Question about Mtd Products Yard Machines 158CC Tiller
Can not get the back tire off
The tire is flat and the tire seems to be weilded on. pin is out but wont move. mtd gt 18.5.46 mtd tradesman
  • 45 Answers
It probably is welded on - with rust.
Spray some WD-40, or something on the axle (on both sides of the wheel). If it still wont come off, you will probably need a puller.
*If your wheels have 2 holes in them, you can make a puller out of a piece of metal and a couple of bolts.
Posted on Aug 25, 2009
Changed rear flat on ariens 42 in riding mower put tire back on now mower will no move any more. worked fine when I pulled it up to take tire off
I feel you have lost the shear pin that goes on your axle. The shear pin goes in the little groove in the wheel It may have fallen out when you pulled the wheel off.There are also safety pins in the belt drive pulleys
Oct 27, 2016 | Ariens Garden
Mtd yard machine transmission
look under the mower and see if the drive belt has come off of any pulleys. sometimes they will have a stick get in there and the belt will come off and it wont move. also be sure it hasn't broke.
Nov 24, 2017 | Garden
Flat tire
i find the when they are stuck that bad you will break more by trying i pop of the beads with a pry bar and just change the tires right on the machine keep in mind if the outside has rust the wheel where the tire seals will as well if so put in a tube it will save you time later
Jun 18, 2012 | Yard Machines MTD Gold 23 HP Garden...
Had a flat tire on my GMC Sonoma. Changed the
wheel rim damaged ?? locating pin for wheel not lined up
May 16, 2010 | 1993 Nissan Altima
How to change the flat tire? Can not remove tire off the rim. How i get the nuts off?
While there is road side assistance that can help in times of need. It's imperative that every driver should know about how to replace a flat tyre. After ascertaining that the tyre is flat, you should check the link which will guide you to change the flat tyre with the spare one, have a look
=> DIY 10 easy steps to change flat tyre
=> How to Change Flat Tire
Dec 16, 2009 | 1998 Volvo S70
Mtd model series 790 mower wont move, belts are fine and transmission wont go in nuetral
mtd 1993 riding mower model 828 I was mowing then tractor stopped and wont go forward or backward It runs fine, and blades
seem fine. Drive belt looks fine.
Sep 17, 2009 | Mtd Garden
I replaced the drive belts on my MTD Tradesman model 139-652-118. Now it won't hardly shift and the break has to be pressed very hard to stop. When I put it in the lock for speed shift it used to sit with...
Make sure you put the right number belt on it. Then, look at the belt routing chart in the owners manual. It sounds like you may have used a belt that is too short, or routed the belt wrong, possibly at the pulley which loosens belt tension when you press on the brake/clutch.
Aug 22, 2009 | Mtd Garden
Need to remove rear wheels to replace tires on MTD riding mower.
most likely rust has taken over
find some liquid wrench or pb blaster and spray the axles liberally and let it penetrate the axles and wheel hubs where the axle goes through.
use a 2x4 and a hammer to tap against the wheel hub to try to move it down the axle then tap in back on to try to free it up as the penetrating oil works in, spin the wheel and tap in different areas of it
the worst case cenario would be to use a torch and heat the axle and hub up and drive it off, but it sounds as though you are moving it some and with some patience they eventually should come off
when you put them back be sure to coat the axle with some grease and do not forget to reinstall the key stock in each wheel, if they have it
the bolt in the center of the axle is all you need to remove and note where the washers came from and where they go back.
hope this helps you some
Jun 14, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Mtd Products  Yard Machines  158CC Tiller Logo
198 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
