Question about Vtech Cameras
Hi - every time I switch on the vtech kidizoom twist camera it says 'rograme ersion incorrect' then switches off. Ive tried everything, new batts, reset button, hooking it up to the but still nothing!!
SOURCE: What memory card does the Vtech kidizoom digital camera use?
Just a normal SD card buy in asda etc.
Posted on Aug 11, 2009
SOURCE: Vtech kidizoom camera will just freeze while you
hi i got a kidizoom for my daughter. i am trying to upload music from itunes it seems to go on but when i switch on the camera i can't find it anywhere. what am i doing wrong?
Posted on Jan 12, 2010
SOURCE: Vtech kidizoom camera does cannot find SD card
I had similar problem. In windows i formatted the SD card as 'FAT' rather then 'FAT32' (right click on card and select format) and that made the camera recognise it!
Posted on Jan 14, 2010
DrWho_64
  • 35 Answers
SOURCE: Vtech Kidizoom camera. Have changed batteries but
Don't use rechargeable batteries. Use Alkaline batteries. Rechargeables run at 1.2Volts each. Regular batteries run 1.5V. The camera wants 6V. Using rechargeables, you're shorting the camera by .8Volts. It wont turn on because it thinks the batteries are low and is protecting the pictures in memory. Use regular batteries, you'll be ok and your kid will love you again.
Posted on Feb 21, 2010
  • 11967 Answers
SOURCE: VTECH Kidizoom camera : even
You can call Vtech at 1-800-521-2010
Posted on Aug 17, 2010
Have inserted new batteries but it will not switch on
With the new batteries installed, try inserting a small screwdriver or unfolded paper clip etc into the reset button hole and you will feel the reset button move. Hold for a second or two and release. The camera should now switch on normally.
Mar 10, 2011 | Vtech Kidizoom Digital Camera
Vtech camera - will not switch on. Have tried changing baterries and sometimes can get it to switch itself on when the batteries are changed but thn it will not switch off.
Have you tried checking if the battery door is tightly secured? Make sure it's completely closed correctly, the charge could be messed up. If that doesn't work, try cleaning doors and where the battery touches the door. Some dust particles or dirt can be on there and effect the power.
Mar 08, 2011 | Vtech Kidizoom Digital Camera
I in stalled new battarys in Vtech kidszoom it came on 2 min later it switch off it won't stay on
Try with different band batteries. Most probably it is an issue with the Camera. The life of these type of Cameras are very shot.. Infact kids grow very faster.. Press the reset button, it it has.. If the issue persists with different batteries, it would be good if you for a local service to save the cost.
Jan 20, 2011 | Vtech Kidizoom Digital Camera
Vtech Kidizoom camera. Have changed batteries but unit is not even switching on. Son has had for just over a year and it has been dropped several times.
Try cleaning the battery contacts inside the battery compartment. Do this with a cotton swab "dampened" in rubbing alcohol. You may also want to clean the battery contacts and the charging station if so equipt. Thanks, Dana
Jan 06, 2010 | Vtech Kidizoom Digital Camera
Vtech kidizoom camera will just freeze while you are operating. Somewhere I read, if you hit the reset button, it will then work. This is true, but the camera freezes multiple times an hour. I then have to...
Dec 31, 2009 | Vtech Kidizoom Digital Camera
I have a vtech kidizoom pro camera and have tried many times to put music onto the camera but it just comes up on the camera as muisc files not found even though when the camera is attached to the computer...
I bought one for my 7 year old. install the cd that came with it first before you attach the usb lead. Open My Computer - find where the Vtech is. then open your computer folder where your music is mp3 mp4a which ever you have highlight the song then then "copy file" select your music folder in the directory where the vtech is located . I do not have an sd card in hers yet. Disconnect turn the dial to the music selector on your v tech make sure the volume is up ! I made that mistake first
Good luck hope it helps
Dec 01, 2009 | Vtech Kidizoom Digital Camera
Feb 20, 2009 | Vtech Kidizoom Digital Camera
Cameras Logo
324 people viewed this question
Top Vtech Cameras Experts
Tony
Are you a Vtech Camera Expert? Answer questions, earn points and help others
