Question about Starbucks Saeco Italia Digital Barista Coffee Machine
How to make shots of espresso stronger - Starbucks Saeco Italia Digital Barista Coffee Machine
How can I make the coffee stronger?
hi, you have to turn the grinder to lower number,and then the coffee will be stronger.
Aug 10, 2014 | Saeco Vienna Digital Coffee Maker,...
Which setting gives a stronger brew, setting 1 or setting 10 on the grinder.? There is a setting on the side door, what does this control?
Hi On this machine you want the lever under the grinder on 4 and the lever in the middle of the door towards the + (plus) but not all the way. Back 1 mark is the strongest setting you should use. It puts more coffee in the brew unit, there for stronger. If push all the way you will get an over charge on some shots and you could also break the brew drive. The grinder lever can be moved to 3 but only when the grinder is running. This makes the grind finer (smaller #'s). Get it too fine and you will plug up the brew unit.
Jun 06, 2011 | Gaggia Syncrony Espresso Machine
Trying to download the manual for titanium espresso coffee machine. need to know how to make the coffee stronger and not so watered down.
try this link, the manual is in Italian and english : http://www.gaggia.it/dam/bo/allegati/files/50_evolution_4302012000_rev05_istr.pdf
watery espresso could be caused by the grind being off or not dosing enough.
mikey@espressomachineexperts.com
Sep 20, 2010 | Gaggia Titanium Espresso Machine
I Have a new Bunn CW15-APS and am trying to make it produce stronger coffee. How do you adjust coffee strength since this system is so automatic?
To get stronger coffee, I would advice adding more coffee to the brew basket or using a slightly finer grind.
Jul 18, 2009 | Bunn CW 15-APS Coffee Maker
Miele cva615 how to make coffee stronger less water
open the door and adjust slide for more grounds, also program prebrewing so it adds a little water to the ground to get them going before the rest of the water is pushed though.
Feb 28, 2009 | Miele CVA615 Espresso Machine
Vev Vigano Carioca Nero Espresso Maker..what kind of grind to use
Use fine grind for espresso, darker roasted bean blend on Italian roast style are better, they are stronger and oily, perfect for expresso machines like this.
One of the best available here is this: Lavazza Qualita Rossa Ground Coffee, great brew on Moka style espresso machines.
Feb 16, 2009 | Vev Vigano Carioca Nero Espresso Maker...
Making Espresso shots... how does the macine do this? Not in man
www.partsguru.com look to the left for Saeco Home Models, select that, then go the model you have and download the manual.
On a magic comfort it has two settings for adjusting the espresso shot besides the amount of the shot. .
On a magic comfort plus,
you can adjust the grind size, the amount used for the shot, preinfusion (a short shot of hot water on the grinds before the unit passes all the water through the puck (coffee grinds), temperature and amount of water for shot
Also, when setting the strength on this machine, don't use a full grind amount as it can jam the machine. use a setting of 6 or 7 max for strong shots, not the 8 or 9 setting!!!
Dec 03, 2008 | Saeco Magic Comfort Plus Espresso Machine
Coffee watery
Setting your dose at max and grinder at finest is not good. This means that you are asking the machine to grind coffee really fine, and then dose maximun amount which can lead to the grinder getting clogged. If you are looking for stronger coffee, it is best to have several shots that one that has too much coffe and too fine. For stronger espresso, use less water instead of more coffee. Two shots of 2 oz. espresso (made with 7 grams of coffee) are more flavorful & sweeter than one shot of 4-oz. espresso made with 14 grams of coffee which could clog your grinder and door/channel. At this point, you need to clean the grinder ( inlcuding the door/channel). I suggest you have an Authorized SAECO Service Center check your machine. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Jun 15, 2008 | Saeco Caffe Charisma Espresso Machine
Saeco Italia SUP021 YR - Red light #29 on solid
Not clear on "Empty bean container/full grounds drawer) - not empty/not full. " But I gather that coffee is not being dispensed. Most Likely the grinder needs cleaning + brew group needs cleaning ( filter ). Do you get water/steam?
Jun 10, 2008 | Starbucks Saeco Italia Digital Barista...
No coffee will dispenses
Hi, We had a similar problem and it turns out the beans we were using were too oily and clogging up the works. We solved it by using a slightly more coarse grind (and brewing a stronger cup), and by buying only the best beans (oily beans don't make coffee stronger, just means they aren't good beans and by roasting longer can make the coffee taste stronger). Try Barefoot Coffee Roasters (I don't work for them, just love their coffee). We also use the cleaning tablet more often than prompted, and clean the inside of the flap when we dump the grinds. Good luck. Great coffee, but finicky machine!
Dec 13, 2007 | Jura Capresso Impressa Z5 Espresso/Coffee...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
Top Starbucks Coffee Makers & Espresso Machines Experts
eyecam
ray gallant
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
