Question about Canon CLC 1120 Color Copier
Paper feeder not pulling paper from drawers, it does pul from the drawer but then when the second stage is supposed to pick up it does not and indicates a jam.
  • Canon Expert
  • 1,326 Answers
Have you replaced the paper pick up & paper feed & paper sep. rollers? If not try to clean the rollers with Wd-40 or simple green. If the copier works better, you will need to replace the rollers. Good Luck
Posted on May 18, 2009
How do i fix the paper jamming which happen in my copier machine ricoh 2027at the second,third fourth drawer?
you need to check does the sensor on the drawer which is on the right side front of the drawer, does correspond with the paper inside the drawers.
Oct 10, 2016 | Ricoh Aficio Office Equipment & Supplies
No paper error, printer will not pick up paper out of tray, with no luck.
push the side door that face exactly the drawer of the located paper if there any lose ?
if yes you need to put adhesive one side sticker behind the drawer and in the middle to re gain the required pressure on the paper.
Feb 23, 2016 | Office Equipment & Supplies
Lexmark T644 Drawer 2 Missing error message but drawer 2 is in place. Drawer 2 always has problems pulling form form drawer when printing from drawer 2.
If job prints from the wrong tray or on the wrong paper or specialty media, this is an indication that the operator panel menu settings do not match the media loaded in the tray.
Make sure the Paper Size and Paper Type specified in the printer driver match the paper size and type in the tray.
For further assistance, please contact Lexmark Technical Support
Feb 09, 2012 | Lexmark T644 Laser Printer
Bottom drawer won't close and other drawer won't open
Sounds like the paper lifting plate for the bottom drawer hasn't lowered. The only way I know of to correct this is by removing the paper pick-up assembly. It's very easy. Open up the right lower door and you will see the paper pick-up assemblies. All you have to do is remove the two left screws. On the right side remove the cover. Then unplug the yellow wires under that same cover. Remove the single screw as well. The pick-up assembly should come out and the plate should drop. Make sure that the plate is free by lifting it and it should drop. This plate is not part of the paper pick-up assembly but is in the slot you've created by removing the assembly. If this is OK then replaced the paper pick-up assembly by reversing he procedure to remove it. As for the other drawer it may be a little harder. Possibly trying to loosening it and/or removing the paper assembly may help. It would be very difficult to help you without being there to see what is hanging the drawer up. This should help a little. Good Luck.
Apr 05, 2010 | Canon imageRUNNER 5000 Copier
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
I am using Toshiba e-studio 166. When i print say 10 documents together, at the output there are more than 15 papers i.e. 5 are unprinted plain papers come out stuck together in between. Please advise your...
Toshiba has extraordinary fingers and rubbers for paper pick up, so I assume that paper is the main problem.
Every time when you need to put paper in drawer you should shake a little bit (depends on paper manufacturer if they don't cut paper good they are connected with small tiny pieces of paper).
Also if paper is wet they will cause issues. Keep paper dry.
I hope it helps
Oct 31, 2009 | Toshiba e-Studio163 Copier
Copies crooked
make sure back stop and side guides are against all edges of the paper in the drawers, ADF edge guides..same thing. does this happen out of all drawers? if so there is a registration roller (long and usually hard rubber) that has to be pressed evenly across to pull paper straight, usually has springs bent around both ends. If it is not drawers or ADF has to be in the path from drawer but before Fuser (hot area) best bet is reg roller.
Aug 04, 2009 | Konica Minolta bizhub C250 All-In-One...
Canon PC770 Paper Tray Does not Close Completely
After numerous attempts, the drawer finally slid in and worked --- until today.
New problem - drawer wouldn't come out and indicator showed the paper was out when machine had paper.
Removed screws from bottom of copier - couldn't completely remove the metal plate, but was able to pull it out enough to allow the paper drawer to be removed. Only thing that could be seen as potential problem was a spring hanging down the back that did not seem to be attached to anything. (heavy duty, about 7" long and 1/2 inch diament)
Removed screw, replaced screws in bottom plate - drawer slid in fine - turned on and ran copies just fine. Don't know what the spring was for - but copier is working for the moment.
Jan 03, 2009 | Office Equipment & Supplies
Paper jam check drawer two t640 printer
Hello there,
If you are getting "Paper Jam check drawer two message" I would suggest you to check for any paper stuck inside the paper drawer two. If you don't see any paper jammed inside drawer two, you might also want to check out if its is stuck anywhere in the paper path. Removing the paper jam should fix the issue. Try cleaning the pick rollers (the rollers which pick the paper) in drawer two. This should help fixing this issue.
Merry Christmas!
Aug 20, 2008 | Lexmark T640 Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Canon CLC 1120 Color Copier Logo
100 people viewed this question
old marine
old marine
