
(I have the heli)
Posted on Dec 26, 2013
Helicopter charger and batteries in remote ok, chopper won't fly
Is the "flight light" blinking on the copter? If you connect the USB cable to the copter will it power up? Have you tried different batteries in the remote? Check the pins in the charging port on the copter, Otherwise there's not a lot that can be done with these little RCs.
Feb 24, 2015 | Syma S102 IR Control Micro Blackhawk RC...
We haven't used the helicopter in awhile and we have forgot how to charge it, were should all the switches be ?
Are there electrical contacts on the bottom of the helicopter?
See if there is a place on the remote where you can attach the copter. Use the remotes' batteries to charge the copters' built-in, non removable battery.
Also... Google.
Jul 08, 2014 | Night Hunter Xtreme Glow In The Dark RC...
How do you turn on an HAK 311
On the copter right above the charging hole, there is a little switch. Left is off, right is on.
My copter has the problem that the remote doesn't work, turning it on does nothing, and connecting it to the copter only makes the light on the remote flash red.
HAK 31 is a piece of junk.
Feb 09, 2014 | Electric 3CH Mini Sport RTF RC Helicopter...
RC helicopter no longer responds to controller
1st,
extend the antenna out. (unwrap from skids ) and wrap it to the tail fin and back.
Also check the connection to the RX pc board. May need to be soldered better.
These are 23mhz,72mhz radios and Binding (which is a 2.4ghz digital system) is not going to happen here.
What to look for is the led on the heli rx. Turn tx on first, then heli. Look at led. It will blink at first then go solid when it syncs to the TX signal.
The heli should have the channel sticker on it (look at rx also) this needs to match the tx (some tx have a channel selector 1,2,3- a,b,c).
Jan 12, 2014 | Toys
Leds stay on and do not blink,
Hi. I have the same issue.
RC has brand new batteries, switches on and see to work properly.
Quad is charged. But LED will not blink.
RC and Quad do not see to connect.
RC lights keeps blinking.
What happened ? As far as I know nothing unsual. I bumbed the quad slightly on the roof of the living room where I was fligh it. Nothing unsual. I landed it a bit roughly. Then it stopped responding. I assumed charge was empty but when I charged , nothing happened.
Dec 25, 2013 | Protocol Manta 4-Channel Radio-Controlled...
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
Gyropter not lifting off after full charge
Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out.
Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
Hope that helps!
Nov 20, 2011 | JCPenney Gyropter RC Helicopter
Not getting altitude
Use only alkaline batteries, rechargeable batteries do not have sufficient voltage to fully charge the heli.
Apr 05, 2011 | RC Micro X Copter Mini RC Helicopter
My helicopter flew for a few seconds and then feel to the ground. It seems as if the controller does not work with the helicopter
Check your battery pack to see if the controller lost power or the battery pack in the RC ARF to ensure that, the copter can receive.
Dec 22, 2010 | RC ARF Falcon 40 Helicopter
Protocol Manta 4-Channel Radio-Controlled Quad-Copter Logo
412 people viewed this question
Top Protocol Toys Experts
scamatics777
Level 1 Expert
 Mikey
Mikey
 Russ Hill
Russ Hill
Are you a Protocol Toy Expert? Answer questions, earn points and help others
