Question about Toshiba TLP 671 Multimedia Projector
It lights up then after a few minutes it goes off. red lights go on. the fans are working and the fan screen is clean
  • gpag May 17, 2009
    THIS IS THE SECOND BULB I HAVE USED WITH THE SAME RESULTS. ITS SEEMS TO THINK IT IS OVER HEATING. CAN THE BALLAST BE REPLACED ?
  • 431 Answers
Hi I am Vortash sounds to me like a ballast or bulb fault this could be one of those silly faults you sometimes get .. the unit thinks the bulb has gone .. why because it goes out the processor is told this and the machine acts accordingly . Now I have had where the plug that is in the bulb housing is at fault the connectors expand under heat part and the bulb dies also had the same where the fittings on the end of the bulb wires are not secure and the same happens .. Also it could be a more serious Ballast failure or simply dry joints around the ballast unit ... without looking for myself I couldn't be sure but this is where I would start .. hope this is of help Regards Vortash
Posted on May 17, 2009
  • clive pearson
    clive pearson May 17, 2009
    Yes but to be honest if you have 2 bulbs you would be better off getting a working unit off ebay that needs a bulb as the cost of of a new ballast and fitting would cost a ridiculous amount and very difficult to obtain if you are not in the electronics trade .. and have a trade identificatuion or account . You could even profit from it if you got 2 units one for each bulb re sell it on ebay and get your money back .. hope this helps regards Vortash
2 Suggested Answers
  • 105 Answers
SOURCE: how to reset lamp timer for a TLP 671
Hi there folow the link bellow for the manual
Regards Al "alstech"
http://www.fixya.com/support/p147512-toshiba_tlp_671_multimedia_projector/manual-15037
Posted on May 26, 2009
After 10 minutes the colour wheel get out of synch and then a few minutes after that there is a crazy squeek and the lamp red indicator turns red light and the unit shuts off. I have opened up the unit...
Hi
Clean the Color wheel sensor thoroughly. a lens cleaning solution might help. be careful.
If problem persists.
Intall a 1" fan throwing air into the vent near height riser stud. into the color wheel chamber. this works.
Jun 13, 2011 | Optoma HD70 DLP Projector
My screen goes off control pad starts to vibrate and 2 red lights flash then fan stops???but have opened it up and cleaned it?
This could be a power issue with your Xbox. You could try cooling it down and waiting a few minutes and trying again.
See if this video helps you: http://www.youtube.com/watch?v=bvBPwJKp59g
Jun 30, 2009 | Microsoft Xbox 360 Console
Sony KDS50A2020 Blackout
Replace the lamp, clean the fans, seen it a hundred times, I know "the lamp light isn`t blinking" replace your lamp and you`ll be back up & running, gl, video-tek
May 29, 2009 | Sony KDS-50A2020 Television
I have a similar problem with the Sony 60" wega SXRD rear projection TV. The green light blinks on the power/display LED and the picture comes on for a few seconds and then the screen goes black . Then the...
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Apr 27, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
4 blinking red lights in power/standby
I would recommend replacing the fan, cleaning it doesn't solve the problem...If it does, it's only a temporary fix. Replacement fan is around $30 and easy enough to do yourself...
Sep 15, 2008 | Sony KDS-R50XBR1 50" HDTV
Projector shuts down after only a few minutes.
I'm having the same problem. My Model is PB8253. Projector started, then afer a couple minutes it goes off with the red lamp led flashing.
Just replaced the lamp, but the problem persists. Tried to remove all connecting cables, except for the power, but still the same problem.
Anyone with similar problem or solution, please contact me at dartveiga@gmail.com
Jan 19, 2008 | BenQ PB6100 Multimedia Projector
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
Toshiba TLP 671 Multimedia Projector Logo
131 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
