Question about HP Compaq Presario SR5130NX PC Desktop
Connect computer TO PROJECTOR - HP Compaq Presario SR5130NX PC Desktop
    Sergeant:
  • 191 Answers
.you dont stake what os you are running this is for windows7.post back if this is not your os.try this link.http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c01938980.
Posted on Jan 17, 2014
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
No signal from computer to projector
That might be because of the weak or bad connection of computer or the projector. Also you should check whether the projector is out of order or not.
http://mhelpdesk.com/field-service-management-software/
Dec 25, 2013 | HP Compaq Presario SR5130NX PC Desktop
I changed my desktop background and now my projector will not display
I would start by cycling this through the f4 option again first. Next I would connect the projector to the computer and then booting up the computer. Next I would disconnect the projector...turn it off, connect the projector again and then power up the projector. Try every combination of sequencing to get the computer and projector to talk to each other. It would not be a bad idea to change out the cable and try a new one as well. If it is a ceiling mounted projector then connect straight to the projector and try that.
Jan 07, 2013 | Hitachi Office Equipment & Supplies
Infocus 5000 won't recognize my computer
How about a little more information?
Does the projector turn on?
has it ever worked?
What type of interface (VGA, DVI, HDMI, RCA)
What type of computer (notebook or desktop)
That being said, double check your cable connections and make sure you tell your computer to look for the projector (Dell laptops used to use FN+F8 to switch from laptop to projector). Windows 7 has a menu choice "Connect to Projector". Mac computers - check system preferences and make sure the projector is ON before you plug it into the Mac.
Nov 25, 2012 | InFocus ScreenPlay 5000 Multimedia...
How do i connect my computer to the projector
projector have a VGA connection that you can connect a computer video cable to.
Sep 01, 2011 | 3M SCP712 Projector
Can I use the speakers for my projectors
Generally, projectors don't have speaker inputs.
If you want to avoid an A/V receiver, connect the PC speakers directly to the DVD player.
Connecting a computer to the projector
Connect the projector to a computer using a VGA cable (included with the projector). In addition, you can connect an audio cable from the computer to the projector if you with to use the internal speaker of the projector. An optional USB cable connection is also available.
1 - VGA cable connection
2 - Optional audio cable connection
3 - Optional USB cable connection
Mar 21, 2011 | iSymphony W2 Audio Shelf System
When i connect my projector to computer correctly it says no signal
Please perform thebelow steps :
You may follow these steps to connect the notebook to an Projector
1. Turn Off Computer.
2. Connect the monitor cable from the monitor to the monitor port on
the rear of the computer.
3. Connect the monitor to a power source and turn it on.
4. Press the Power button to turn on the computer.
* Switching the display to the external monitor
Press FN + F4 to toggle the display between the Notebook display and
Projector
May 20, 2010 | Computers & Internet
Computer used to work with projector, and now doesn't?
Have you tried pressing Fn F5? On my system (HP), by computer monitor goes dark when I connect the projector. Pressing (Function) FN F5 toggles the video between Computer Monitor, Projector, or Both.
Check the function settings for your computer. On my Compaq laptop at home, the video function is F4, so there may be different settings for your computer.
Jan 10, 2009 | Office Equipment & Supplies
The projector has a blue screen. The projector will not connect with the computer. We are using this for a presentation and can't get the projector to work with the computer.
Check all your connections to the computer then shut down the computer and restart. Try putting the setting on the remote to Computer setting. Also make sure the video setting are all correct in display on your menu.
Nov 20, 2008 | Sanyo PLC XU35 Multimedia Projector
HP Compaq Presario SR5130NX  PC Desktop Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
