Question about Samsung Televison & Video
Dvd lens price
My dvd lens is not working & i want a short strip i.e from lens to pcb to rotate the motor
  • 1 more comment
  • Azhar Shaik
    Azhar Shaik Feb 04, 2014
    I WANT THIS BUS STRIP WHERE I CAN PURCHASE IT....
  • Azhar Shaik
  • Azhar Shaik
  • Samsung Master
  • 1,511 Answers
It is difficult to understand just what you are trying to accomplish? The problem you are stating needs claiification.
Posted on Dec 25, 2013
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Cannot read any DVD/CD
hi welcome to fixya
here is my solution for that problem, first lets verify to narrow down where the main cause it could be. lets use first a dvd cleaner, dust can cause the optic lens not to read. then insert a dvd observe the light indicator ( yellow ) if blinking which mean the optic lens is starting to read the disc, if not it doesn't read. so at this time you are going to remove the cover with your dvd drive just to know and access the mechanism as will as the optic lens. now turn the power on and insert the dvd look for the optic lens if emits red light then moved going up to read the disc which mean the optic lens has supply. then check the spindle motor if rotates normally if not check the motor replace if defective. one way on how will you check the motor if defective through using a analog tester, check the resistance on the positive and negative terminal of the motor if the resistance is almost 0 ohm or shorted which mean it was worn out need to replace. hope this will help thanks for consulting through fixya.
Sep 11, 2011 | Computers & Internet
Not playing
defective lens....or motor w/c rotates the cd....you can purchase Lens assembly..it is a complete set of lens and motor driver...just look for the code number in the case.....it's better to replace this and it will runs as new.....in case of defective modemn or the PCB circuits..it is also replaceable they just gonna swap it w/ new one..
Feb 12, 2011 | Computers & Internet
Please I have canon copier IR3170C but it has been giving me this error code E000021 - 0001 any time i on the machine and it is being boot. Please help me out. thanks
getfile.asp?rid=1258 May 8, 2006 getfile.asp?rid=3215 Product : imageRUNNER C3100 / C3170 Title : E021-000x Error Code Error :
E021-000x Error Code: Developing rotary does not rotate and abnormal noise comes from motor.
E021 can be displayed when an error occurs in the developing rotary.
The detail codes are:
0001: The developing rotary home position cannot be detected.
0002: The intervals of flag detection during rotation is too short or long.
0003: The sensor does not detect the flag when the developing rotary stops at development point
As a result of inspection, it was found that the DC Controller PCB was unable to control the motor because it was faulty.
Workaround :
1. Check whether or not the developing rotary receives any physical load.
Rotate the developing rotary in a counterclockwise direction by hand to see whether it rotates smoothly. If any abnormality is found, eliminate the root cause. No problem is found, go to the Step 2.
2. Make sure that the connectors are securely fitted between J313 on the DC Controller PCB and the Rotary Motor (M8) or there is no pinched wire. No problem is found, go to the Step 3.
3. Replace the DC Controller PCB with a new one. If the symptom still recurs, go to the Step 4.
4. Replace the Rotary Motor with a new one.
DC Controller PCB: FG3-3846-030
Rotary Motor: FM2-0080-000 Canon USA, Inc. Systems & Technical Support Division
Jan 20, 2011 | Canon Office Equipment & Supplies
IMAGERUNNER 2000 SYSTEM E100
This can be caused by the following....
*When the laser scanner motor is started up, the BD input signal does not arrive within a specific period of time.
*When the scanner motor is started up, the motor rotation is too fast, and fails to reach a specific revolution within 20 sec at time of deceleration.
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not within a specific range (±2%) for an equivalent of 10 mm (print distance).
*While the scanner motor is rotating at a specific speed, the BD input signal cycle is not as indicated (±2%).
*During the WMUPR period after the power switch has been turned on or the front cover/left cover has been opened/closed, the drum unit is absent.
Possible cause:
  • The wiring is faulty (short circuit, open circuit).
  • The laser scanner unit is faulty.
  • The DC controller PCB is faulty.
  • The drum unit is not installed.
Remedy
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
Apr 15, 2010 | Canon imageRUNNER 2000 Copier
The DVD does not start and player comes up with error message H02
HI, you will need to replace the spin motor soon, it is showing signs of failuer.
the spin motor is part of the optical lens assembly.
Jun 21, 2009 | Yamaha DVD-S830 DVD Player
I got canon ir1600 i am receiving an error msg as error 100
as sm -
E100
When the scanner motor is started up, the BD input signal does not arrive
distance).
Possible cause
The wiring is faulty (short circuit, open circuit). The laser scanner unit is
faulty. The DC controller PCB is faulty. The drum unit is not installed.
Remedy
1) Drum unit
2) Connection
YES : End.
Jun 04, 2009 | Canon ImageRunner 1600 Copier
DVD not running
check the cables or replace it. Also cleaned the player with 2 heads lens cleaning dvd. try with good lens cleaner dvd.
click this link for more info
Feb 01, 2009 | Philips MCD702 Shelf System
Does not recognize/play DVD - shows "NO DISK"
If you are good at repairs.dismantle the Disk drive unit carefully from the main carriage and if the Optical lens reading unit has got a drive P C B ,then desolder the PCB so that you have only the CD mechanism on your table,with a Digital Multimeter check the Ohmic values of both the Spindle motor and Sled motor. the resistance should read between 4.5 ohms and 8ohms any value beyond this means that the drive signal voltage is not enough to move /rotate the disc and optical-pickup in syncronisation.you can get the drive-motors replaced,or replace the CDM assly available off the shelf.
this should solve the problem.hundreds SONY DVD players are running with this remedy.
Nov 29, 2008 | Sony DAV-C900 System
Lens motor
You are nearly right or even has stripped gears. Check out Olympus for a possible repair I do not think you will be jumping for joy at the price though.
Aug 21, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Televison & Video Logo
18 people viewed this question
Jerry Greenberg
Jerry Greenberg
