Question about Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT
Jandy Lite2 Pool heater will not stay lit after firing.
Just hooked up our new Jandy Lite2 125,000 btu pool heater and there seems to be a problem. The pump kicks on like it should and the heater fires but it only stays lit for about 15 seconds, then it shuts off. After 3 of the same instances, the heater place a trouble code on the screen, meaning ignition problem. I am 70 feet from the gas meter, so I used 1" gas line for good measure. Also, double and triple checked the wiring. Any ideas?
  • iceman_27us May 17, 2009
    Thanks jd21. There is a flame sensor that sits just over one of the burner tubes. It does seem to be in the flame where its supposed to be. Is there any way to test it to make sure it's working properly?
  • 163 Answers
Look at the sensor that tells unit that everything is lit. There should be some sort of sensor that tells the ECU that the ingnition area is a burn temp. It sounds like the unit can't tell that flame is lit. Hope this helps.
Posted on May 17, 2009
Aside from the other suggestions made here... make sure you have the inlet, and outlet pipes from the heater routed properly. If you have them backwards, the unit will fire, then kick off shortly after.
Reason for this is because the unit kicks off when the water temp at the inlet reaches a specific temp, if they are swapped, it's measuring the water it just heated, not the water coming back from the pool/ spa. Make sense?
Posted on Mar 05, 2010
Jandy lite2 lg175 pool heater will not remain lit where is the flame sensor located?
follow small black wire down from board next to ignitor in box or ignitor on burner clean up then try again
Aug 19, 2012 | Jandy Laars Lite2 Ld 175,000 Btu Heater
Why is my Jandy Lite 2 Pool Heater Tripping the Circuit Breaker
shorted ignitor remove the ignitor leads and see if it still trips if it doesnt trip replace the ignitor
May 17, 2012 | Jandy Laars Lite2 - 125,000 BTU Propane...
If your persure is to high you are probally running propane in a natural gas heater. If this is a new heater take it back and get a new L.P. verson if not they make a conversion kit with new gas orfaces for the burner and a new gas block for the gas valve. if your tech dosen't know this get a new tech, this is a box full of fire next to your hause. Don't save money on the tech it can cost to much!
Jul 23, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Laars Lite 2 NG 250 Btu
http://www.jandy-downloads.com/pdfs/H0264600A.pdf is the link for the manual to your heater. This may help, if not repost and I will see what I can do.
Jul 03, 2009 | Jandy Laars Lite2 Lg 125,000 Btu Heater
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
How to change thernal couple, without taking everything apart?
The thermal couple has a round cap with four notches next to the inlet and outlet that can be unscrewed with anything that will fit into the notches.
Jun 07, 2009 | Jandy Laars Lite2 Lg 125,000 Btu Heater
Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Logo
864 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
